跳转到主内容
视频概述
这个拆解是不是维修指南。 要维修你的的Oura Ring 2,请使用我们的维修手册
  1. Oura Ring 2 Teardown, Oura Ring 2 Teardown: 步骤 1 中的图像 1,2 Oura Ring 2 Teardown, Oura Ring 2 Teardown: 步骤 1 中的图像 2,2
    • This is primarily a video teardown, but intrepid iFixit community members have also submitted their own analyses. One reader in particular spent hours attempting to reverse engineer the Oura Ring 2 through the video, datasheets, and X-rays, and shared the following:
    • The two IR LED drivers should be the same type, one for each IR LED.
    • There's likely an operational amplifier for signal conditioning for the photo diode before the signal is sent to the microcontroller. (This is commonly done with these type of photo diode based health meters.)
    • If this is not a microcontroller, it could be a temperature sensor (not a thermistor).
    • A wireless charging IC, predicted based on its surrounding components and location.
    • And finally, a battery fuel gauge IC for probably determining battery health.
    • Based on all this, the second image shows the predicted block diagram.
3条评论
Wow, I didn’t even know smart rings existed. I also think that it’d be much easier to service if the titanium shell came off in two halves so nothing would have to be bent to service the electronics.
Ethan Zuo - 回复
Check out this review of the Oura Ring for a good overview - https://youtu.be/56RPyoNSrYY
jtisdale -
Is it possible for you to share SMD Markings on all the devices?
surya mishra - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 84
过去 30 天: 514
总计 34,803
