简介
We got our hands on the new Palm Pre from Sprint! Oh joy, our all-nighter in front of the Sprint store paid off! We're finished disassembling it now. Follow our updates @ifixit on twitter.
你所需要的
We arrived at the Santa Barbara Sprint store at 2am and were first in line!
Two blocks down the street at a local shoe store were 18 people stolidly entrenched in line for Kanye West's new Air Yeazy shoe. Some of them had been in line since Monday!
By the time we got our Pre at 8 am, there were about 25 others waiting.
It took several tries to activate the phone (about five minutes total), but no where near as bad as Apple's iPhone 3G launch activation woes last summer.
We tested out Sprint's 3G EVDO network on the road home and didn't notice any interruptions. Uploads and downloads were fast, and Pandora's application ran like a champ.
WebOS is so cool! We love how natural it feels to swipe between applications and multitask with Web, Twitter, AIM, and Pandora.
Contents of the box:
Palm Pre phone
AC Phone Charger, Standard Li-Ion Battery
Stereo Headset, Carry Pouch
Micro USB Sync Cable
Get Started Guide and Features Guide
A prepaid plastic recycling envelope in the box, making it easy to recycle your newly obsolete phone. This is a fantastic move on Palm's part, but of course recycling is a last resort if you can't fix it.
And a partridge in a pear tree...
Users preferring physical keyboards will be satisfied, but iPhone veterans may be left disappointed at the lack of a software keyboard option.
Revealing the keyboard feels awkward and interrupts the smooth WebOS experience. Try before you buy, because this keyboard could be enough to deter picky users.
The Pre comes with a stylish and rugged case, a slide-out QWERTY keyboard, earbuds and USB cable.
The Pre is "Inspired by and designed in California," while the iPhone is merely "Designed by Apple in California."
The battery came only partially charged, and we managed to drain it on the 1.5 hour drive back from Santa Barbara.
We'll just charge it briefly with the MicroUSB connector before ripping it apart. :)
You get a full one year warranty on hardware, but for software Palm only promises "software will perform in substantial conformance to their program specifications for a period of ninety (90) days."
The back of the phone and speaker.
The speaker in the Pre is substantially better than the one in the iPhone.
Palm didn't skimp on antennas. They're exposed for all to see as soon as you remove the back panel.
The antenna design is three dimensional to optimize signal quality. The iPhone's antennas also use this technique.
The small sticker labeled palm visible in the third image is probably there to prevent people from doing what we're about to do...
One was labeled GPS (its obvious what its for) and the other one was labeled DIV (for diversity antenna - thanks microbreak!).
Re: Step 15
"...there's no denying that packing the keyboard into a device that's no larger or heavier than the iPhone is a very impressive engineering feat."
At 87% volume of the Pre, the iPhone also weighs 2 grams less.
If they hadn't packed the keyboard in, I'm sure your statement would be true, except for the 'very impressive engineering feat' part.
来自 nxthxn 的话:
Is two grams really enough for a human to notice the difference? It's within rounding error - if given in ounce units both would weigh 4.7 ounces.
dculberson - 回复
Removing the keyboard bezel.
The hardware keyboard and its associated sliding mechanism weighs 32 grams. That's nearly 25% of the weight of the phone! Even if you're not a fan of a hardware keyboard, there's no denying that packing the keyboard into a device that's not much larger or heavier than the iPhone is a very impressive engineering feat.
The Palm Pre is the first phone using Texas Instrument's new OMAP3 (Open Media Applications Processor) platform.
The processor is a 600 MHz ARM Cortex A8 + PowerVR SGX 530 GPU + 430MHz C64x+ DSP + ISP (Image Signal Processor)
The chip covered by a white sticker on the LCD is CP6944BA 0907 A 04 KOR 604022.
We found a water damage sensor on the logic board, just below the Micro USB port, indicated by the red box on the second image.
Removing four more small connectors, and the main logic board is finally free.
Like the original iPhone, the Pre has two main boards, the logic board and the communications board.
Unfortunately, everything interesting is carefully hidden beneath metal EMI shields. Not only are the shields soldered to the board, there's epoxy holding them down as well. Palm definitely didn't make it easy to see what makes the Pre tick.
This is an incredibly thin, flexible PCB.
The Pre has an integrated 3 megapixel digital camera with LED flash.
The camera is one of our biggest complaints with the iPhone. The iPhone suffers from both poor quality photos and a long shutter delay. While the quality is definitely improved on the Pre, it's still pretty slow snapping photos.
You can see the standard phone vibrator next to the camera.
来自 n8b 的话:
Does the camera come off the board that has the phone vibrator without a soldering iron?
I have torn mine apart, and it does not appear to come off easily. It may even be difficult with a soldering iron because of the extremely thin flexible pcb. That is why I asked if they had any ideas.
You may be able to snip the leads coming out of the camera module, but that would be a pretty permanent solution I imagine.
来自 n8b 的话:
No, the camera is surface mount soldered onto the board.
Kyle Wiens - 回复
来自 RolfB 的话:
Does anybody know what the copper coil does that is on the back panel? See photo above (step 23) lower right corner.
That copper coil on the back panel that comes with the Touchstone charging kit. We talk about it in our touchstone teardown.
