跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的PSP 300x,请使用我们的维修手册
  1. PSP 300x Teardown, PSP 300x Teardown: 步骤 1 中的图像 1,2 PSP 300x Teardown, PSP 300x Teardown: 步骤 1 中的图像 2,2
    • The first picture is a view of the front of the PSP-3000. The second picture is of the back.
  2. PSP 300x Teardown: 步骤 2 中的图像 1,2 PSP 300x Teardown: 步骤 2 中的图像 2,2
    • Lift the covering from the left side on the back of the PSP to reveal the battery.
    • Pull up on the top at the top of the battery with your fingernail and remove it.
  3. PSP 300x Teardown: 步骤 3 中的图像 1,3 PSP 300x Teardown: 步骤 3 中的图像 2,3 PSP 300x Teardown: 步骤 3 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger Set
    $7.99
    购买
    • Using a spudger or fingernail (spudger set available at iFixit) Metal Spudger Set peel back the warranty sticker that was behind the battery.
    • Using a Phillips #0 screwdriver (screwdriver available at iFixit http://www.ifixit.com/Tools#0-Phillips), Unscrew all four screws from the back of the PSP.
    • Two from behind the battery.
    • And two on the right side of the PSP.
  4. PSP 300x Teardown: 步骤 4 中的图像 1,2 PSP 300x Teardown: 步骤 4 中的图像 2,2
    • Unscrew two screws from the top of the PSP.
    • Turn the PSP around, and unscrew a single screw from the bottom edge.
  5. PSP 300x Teardown: 步骤 5 中的图像 1,2 PSP 300x Teardown: 步骤 5 中的图像 2,2
    • Starting from the 'R' trigger, slide the spudger in between the outer casing the the PSP, and gently pry off the casing.
    • Remove the outer casing completely.
  6. PSP 300x Teardown: 步骤 6 中的图像 1,3 PSP 300x Teardown: 步骤 6 中的图像 2,3 PSP 300x Teardown: 步骤 6 中的图像 3,3
    • Push the homebar to the right to release the tab on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    • Slowly begin to lift the LCD screen off the PSP from the top edge.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
  7. PSP 300x Teardown: 步骤 7 中的图像 1,3 PSP 300x Teardown: 步骤 7 中的图像 2,3 PSP 300x Teardown: 步骤 7 中的图像 3,3
    • Using a spudger or fingernail, flip the small brown locks on the four ribbon cable connectors up.
    • WARNING! Be carefull removing the small ribbion from the LCD connector, it is very delicate. Using a spudger lift the black plastic up, NOT the white part on the connector!
    • Pull all four ribbon cables out, and remove the LCD screen and homebar from the PSP.
  8. PSP 300x Teardown: 步骤 8 中的图像 1,3 PSP 300x Teardown: 步骤 8 中的图像 2,3 PSP 300x Teardown: 步骤 8 中的图像 3,3
    • Remove the small metal bar from the top edge of the PSP. (This was helping to hold the LCD screen in place)
    • Remove the button pad from the PSP.
  9. PSP 300x Teardown: 步骤 9 中的图像 1,3 PSP 300x Teardown: 步骤 9 中的图像 2,3 PSP 300x Teardown: 步骤 9 中的图像 3,3
    • Unscrew the the screw securing 'L' trigger.
    • Remove the white plastic piece that holds the 'L' trigger in place.
    • Remove the 'L' trigger from the PSP.
  10. PSP 300x Teardown: 步骤 10 中的图像 1,3 PSP 300x Teardown: 步骤 10 中的图像 2,3 PSP 300x Teardown: 步骤 10 中的图像 3,3
    • Unscrew the 'R' trigger and remove both pieces. (Refer to step nine by applying the procedures to this, the right, side)
  11. PSP 300x Teardown: 步骤 11 中的图像 1,2 PSP 300x Teardown: 步骤 11 中的图像 2,2
    • Remove the screw from the bottom left edge.
    • Being careful not to break the ribbon cable, use the spudger, to carefully peel the adhesive button from below the 'L' trigger.
  12. PSP 300x Teardown: 步骤 12 中的图像 1,3 PSP 300x Teardown: 步骤 12 中的图像 2,3 PSP 300x Teardown: 步骤 12 中的图像 3,3
    • Using the spudger or fingernail, flip up the brown lock on the ribbon cable.
    • Remove the cable from the connector and remove the entire black piece from the PSP.
    • Remove the screw from the analog stick.
  13. PSP 300x Teardown: 步骤 13 中的图像 1,3 PSP 300x Teardown: 步骤 13 中的图像 2,3 PSP 300x Teardown: 步骤 13 中的图像 3,3
    • Unlock and remove the ribbon cable connection the analog stick to the main board.
    • Remove the analog stick from the PSP.
  14. PSP 300x Teardown: 步骤 14 中的图像 1,3 PSP 300x Teardown: 步骤 14 中的图像 2,3 PSP 300x Teardown: 步骤 14 中的图像 3,3
    • Unlock and remove the ribbon cable from the power switch on the right side of the PSP.
    • Unscrew and remove the screw from the yellow power jack.
    • Carefully bend back the black tab holding the power jack in place and start pulling the plug up to release it from this clip.
  15. PSP 300x Teardown: 步骤 15 中的图像 1,1
    • Pull the plug connecting the power jack to the motherboard.
