跳转到主内容
本篇指南是分解流程而非维修指南。 如果您要维修您的DualSense,应参考我们的维修指南
  1. PS5 Controller Trigger Teardown, PS5 Controller Trigger Teardown: 步骤 1 中的图像 1,1
    • Once you have opened your controller to this point remove those 4 screws to separate the middle frame from the outer frame.
  2. PS5 Controller Trigger Teardown: 步骤 2 中的图像 1,1
    • Once you have separated the middle frame from the outer remove the 2 screws securing the trigger assembly to the middle frame. Remove the opposite 2 if you are changing parts on the other side.
  3. PS5 Controller Trigger Teardown: 步骤 3 中的图像 1,1
    • The trigger assembly comes out easy now.
  4. PS5 Controller Trigger Teardown: 步骤 4 中的图像 1,2 PS5 Controller Trigger Teardown: 步骤 4 中的图像 2,2
    • Remove these 3 screws on this side of the trigger assembly and one more hidden behind the ribbon cable on the other side.
  5. PS5 Controller Trigger Teardown: 步骤 5 中的图像 1,2 PS5 Controller Trigger Teardown: 步骤 5 中的图像 2,2
    • Your trigger assembly is now open. Gently remove the plastic piece to reveal more of the metal pin. Refer to second pic. Pull the metal pin holding the trigger out using a pliers and this will free up the assembly for the button film replacement.
  6. PS5 Controller Trigger Teardown: 步骤 6 中的图像 1,1
    • The metal pin is now out and the trigger is free.
  7. PS5 Controller Trigger Teardown: 步骤 7 中的图像 1,1
    • Remove the button conductive rubber and now replace the button film.
  8. PS5 Controller Trigger Teardown: 步骤 8 中的图像 1,1
    • For reassembly reverse the order. Congratulations. You have successfully replaced your R1, R2 or L1, L2 button film.
vickyjean1007
于03/28/22注册
181 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 55
过去 7 天: 242
过去 30 天: 740
总计 8,665
