拆解
This is a quick teardown of the playstation move controller.
这个拆解是不是维修指南。 要维修你的的PlayStation Move,请使用我们的维修手册。
Playstation Move Controller
Remove the 4 screws holding the back over and trigger button on.
Once open you will see two ribbon cables.
The one connected to the trigger button is removable.
The ribbon cable attached to light globe is soldered on.
Light Globe Cover and the LED Module can be separated.
The battery can easily be removed. There is connector on the side of the board.
Battery Specs: Single Cell 1380 mAh 3.7 Volt
Sony Part: LIS1441
Remove the inner plastic (1 Screw) frame to expose the logic board
Remove the 2 top screws and one bottom screw to remove the logic board from the controller.
Logic Board
Chip Closeups Included
503A 04c ALPS - Radio Module
AKM8974948D - MEMS Gyroscope
与5其他贡献者
616 声望
创作了3篇指南
徽章: 1
AKM 8974 - 3-axis Electronic Compass
Xeno - 2013年5月27日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 3
过去 7 天: 10
过去 30 天: 42
总计 18,410
