跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Pantech Crux,请使用我们的维修手册
  1. Pantech Crux Teardown, Pantech Crux Teardown: 步骤 1 中的图像 1,3 Pantech Crux Teardown, Pantech Crux Teardown: 步骤 1 中的图像 2,3 Pantech Crux Teardown, Pantech Crux Teardown: 步骤 1 中的图像 3,3
    • Let's see what's inside!
    • Turn your Pantech Crux so that the back cover is facing upwards.
    • Press the indented area at the top of the back cover with one thumb and slide down the cover with your other thumb.
    • Remove back cover and set it to the side.
  2. Pantech Crux Teardown: 步骤 2 中的图像 1,2 Pantech Crux Teardown: 步骤 2 中的图像 2,2
    • Place your thumbnail in the groove at the bottom of the battery.
    • Lift your thumbnail up to remove the battery from the battery casing.
  3. Pantech Crux Teardown: 步骤 3 中的图像 1,3 Pantech Crux Teardown: 步骤 3 中的图像 2,3 Pantech Crux Teardown: 步骤 3 中的图像 3,3
    • Grab something with a Phillips #000 Screwdriver head.
    • Locate the four screws on the corners of where the back cover was.
    • Use the Phillips #000 Screwdriver to remove these screws.
  4. Pantech Crux Teardown: 步骤 4 中的图像 1,2 Pantech Crux Teardown: 步骤 4 中的图像 2,2
    • Locate the two screw covers at the top of the phone.
    • Grab a 0.8 SIM Eject bit.
    • Use this bit to get underneath the cover and lift up.
    • Remove both covers.
    • Use the Phillips #000 Screwdriver to remove both screws.
  5. Pantech Crux Teardown: 步骤 5 中的图像 1,3 Pantech Crux Teardown: 步骤 5 中的图像 2,3 Pantech Crux Teardown: 步骤 5 中的图像 3,3
    • Flip your Pantech Crux so the screen is facing upwards.
    • Locate the sticker above your screen (it has a lock on it).
    • Use the 0.8 SIM Eject bit to get underneath the sticker.
    • Peel up the sticker.
    • Use a Phillips #000 Screwdriver to remove the screw that was beneath the sticker.
  6. Pantech Crux Teardown: 步骤 6 中的图像 1,3 Pantech Crux Teardown: 步骤 6 中的图像 2,3 Pantech Crux Teardown: 步骤 6 中的图像 3,3
    • Locate the area where the back case meets the silver outlining.
    • Use your thumb or the 0.8 SIM Eject bit to lift the back case up.
    • Slide either your thumb or the 0.8 SIM Eject bit between the back case and the silver outlining until the back case comes free.
    • Lift and remove the back case from the phone.
    • Place phone with the screen facing downwards.
  7. Pantech Crux Teardown: 步骤 7 中的图像 1,3 Pantech Crux Teardown: 步骤 7 中的图像 2,3 Pantech Crux Teardown: 步骤 7 中的图像 3,3
    • Locate the buttons on the side of the phone that are now loose.
    • Remove these buttons by pulling on them with your thumb and pointer finger.
  8. Pantech Crux Teardown: 步骤 8 中的图像 1,2 Pantech Crux Teardown: 步骤 8 中的图像 2,2
    • Locate the screw that is in the middle of the motherboard.
    • Use the Phillips #000 Screwdriver to remove this screw.
  9. Pantech Crux Teardown: 步骤 9 中的图像 1,1
    • Loosen the motherboard from the front case.
  10. Pantech Crux Teardown: 步骤 10 中的图像 1,1
    • Locate the small wire in the bottom right corner of the motherboard.
    • Release this wire by gently pulling up on it with your thumb and pointer finger.
  11. Pantech Crux Teardown: 步骤 11 中的图像 1,3 Pantech Crux Teardown: 步骤 11 中的图像 2,3 Pantech Crux Teardown: 步骤 11 中的图像 3,3
    • Lift the motherboard.
    • Locate the cable that attaches the motherboard to the front case.
    • Use the 0.8 SIM Eject bit or your nail to lift up and pop off the piece that attaches the cable to the motherboard.
  12. Pantech Crux Teardown: 步骤 12 中的图像 1,2 Pantech Crux Teardown: 步骤 12 中的图像 2,2
    • Flip the motherboard to the left of the front case.
    • Locate the four screws that were below the motherboard.
    • Use the Phillips #000 Screwdriver to remove all four screws.
  13. Pantech Crux Teardown: 步骤 13 中的图像 1,2 Pantech Crux Teardown: 步骤 13 中的图像 2,2
    • Use your thumb or the 0.8 SIM Eject bit to lift up the layer containing the motherboard from the front of the phone.
    • Run your thumb or the 0.8 SIM Eject bit along the edge of this layer to loosen it.
    • Remove the layer when it becomes loose enough.
  14. Pantech Crux Teardown: 步骤 14 中的图像 1,3 Pantech Crux Teardown: 步骤 14 中的图像 2,3 Pantech Crux Teardown: 步骤 14 中的图像 3,3
    • Underneath the layer you just removed is a piece of metal with seven screws on it.
    • Use a Phillips #000 Screwdriver to remove all seven screws.
    • Use your finger or the 0.8 SIM Eject bit to remove this metal piece from the front of the phone.
  15. Pantech Crux Teardown: 步骤 15 中的图像 1,2 Pantech Crux Teardown: 步骤 15 中的图像 2,2
    • What you see is the back of the screen.
    • To remove the screen lift it up from the side.
  16. Pantech Crux Teardown: 步骤 16 中的图像 1,1
    • Congratulations! You have completed a teardown of the Pantech Crux.
Megan Voss
于09/17/13注册
79 声望
撰写一个指南
一条评论
Thanks for the help. It was fun to take apart my phone and see if I could fix it before trading in for a new one.
The screen is black: it shows light, but it is just projecting a black screen. Since this is a touch screen, that means that I can't see anything that I am doing or even make a phone call. I have memorized where the "answer" button is, so I can receive...
Thanks again!
BustoJuice - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 983
