跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Miscellaneous Electronics,请使用我们的维修手册
  1. Plasma Ball Teardown, Safety Procedures: 步骤 1 中的图像 1,3 Plasma Ball Teardown, Safety Procedures: 步骤 1 中的图像 2,3 Plasma Ball Teardown, Safety Procedures: 步骤 1 中的图像 3,3
    • Obtain your plasma ball and unplug the wire (If battery operated take out battery's).
    • Turn the Off/On/Sound switch to Off.
  2. Plasma Ball Teardown, Unscrew The Base: 步骤 2 中的图像 1,3 Plasma Ball Teardown, Unscrew The Base: 步骤 2 中的图像 2,3 Plasma Ball Teardown, Unscrew The Base: 步骤 2 中的图像 3,3
    • Flip over the plasma ball ( Be careful if putting on a table, its glass its easily broken)
    • Unscrew the 4 screws, one in each corner of the mechanism.
  3. Plasma Ball Teardown, Pull the Base  Apart: 步骤 3 中的图像 1,3 Plasma Ball Teardown, Pull the Base  Apart: 步骤 3 中的图像 2,3 Plasma Ball Teardown, Pull the Base  Apart: 步骤 3 中的图像 3,3
    • Carefully pull apart the base from the main body,
    • Now we have the base and the main panel.
  4. Plasma Ball Teardown, Unscrew The Main Panel: 步骤 4 中的图像 1,3 Plasma Ball Teardown, Unscrew The Main Panel: 步骤 4 中的图像 2,3 Plasma Ball Teardown, Unscrew The Main Panel: 步骤 4 中的图像 3,3
    • Unscrew the two screws that hold the base to the control center.
    Why does the %#*@ thing have a microphone a mic on it up by the switch
    Sweet Hart - 回复
  5. Plasma Ball Teardown, Pop Out The Main Panel: 步骤 5 中的图像 1,2 Plasma Ball Teardown, Pop Out The Main Panel: 步骤 5 中的图像 2,2
    • Next pop out the control center by pushing on these two plastic holders.
  6. Plasma Ball Teardown, Remove The Main Panel: 步骤 6 中的图像 1,3 Plasma Ball Teardown, Remove The Main Panel: 步骤 6 中的图像 2,3 Plasma Ball Teardown, Remove The Main Panel: 步骤 6 中的图像 3,3
    • Pull the control center off the base and you are done with the teardown
    • To rebuild the Plasma Ball do all the steps in reverse order.
Payton Harty
于11/02/16注册
296 声望
创作了2篇指南
18条评论
Interesting teardown! Although, it might be noted that care should be taken when handling the circuit board, especially around the flyback transformer (big black cylinder), as plasma balls typically operate on high voltages and may pose a shock hazard.
nerdyphysicsguy - 回复
does anyone know anything about troubleshooting electrical issues? I have a ball this is 20 years old and worked in 2016 when i packed it to move, but when i reopened it 8 months later i get nothing when i turn it on. Anyone have ideas?
Josh Pickles - 回复
It could be a couple things leading to this. The wire could be faulty or the wire is not touching the steel wool are most likely the problem. You could try and tear down adjust it and see if it helps.
Payton Harty -
When I tried putting it back together it would not light the same way does anyone know how to fix this?
Cmolinar98 - 回复
Need to ensure the wire touches the steel wool when reassembling.
Coen Stoltz - 回复
Any suggestions as to get the arcs to use the whole globe? Unless I touch the globe the arcs all shoot along the base
Grant - 回复
Thanks! Used to repair the plasma ball at local children's museum.
Calvin Stevens - 回复
My plasma ball makes a high sound without touching . I can not let in work because of that noise , does anyone know how to fix this noise?
lacusta45 - 回复
A high-voltage discharge from a Van De Graaff generator to the plasma ball globe killed the latter. What internal component is most likely damaged?
Eric Anderson - 回复
I had one forabout 30 years.. sometimes people would put metal objects up to the glass 4 bigger spark effect. and then one day it just didn't work like it used to. after some fine scrutinizing I realized that the metal objects being held up to the glass creating amuch stronger Arkinside that the ark actually burned a tiny pinhole through the glass bulb no vacuum no spark. was able to pull a vacuum on the tube seal the hole and Wallah she worked again only to be burned up in house fireyears later
Rachel Maher - 回复
my son just got a plasma ball for Christmas, it worked this morning but when I turned it on tonight it would only do a few arcs and only at the very very bottom.. any help?
Freya - 回复
I totaly tore down illumina storm and cleaned and adjusted wool and wire im getting power to the point to where it plugs into slide bottons but wont even flicker when turned on NEED SOME HELP HERE???
Dave Williamson - 回复
I need to but what happens if it electrocutes me
CAYDEN SOHNS - 回复
Where can i get the replacement coils?
spacewranglers - 回复
What Plasma Ball is this specifically? Like the brand name of it
Jack McCree - 回复
Where can you order a new plastic housing for the 12v female hole? I have managed to take it apart but can’t find spares online?
Evan - 回复
This might sound dumb, but I need to put new gas into the sphere so I can get the plasma to arc, any advice?
Matthew - 回复
Is a plasma ball meant to be left on for a few hours or more? I bought one at a Yardsale today and it worked great, but I accidentally left it on and about 5 hours later I noticed it was warm and no longer working. Any ideas or suggestions?
Lori Garris - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 19
过去 30 天: 64
总计 15,000
