简介
We've had our eyes on Oculus since the beginning, having dismantled (and successfully re-mantled) both development versions of their VR headset. But today, we've got the real deal: the final, consumer-ready, OMG-it's-finally-here Oculus Rift. After four long years of development, what changed? What stayed the same? And can we put it down long enough to actually take it apart and find out?
Grab your tools and join us around the teardown table, because the future is now. We're tearing down the Oculus Rift.
Like what you see? Make us your virtual friend on Facebook, Instagram, or Twitter.
你所需要的
视频概述
We've had two prerelease versions on our teardown table, so we're excited to see what tweaks this Rift has in store. Here's the scoop so far:
Two OLED displays with a combined resolution of 2160 x 1200
90 Hz refresh rate
Accelerometer, gyroscope, and magnetometer
360-degree headset tracking via Constellation IR camera
Horizontal field of view greater than 100º
Improving the VR experience means improving the head tracking—and tracking means dots. Lots of dots.
Infrared dots, to be precise; they're generated by tiny LEDs embedded in the headset. You'll never see them during normal use, but our infrared camera sees all—just like the Oculus' tracker, known as "Constellation."
Turn your head around, and you're still being tracked. Unlike its predecessors, the latest Rift has IR LEDs in the front and the back. You can spin in circles and never break immersion—until you trip over the cord.
This is definitely the sleekest Rift yet—lightweight, impressively comfortable, and now with earphones built right in for maximum immersion.
A thick foam frame attempts to minimize the effects of Oculus Face. It's simply attached with clips.
Fewer screws means less weight!
With the frame removed, we can unplug the
spinal cordsingle cable from the head-mounted display. -
The cable management has really seen some impressive evolution across the generations of Rift.
Removing the adjustable earphones couldn't be easier.
An embedded flathead barrel nut secures the speaker arm, and spring contacts connect it to the wires in the headband. Sweet!
We've seen our share of expensive, un-repairable, nigh-impossible-to-disassemble earphones, so this is a welcome surprise.
Especially considering these lil guys are prime damage targets should your headset "fall" to the ground following a rough PvP match.
The frame also contains a small anchor point for the over-the-head strap.
But how to remove it? We're momentarily stumped—until our teardown engineer finds the hidden interior clips that secure the frame. After a few well-placed flicks of the spudger, it's free.
With that, we pop our Kato mask off the Oculus for our first real peep inside!
The DK2 prototype used a single 1080p display panel yanked from Samsung's Galaxy Note 3. But this time, something's different...
Instead of a smartphone display, Oculus has doubled your order! Two displays, mounted right to the lenses, adjustable with this knobby thing!
Until the day the eyePhone drops, this will do.
What's this? Looks like
a face-detectoran ambient light sensor, present to check if you're wearing the Rift, or perhaps to adjust display brightness to account for extra light leaking into the headset.
Lifting off the cowling reveals a couple standard-issue ribbon cables. The extra slack lets the eyepiece assemblies wiggle around and move back and forth to adjust the interpupillary distance, or IPD (that is, the distance between your eyes).
Three more ribbon cables attach the LED control board to the IR LED array, webbed around the inside of the headpiece housing.
Here's the meat of the Oculus!
Leaving the meat for the main course, let's take a peek at the
saladLED array. -
Those fiddly cables connect to a set of three IR LED arrays: Top, Bottom, and Strap heading up the rear.
Each LED is labeled, and D8 through D10 are hanging out near a lone "hidden" microphone. What's that for, we wonder.
The top of the lens assembly hosts the motherboard. And chips!
Toshiba TC358870XBG 4K HDMI to MIPI Dual-DSI Converter
Cypress Semiconductor CYUSB3304 USB 3.0 Hub Controller
STMicroelectronics STM32F072VB ARM Cortex-M0 32-bit RISC Core Microcontroller
Winbond W25Q64FVZPIG 64 Mb Serial Flash Memory
Nordic Semiconductor nRF51822 Bluetooth Smart and 2.4GHz proprietary SoC
CMedia CM119BN USB Audio Controller
Bosch Sensortec BMI055 6-axis Inertial Sensor
Motherboard IC identification, continued:
STMicroelectronics VL53L1X time-of-flight sensor (likely)
STMicroelectronics BALF-NRF01D3 Bluetooth balun
Texas Instruments display power management
ON Semiconductor CAT93C46B 1 Kb serial EEPROM
STMicroelectronics M24C64-F 8 Kb serial EEPROM
Texas Instruments TPS22908 load switch
Ricoh R1202L721A step-up DC-DC converter
Separating the lens assembly reveals the custom, non-Note, larger-than-lens-aperture display!
