跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Palm IIIc,请使用我们的维修手册
  1. Palm IIIc Teardown, Removing broken LCD screen: 步骤 1 中的图像 1,1
    • Keep track of all pieces removed from the device.
    • Gently pull off the device cover. The cover snaps on and off easily where the cover attaches to the Palm IIIc device
  2. Palm IIIc Teardown: 步骤 2 中的图像 1,1
    • Using a Phillips head screwdriver, take out the four screws on the back of the device. You may have to pull them out with your hands once they are unscrewed.
    • There will be two long screws and two short screws. The long screws come from the top of the device, and the short screws come from the bottom of the device.
  3. Palm IIIc Teardown, Remove the Front and Back Covers: 步骤 3 中的图像 1,1
    • Using a spudger, carefully pry open the front and back covers along the side seam.
    • A small sensor cover will fall out when the front and back covers are removed. Keep track of it.
  4. Palm IIIc Teardown, Palm IIIc Teardown: 步骤 4 中的图像 1,1
    • Unhook battery cable from the motherboard and remove the battery.
  5. Palm IIIc Teardown: 步骤 5 中的图像 1,2 Palm IIIc Teardown: 步骤 5 中的图像 2,2
    • Behind the motherboard remove the brown plastic clamp and remove the front screen cover.
  6. Palm IIIc Teardown: 步骤 6 中的图像 1,2 Palm IIIc Teardown: 步骤 6 中的图像 2,2
    • Unhook the blue and red screen cables.
  7. Palm IIIc Teardown: 步骤 7 中的图像 1,3 Palm IIIc Teardown: 步骤 7 中的图像 2,3 Palm IIIc Teardown: 步骤 7 中的图像 3,3
    • Pop out the other two brown plastic clamps to release the screen and buttons.
  8. Palm IIIc Teardown: 步骤 8 中的图像 1,1
    • The black clips on the edges of the device (see picture) must be unclipped to remove the motherboard.
    • Carefully remove the motherboard from the device, pulling the motherboard away from the clips.
  9. Palm IIIc Teardown: 步骤 9 中的图像 1,1
    • Pull the screen out from the front.
  10. Palm IIIc Teardown: 步骤 10 中的图像 1,1
    • The object is now fully disassembled.
Paulina Trujillo
于04/07/11注册
265 声望
创作了8篇指南
团队
Cal Poly, Team 20-69, Walters Spring 2011 Cal Poly, Team 20-69, Walters Spring 2011 的会员
CPSU-WALTERS-S11S20G69
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 4,900
