简介
What you will need:
T6 Screwdriver
Your favorite spudger ( I chose the iSesamo)
This phone is easy and almost impossible to brake. So put any fear you have away and lets crack it open.
你所需要的
Take the back cover off and remove the battery. (Not shown)
Remove the two screws located with red circles
The lcd screen is held in by a steel bracket. This bracket is held in place by the clips marked with red squares. The easit way to release it is by levering the one on the right (as pictured) and the bracket should come off.
When re-assembling make sure the studs marked with blue circles line up properly.
Using a spudger disconnect the LCD cable.