These OLEDs measure in at 90 mm apiece, for a resulting pixel density of ~456 ppi. In contrast, the display on an iPhone 6s Plus comes in at 401 ppi, while the Galaxy S7 is a cut above at 576 ppi.
So for now at least, individual pixels are still very much visible, or ''indivisual," a technical term that we just made up.
Where prior Oculus Rift kits shipped with interchangeable circular lenses (left), the CV1 uses a single set of non-removable, asymmetric lenses (right).
A closeup of the CV1 lens reveals these concentric rings, a telltale sign of Fresnel lenses. These cleverly manufactured lenses do the same job as the thick, bulging, curved plastic lenses seen in prior Rifts—using thin arrays of concentric prisms that weigh far less.
Bonus round: by varying the size and shape of the concentric prisms, Oculus was able to fine-tune the lens for this specific application, minimizing spherical aberrations (or distortions) that may result from a traditional curved lens. This probably explains the asymmetric shape.
But wait—if Fresnel lenses do away with the bulging curves of traditional lenses, why are these lenses curved?
Turns out, Oculus went a step further down the optical tunnel, and manufactured hybrid Fresnel lenses.
These lenses are made up of concentric prisms of uniform thickness (like any other Fresnel lens). But an extra, sloping layer is added to the back of the lens, creating a shape that mimics a traditional curved lens—and allowing the focus to vary along the vertical axis of the lens.
We interrupt this teardown for a Science Party. Dim the lights, fire up the smoke machine, and bring the laser beams!
So when you put it all together, what does a lens in a VR headset actually do?
For the VR experience to be realistic and not cause great discomfort, you need the optics to do two things: magnify the display so that you can't see the edges (which would kill the immersion), and focus the display at optical infinity.
TL;DR: The Rift's lenses make up for your eyes' and the displays' shortcomings, making you think you're looking at an endless, distant display (instead of a TV screen glued to your face).
What was behind those lenses and dual displays? A super-sleek, spring-loaded, dual rack-and-pinion mechanism for adjusting the spacing between the display + lens assemblies.
The use of dual displays was a major advance between Rift DK2 and the Crescent Bay prototype. By allowing each lens + display assembly to move as a unit, the Rift provides enough adjustment to accommodate the 5th-95th percentile of IPD—while keeping other key optical properties intact.
TL;DR: If you have eyes, you can probably use this. Nice.
Next to come out is the LED driver board, featuring all the labels a teardowner/reassemblist could want...
The aforementioned well-labeled board, complete with over a dozen test points and the essential control hardware.
3x Texas Instruments TLC59401 16-Channel LED Driver with Dot Correction and Grayscale PWM Control
On the reverse, we see a pair of (relatively) large capacitors—probably necessary to smooth the intermittent load of pulsing such a huge array of IR LEDs.
Optics: check. Silicon: check.
Time to go hunting for headband hardware. Plastic opening tool in hand, we pry the FCC labels off in search of LEDs and headphone wiring.
Peeling back a layer of fabric, we find a slick black ribbon cable that wraps around your head to feed the LEDs in the back. Neat!
But wait—what are these mechanical things?
The Oculus Rift CV1 Repairability Score: 7 out of 10 (10 is best):
Cable management is much improved from the development kits, with a sturdy connector for easy removal.
The earpiece speakers are super easily removed thanks to spring connectors.
The face pad is held in with plastic clips and pulls out easily.
Getting inside is difficult, with hidden internal clips securing the dust shield.
Replacing the head strap is impossible without cutting through the fabric on the headset.
Intricate design and delicate ribbon cables makes it very difficult to remove the lenses, displays, and motherboard.
90条评论
best
teardown
ever!
Keep checking in to find out ;)
