To access the battery you must remove the back cover. Press the tab on the bottom of the cover in so that the back cover plate can slide over it.
Now slide the back cover off of the phone.
Remove the four screws securing the front cover to the rest of the phone using a T7 screwdriver.
Once the front cover has been removed, there is nothing holding the keyboard to the rest of the phone. Simply remove the keyboard from the cover by lifting the keyboard from its interior side.
After casing and keyboard have been taken off, remove the screws holding the screen in place using a T-6 for the screws in the middle of the red circles and a T-5 for the screw in the middle of the red square.
Lift ribbon off of the contact with the logic board
*When reassembling, make sure to firmly press contacts into place to ensure a connection is made between ribbon and logic board
Once the screws are out, gently pull the screen off of the phone. *NOTICE* The sticker that attaches the display (in the middle of the blue square again) and the logic board is to be removed safely and be sure not to rip this apart.
Finally, pull the silver case off to completely free the cracked or damaged screen.
Remove the speaker by pulling it off of the display frame.
The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
Finally, after the screen and keyboard have been taken off, there is nothing securing the logic board to the rest of the phone. Simply pull the green logic board from the back casing.
Once free from the back of the phone, the logic board can be replaced by a new one.
After the logic board has been removed, there is nothing else securing the antenna to the back cover. Simply remove the antenna by pushing outward from the interior side.
The volume control buttons are secured to the frame only by their fit around a small piece of the plastic. Using a small flat-head screwdriver or other flat object, lift the ribbon over this piece of the cover.
With the back panel, you will slowly take the Connector Housing by first pushing and sliding it off the back panel.
*Notice* Be very careful not to lose the small loose spring from behind the button or the small buttton itself. So do this step slowly.
After the Connector Housing has been removed, there is nothing else holding the Microphone in place. Simply remove if from the housing by pulling up.
After the Connector Housing has been removed, there is nothing else holding the Headset Jack in place. Simply remove if from the housing by pulling up.
EDIT: The connection socket shown in the red square is actually the POWER IN socket.
