跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Panasonic EB TX320ASW,应参考我们的维修指南
  1. Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: 步骤 1 中的图像 1,2 Panasonic EB TX320ASW Teardown, Panasonic EB TX320ASW Teardown: 步骤 1 中的图像 2,2
    • To remove the faceplate, pry the top of faceplate away from the phone. Follow snaps down, until faceplate is completely popped off.
  2. Panasonic EB TX320ASW Teardown: 步骤 2 中的图像 1,1
    • To remove battery push clip in; battery will pop out.
  3. Panasonic EB TX320ASW Teardown: 步骤 3 中的图像 1,1
    • Using a Star 3.0 bit, remove 4 screws in battery compartment.
  4. Panasonic EB TX320ASW Teardown: 步骤 4 中的图像 1,2 Panasonic EB TX320ASW Teardown: 步骤 4 中的图像 2,2
    • To separate front of phone from the back; start prying from bottom and work up the side. The phone should then pop apart.
  5. Panasonic EB TX320ASW Teardown: 步骤 5 中的图像 1,1
    • To remove keypad, turn front of phone over and let keypad fall out. All keys are connected by one rubber section.
    • If a button had been ripped off your keypad, you can replace the entire rubber keypad at this step and reassemble phone.
  6. Panasonic EB TX320ASW Teardown: 步骤 6 中的图像 1,3 Panasonic EB TX320ASW Teardown: 步骤 6 中的图像 2,3 Panasonic EB TX320ASW Teardown: 步骤 6 中的图像 3,3
    • To remove main-board from phone grab side of phone and pry upwards. Board should snap out.
  7. Panasonic EB TX320ASW Teardown: 步骤 7 中的图像 1,1
    • To remove speaker cover, pull out silver plate.
  8. Panasonic EB TX320ASW Teardown: 步骤 8 中的图像 1,2 Panasonic EB TX320ASW Teardown: 步骤 8 中的图像 2,2
    • After silver plate is removed, power button sits freely. Speaker can be removed by pulling up on it.
    • If your speaker went out it can easily be replaced in this step with a new one, then reassemble phone after this step.
  9. Panasonic EB TX320ASW Teardown: 步骤 9 中的图像 1,2 Panasonic EB TX320ASW Teardown: 步骤 9 中的图像 2,2
    • To remove keyboard circuit press on the middle and slide down. The board will pop up allowing for removal.
  10. Panasonic EB TX320ASW Teardown: 步骤 10 中的图像 1,3 Panasonic EB TX320ASW Teardown: 步骤 10 中的图像 2,3 Panasonic EB TX320ASW Teardown: 步骤 10 中的图像 3,3
    • To remove main-board from bracket, gently apply pressure to the four small clips. Board will pop out freely.
  11. Panasonic EB TX320ASW Teardown: 步骤 11 中的图像 1,2 Panasonic EB TX320ASW Teardown: 步骤 11 中的图像 2,2
    • To remove LCD screen pry back on highlighted clip and pull screen out. The screen will then pull up and out.
    • If the LCD screen went out, or was cracked somehow, replace with a new LCD screen and then reassemble phone from this step.
Andrew Foss
于10/04/11注册
10 声望
撰写一个指南
团队
UW Stout, Team 5-2, Zhou Fall 2011 UW Stout, Team 5-2, Zhou Fall 2011 的会员
UWSTOUT-ZHOU-F11S5G2
2 名成员
创作了1篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 3,502
