你所需要的
Let's see what's inside!
Turn your Pantech Crux so that the back cover is facing upwards.
Press the indented area at the top of the back cover with one thumb and slide down the cover with your other thumb.
Remove back cover and set it to the side.
Locate the area where the back case meets the silver outlining.
Use your thumb or the 0.8 SIM Eject bit to lift the back case up.
Slide either your thumb or the 0.8 SIM Eject bit between the back case and the silver outlining until the back case comes free.
Lift and remove the back case from the phone.
Place phone with the screen facing downwards.
一条评论
Thanks for the help. It was fun to take apart my phone and see if I could fix it before trading in for a new one.
The screen is black: it shows light, but it is just projecting a black screen. Since this is a touch screen, that means that I can't see anything that I am doing or even make a phone call. I have memorized where the "answer" button is, so I can receive...
Thanks again!
BustoJuice - 回复
