跳转到主内容
  1. Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
    • Unscrew 8 side screws (flat 2.4mm or dedicated torx), then of the 4 rear screws (hex 1.5mm).
  2. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector. Remove the front of the phone, disconnecting the LED connector.
    • Remove the front of the phone, disconnecting the LED connector.
  3. iPhone 电池维修工具包
    只要 $29.99
    Buy Now
    iPhone 电池维修工具包
    只要 $29.99
    Buy Now
  4. Remove the 5 screws (Phillips #0) on the black support.
    • Remove the 5 screws (Phillips #0) on the black support.
    • Remove the black support.
  5. remove the 3 screws (Phillips #0) supporting the PCB.
    • remove the 3 screws (Phillips #0) supporting the PCB.
    • Disconnect the antenna on the right.
    • Disconnect the ZIF connector on the left.
    • Disconnect the ZIF connector at the top.
    • Disconnect the two connectors (battery) at the bottom.
  6. Withdraw the jammed SIM card. Withdraw the jammed SIM card.
    • Withdraw the jammed SIM card.
结论
特别感谢这些译者︰
100%
这些翻译人员帮助我们修复这个世界! 想要作出贡献?
开始翻译 ›
Steve Muller
于2018年05月14日注册
178 信誉积分
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 4
过去的30天: 20
总计 151
