跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的PlayStation 2 Slimline,请使用我们的维修手册
  1. PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: 步骤 1 中的图像 1,3 PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: 步骤 1 中的图像 2,3 PlayStation 2 Slimline Teardown/Disassembly, PlayStation 2 Slimline Teardown/Disassembly: 步骤 1 中的图像 3,3
    • On a flat working surface, flip the PlayStation 2 Slimline so that the bottom side is facing up.
    • Remove the covers over the screws, circled in red on the second image.
    • Take a Phillip's #1 screwdriver and remove the five screws circled in red on the second image.
    • You will have to remove the "Do Not Void" seal in order to remove the last screw.
  2. PlayStation 2 Slimline Teardown/Disassembly: 步骤 2 中的图像 1,2 PlayStation 2 Slimline Teardown/Disassembly: 步骤 2 中的图像 2,2
    • Make sure you haven't forgotten the screw under the "Do Not Void" seal.
    • Take a metal spudger and separate the upper half of the chasis from the lower half.
    • For later models the DVD drive assembly is not screwed in and will fall off if you open it upside down.
  3. PlayStation 2 Slimline Teardown/Disassembly: 步骤 3 中的图像 1,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 3 中的图像 2,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 3 中的图像 3,3
    • With the chassis open you can see the motherboard and its attachments.
    • Identify the battery, then use a spudger to pry it out. Disconnect the battery from the motherboard with your hands.
  4. PlayStation 2 Slimline Teardown/Disassembly: 步骤 4 中的图像 1,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 4 中的图像 2,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 4 中的图像 3,3
    • Gently disconnect the three ribbon cables.
    • Take a Phillips #1 screwdriver and remove the four screws on the optical drive.
    • Two of the screws can't be seen on the picture, they are located on the opisite side from the visable ones.
    • Pull up the optical drive and carefully peel the flex cable, attached underneath the drive, from the metal plate.
  5. PlayStation 2 Slimline Teardown/Disassembly: 步骤 5 中的图像 1,2 PlayStation 2 Slimline Teardown/Disassembly: 步骤 5 中的图像 2,2
    • Remove the three PH00 screws from the fan's cover.
    • Then peel the duct tape back and remove the cable.
  6. PlayStation 2 Slimline Teardown/Disassembly: 步骤 6 中的图像 1,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 6 中的图像 2,3 PlayStation 2 Slimline Teardown/Disassembly: 步骤 6 中的图像 3,3
    • Remove the four screws marked on the picture. These are located on the bottom side of the motherboard.
    • Then flip the motherboard back over and remove the two rating screws on the upside.
    • Now both metal plates should be ready to remove.
  7. PlayStation 2 Slimline Teardown/Disassembly: 步骤 7 中的图像 1,2 PlayStation 2 Slimline Teardown/Disassembly: 步骤 7 中的图像 2,2
    • Remove the metal plate from the bottom side of the motherboard.
    • Now everything should be disconnected and you successfully torn your PlayStation 2 Slimline down.
    • To reassemble, follow these steps in reverse.
tlroesner
于05/13/12注册
1,864 声望
创作了4篇指南
2条评论
not all slimlines are internally the same. as seen in the second picture, this teardown is for the 75004 model
Roman - 回复
Komponen kotak hitam kaki 4 itu apa gan, di dalemnya kaya jumperan gitu. Itu fungsinya buat apa ya? Posisinya sudut kiri bawah iptikal drive.
camxmovie - 回复
添加评论
浏览统计数据:
过去 24 小时: 20
过去 7 天: 212
过去 30 天: 817
总计 79,614
