跳转到主内容
视频概述
本篇指南是分解流程而非维修指南。 如果您要维修您的Oura Ring 2,应参考我们的维修指南
  1. Oura Ring 2 Teardown, Oura Ring 2 Teardown: 步骤 1 中的图像 1,2 Oura Ring 2 Teardown, Oura Ring 2 Teardown: 步骤 1 中的图像 2,2
    • This is primarily a video teardown, but intrepid iFixit community members have also submitted their own analyses. One reader in particular spent hours attempting to reverse engineer the Oura Ring 2 through the video, datasheets, and X-rays, and shared the following:
    • The two IR LED drivers should be the same type, one for each IR LED.
    • There's likely an operational amplifier for signal conditioning for the photo diode before the signal is sent to the microcontroller. (This is commonly done with these type of photo diode based health meters.)
    • If this is not a microcontroller, it could be a temperature sensor (not a thermistor).
    • A wireless charging IC, predicted based on its surrounding components and location.
    • And finally, a battery fuel gauge IC for probably determining battery health.
    • Based on all this, the second image shows the predicted block diagram.
9指南评论
Wow, I didn’t even know smart rings existed. I also think that it’d be much easier to service if the titanium shell came off in two halves so nothing would have to be bent to service the electronics.
Ethan Z - 回复
Check out this review of the Oura Ring for a good overview - https://youtu.be/56RPyoNSrYY
jtisdale -
Is it possible for you to share SMD Markings on all the devices?
surya mishra - 回复
same request
Marsh Cai -
Yes, contact plawat at slimiot dot com
penta track -
添加评论
浏览统计数据:
过去 24 小时: 19
过去 7 天: 155
过去 30 天: 586
总计 48,350
