在此拆机指南中使用的工具
简介
There are many small parts to this tear-down and are specific to they way they are positioned. Make sure you remember how they are set before you remove them.
这个拆解是不是维修指南。 要维修你的的PlayStation Move Navigation Controller,请使用我们的维修手册
  1. There are four screws located on the bottom of the controller. Located right above the bottom left screw is a reset switch, in case you need to re-sync the device to your PlayStation console.
    • There are four screws located on the bottom of the controller. Located right above the bottom left screw is a reset switch, in case you need to re-sync the device to your PlayStation console.
  2. There is one ribbon cable connecting the two trigger buttons to the main board. It is easily removed with a little tug.
    • There is one ribbon cable connecting the two trigger buttons to the main board. It is easily removed with a little tug.
  3. There is one more ribbon cable connecting the d-pad and can be unplugged the same as the first.
    • There is one more ribbon cable connecting the d-pad and can be unplugged the same as the first.
    • The battery is easily removed and is the same type used in the PlayStation Move Wand.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. There are four more screws which hold the joystick in place and white ribbon cable that is soldered in place on both sides, which allows for some flexibility, but cannot be removed without the rest of the board.
    • There are four more screws which hold the joystick in place and white ribbon cable that is soldered in place on both sides, which allows for some flexibility, but cannot be removed without the rest of the board.
    • Note the seperated button off to the side, which is the plunger for the reset button directly to the right of it.
  6. This is the main board separated from the casing the plastic head on the joystick is removable but the control is soldered to the board. The base charging input is detachable, but the USB circuit is part of the main board.
    • This is the main board separated from the casing the plastic head on the joystick is removable but the control is soldered to the board.
    • The base charging input is detachable, but the USB circuit is part of the main board.
    • On the second included picture you can see the three points that are the contacts for the X, O and PlayStation buttons.
  7. The casing reveals the primary buttons for the navigation controller.
    • The casing reveals the primary buttons for the navigation controller.
    • The top two buttons are for the X and O which only have a piece of white plastic covering the buttons.
    • Just below is the cover for the d-pad. It will reveal underneath a the same type of plastic with a ribbon circuit sandwiched in between the hard plastic and the d-pad buttons on protruding from the casing.
    • In the middle is the PlayStation button, and like the X and O buttons. Only has the white plastic piece in between that and the board.
    • Finally, at the very bottom is the piece that extends the red power light to the outside of the case. the joiner is removable and can easily fall out so try not to lose it.
  8. When putting back together, do not forget the reset switch button. Make sure You Put it in correctly, since it may seem like the device is dead if you put it back in wrong.
    • When putting back together, do not forget the reset switch button.
    • Make sure You Put it in correctly, since it may seem like the device is dead if you put it back in wrong.
  9. This is the full tear-down view if you need a reference to the parts in case you might be missing or have an extra part when you are done.
    • This is the full tear-down view if you need a reference to the parts in case you might be missing or have an extra part when you are done.
Joel
于2010年10月25日注册
2,509 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 2
过去的7天: 16
过去的30天: 50
总计 13,171
