跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的OnePlus 7 Pro,请使用我们的维修手册
    最后的想法
    • The battery can be removed first, once you open the phone. It’s only lightly adhered and comes with a pull tab for easy removal.
    • Many components are modular and can be individually replaced.
    • Display replacements, which are the most common repairs, are not prioritized in the design. (You have to completely disassemble the phone to swap out your screen.)
    • While the Front Facing Camera’s new pop up ability is really cool, the added mechanical element makes it more likely to wear out and more complicated to replace.
    • The primary access point for all repairs, the rear panel, is firmly glued in place.
    可修复性评分
    4
    可修复性10分中得4分
    (10是最容易修复)
6条评论
What is the best way to get rid of slider?
Can it be cut from outside w/o unglue back cover?
Bob Monkas - 回复
Slider? Do you mean the pop up camera? If so, removing it is major surgery, cannot be done from the outside.
Forge -
Can I replace the 256 memory module? Need to salvage some things on it.
vishal.shah.tx - 回复
OnePlus 7 pro 8/256
Anita Jajoriya -
do i need to remove the pop up camera if i want to change the screen?
romain.collet - 回复
添加评论
浏览统计数据:
过去 24 小时: 11
过去 7 天: 65
过去 30 天: 340
总计 69,418
