你所需要的
Nvidia Shield Normal Controller, without Display, so it's just a controller if you don't have other shield device
Micro-USB 2.0
3.5 mm stereo headphone jack
Charge indicator
Still don't know how this controller connected to PC without cables, the controller can be connected to a Nvidia Shield through WiFi but no idea if this works with pc.
Remove two cable for the vibration motors and one cable for the battery.
There are 2 Vibration motors
Remove the two screws holding the logic board to the device.
Carefully remove the logic board.
we can found battery part under the motherboard
Screw*4
LC18650 Lithium-ion Battery: 3.6V/2200mAh/7.92Wh
TLV320AIC3204 (Very Low-Power Stereo Audio CODEC)
Atmel ATXMEGA32A4U-AU (8-bit Microcontroller)
Potentiometers
Microchip SST25WF020A (SPI Flash 2Mbit 1.8V)
Ozmo2000 431-B0 (WiFi Integrated Chip)
ADG3 3088CP (Unknown)
18条评论
Where is the Shield console teardown?
I brought the controller to the hardware store and found that a T6 fit perfect. I bought it and used it, worked fine. I know the description says T7. May be a mistake
Farrid is Correct I have both a T7 and T6 Screwdriver and the T7 IS TOO BIG!, T6 fits perfectly. Just a heads up to anyone who needs to go out and but a Single screwdriver.
drestine -
You are right. It’s T6, not T7.
Looking to replace ribbon cables. Anyone know where i can buy them?