Kyle Wiens - 回复
来自 emooretc 的话:
Man that's too bad. The treo 700p was pretty easy to pull the camera on. Just pull a few screws and the camera just unplugged. I was wondering if that thing it was mounted too was a board or a cable. I guess I'll have to stick with my treo for now and see how the new iPhone looks. I've had a palm in my pocket ever since the 99 when the IIIe came out.
来自 kyle 的话:
Thanks Kyle. when I saw the coil I thought of it but I wasn't sure. I just saw the latest Brink on TV and they mentioned it: the Pre's wireless charging. It's funny that electric toothbrushes got that feature 10 years ago (though a little simpler) and we see it just now appearing in a very obvious application. It looks like that all the engineers who wanted to do this "stuff" (keyboard, wireless charging...) at Apple (and weren't "allowed) went to Palm... It will be interesting to find out what these "big old boys" carriers and other old-style companies (Nokia, Moto....) will come up with when they propose the new "standardized" charging solution for our cells. It should be wireless! Maybe Palm is going to set some standards again (for a while). I hope the Pre will be doing well. We need competition. Otherwise the iPhone will just fade away with its next iteration...nothing much new this year as we found out today.
来自 RolfB 的话:
It is the inductive charger for the pre called the touchstone charger. The phone is held on to the touchstone by means of the four magnets around the coil. When in place, inductive charging occurs. In other words the phone gets charged without plugging in cables.
Internal components, from left to right:
Earpiece speaker, LCD display and digitizer, microphone, communications board.
Original rear panel and plastic framework.
Battery, internal metal framework and spring mechanism, keyboard.
Camera board and main circuit board.
Main plastic framework containing antennas, antenna cabling, and the surprisingly excellent speakerphone.
Samsung K5D1257ACC-D090
Qualcomm MSM6801A
AVAG0 FEM-7788
0CEQ 86K H33F
Well done for your teardown! Just wanted to point to an erroneous identification of the bluetooth chip. On your pics I can clearly see Marvell's 8686 WLAN chip. However it's not a combo WLAN+Bluetooth chip as there is another chip right next to it that comes from CSR (you can read it on the packaging) and that's CSR's bluetooth SoC. Also the chip underneath the Elpida DRAM die is Texas Instruments's OMAP 3 chip. The other TI chip next to it (TWLXX) is the power management unit that works with it. THx
cellularme - 回复
来自 cellularme 的话:
Fixed, thanks!
Kyle Wiens - 回复
You have two major errors in the blockdiagram and the PCB info here:
The TriQuint Cellband PA-Duplexer in the new small 7x4mm package is completely missing in your list and the block diagram! It is TriQuint part number TQM613026A. (You call it a "Duplexer" only, which is wrong.
http://www.triquint.com/docs/o/TQM613026...
The Avago PCS band part is a larger and older PA-Duplexer Module in 8x5mm package called AFEM-7738 (not FEM-7788), see:
The back of the display, complete with what appears to be a manufacture date at the beginning of January.
Unfortunately for repair, it doesn't look like the LCD and digitizer are easy to separate.
Both the iPhone and the Pre sport a HVGA display. However, the iPhone's display measures 3.5" diagonally, while the Pre's is only 3.1"
Logic board with shielding removed
Chip markings:
Texas Instruments TWL5030B 8CA28MWC
Marvell WiFi chip under the silver EMI cover, marked W8686B12. Directly above it is the CSR bluetooth chip. They're both on a daughterboard soldered to the logic board.
Samsung SDRAM KMCMG0000M-B998
ELPIDA K2132C1PB-60-F 08510N060. Another BGA chip underneath this one is Texas Instruments OMAP3430.
Unbranded chips: 3335A ADJ RNX, 89A8 850. And the one hidden with epoxy above Samsung's SDRAM is Kionix 3-Axis Accelerometer.
The top of the board is labeled 888-3 94V0 1 309 - F3. The bottom of the board is bereft of chips or markings, something Apple has never done.
Component comparison between the iPhone and the Palm Pre.
Hardware-wise, the Palm Pre is very impressive. Our only hardware complaint was the physical keyboard, although some people may appreciate the hardware keyboard.
The Pre logic board is substantially smaller than the iPhone logic board, which is very impressive considering how renowned Apple's engineers are for shrinking hardware footprints. It's amazing the difference a year can make.
In general, this Palm hardware reminds us a lot more of Apple's engineering style than any of hardware we've taken apart by other manufacturers (like Dell).
also, could you please post a teardown of the keypad itslef:
-what is the backlight method (side fire LED w/ light guide, or EL)
-is the keypad a single film or singulated
-are the actuators pucks on the EL or the keypad film/keycaps
-how many dimples do the popples have (i assume 3-4)....do you know the actuation force?
-how is the keypad tactility?
-how do you find the backlighting brightness?
一条评论
I dont suppose after all this time you can help me with a palm pre plus? I kept it because I have some great photos on it. But there is only the power port. No sd card accessable. The power port broke. Is there any way to still get the phots out? Oh yes, I bought a replacement so I have one that still works. Well, it did a few months ago. I can charge the broken one by switching battery after it's charged.
Additional problem, it acts like it's a new phone to set up, asking for i.d. of some sort. So basically is there any way to either physically remove and transplant the memory (chip?)or load it onto a computer?