    • Remove the power jack.
    my power jack on psp 3004 seems to be rigidly stuck to that tiny white socket for it
    it came off the motherboard together with the power jack
    i used too much force because i was frustrated about doing the same thing for about 30 minutes
    is it repairable, replaceable?
    JOSHUA - 回复
  16. PSP 300x Teardown: 步骤 16 中的图像 1,2 PSP 300x Teardown: 步骤 16 中的图像 2,2
    • Push the black tab at the bottom of the speaker over.
    • The speaker should pop out of place, and you should be able to remove it easily.
  17. PSP 300x Teardown: 步骤 17 中的图像 1,3 PSP 300x Teardown: 步骤 17 中的图像 2,3 PSP 300x Teardown: 步骤 17 中的图像 3,3
    • Pull the wireless antenna cable from its plug.
    • Unlock and remove both ribbon cables from the mother board.
  18. PSP 300x Teardown: 步骤 18 中的图像 1,2 PSP 300x Teardown: 步骤 18 中的图像 2,2
    • Remove the screw from the power switch board.
    • Remove the power switch assembly/board.
  19. PSP 300x Teardown: 步骤 19 中的图像 1,2 PSP 300x Teardown: 步骤 19 中的图像 2,2
    • Unlock and remove one last ribbon cable from the bottom edge of the PSP.
    • Remove the screw from the bottom left corner of the PSP.
    you need to caerfully unplug the big orrange ribbon cable. push the little black parts from the white part appart and caerfully unplug the cable
    Václav Vyhnálek - 回复
  20. PSP 300x Teardown: 步骤 20 中的图像 1,2 PSP 300x Teardown: 步骤 20 中的图像 2,2
    • Lift the silver rim on the right side of the PSP up and off.
    • Lift the silver rim on the left side of the PSP up and off.
  21. PSP 300x Teardown: 步骤 21 中的图像 1,3 PSP 300x Teardown: 步骤 21 中的图像 2,3 PSP 300x Teardown: 步骤 21 中的图像 3,3
    • Lift the motherboard up slowly starting from the bottom of the PSP, being careful not to damage the port on top.
    • Pull the motherboard out and remove it from the PSP.
    • The specific motherboard model of this PSP-3000 is TA-090
  22. PSP 300x Teardown: 步骤 22 中的图像 1,2 PSP 300x Teardown: 步骤 22 中的图像 2,2
    • On the top of the back of the PSP, pull the white plastic piece out.
    • Pull the spring out and remove it from the PSP.
  23. PSP 300x Teardown: 步骤 23 中的图像 1,3 PSP 300x Teardown: 步骤 23 中的图像 2,3 PSP 300x Teardown: 步骤 23 中的图像 3,3
    • Open the UMD (disk drive) and locate the two small black rubber squares wedged in the space between the casing and the metal drive hinge on either side.
    • Pull these out using a pair of tweezers.
  24. PSP 300x Teardown: 步骤 24 中的图像 1,2 PSP 300x Teardown: 步骤 24 中的图像 2,2
    • Remove the metal piece from the drive.
    • Grabbing the PSP with both hands, gently pinch the UMD lid towards the right side (the side without the battery).
    • Pull up and the the left side carefully to remove the lid from the PSP. (The casing may have to flex a little bit to allow this)
  25. PSP 300x Teardown: 步骤 25 中的图像 1,2 PSP 300x Teardown: 步骤 25 中的图像 2,2
    • Remove the four screw from the UMD drive.
    • Remove the drive.
  26. PSP 300x Teardown: 步骤 26 中的图像 1,3 PSP 300x Teardown: 步骤 26 中的图像 2,3 PSP 300x Teardown: 步骤 26 中的图像 3,3
    • Enjoy the eye-candy.
    for a change, user submitted teardown with Great quality photos, Awesome!
    mahonen - 回复
    Awesome Job....... I never know that my PSP has a lot of things in it
    Ummayer Rehan - 回复
mbnewsom
于10/28/09注册
3,103 声望
创作了11篇指南
9条评论
Can you get me in pdf
Aayush - 回复
Does a PSP have any bearings inside of it?
Brooke Payne - 回复
No ball bearings. Thumbsticks are probably just Lubed plastics rubbing against eachother
mahonen -
Thank you very much for the guide.
C. JONES - 回复
This has inspired me to build my own PSP. I had one as a child, and want one now for the nostalgia. Thanks!
Sheenyl Hassan - 回复
I was putting a new screen on a psp3001
and the ribbon flex connector broke and now there’s nothing to hold the small ribbon in place
how do I fix this
C mattingly - 回复
JOSHUA - 回复
Trying to figure out the size screw to fit the holes on either side of the USB port. Anyone know? I believe the tv tuner addon used it to mount to the psp, but I plan to use it to mount something externally for a battery mod.
Iguana Bob - 回复
Thanks for making this guide! It will serve me well on my quest to refurbish my PSP 3001. Not only do I want to clean the grime from all the years I have used it, but I also need to clean the electronics inside it, as they have suffered liquid damage close to the UMD drive. Thanks so much again!
-RG
Rando_GUY - 回复
添加评论
浏览统计数据:
过去 24 小时: 21
过去 7 天: 203
过去 30 天: 892
总计 88,379
