拆解
In this tutorial, I will show you how to disassemble the Nokia 3210.
这个拆解是不是维修指南。 要维修你的的Nokia 3210,请使用我们的维修手册。
Remove Battery cover, battery and SIM Card.
Remove the antenna with your fingers.
Remove these screws. These are Torx T6. You'll need this screwdriver to remove them.
If you remove the plate, you can see the Motherboard. Remove the Motherboard with a small flathead screwdriver or a spudger. (A spudger is recommended).
Here's the PCB with removed EMI shields.
CCONT NMP70467 Power Management IC
NMP0581 Power Supply IC
BGY252 and BGY 262 UHF Amplifier
Other side of the PCB.
Hitachi HWYN202A 900MHz Duplexer
Intel F160B3TA Flash
Atmel 24C128 EPROM
Samsung KM68U1000 SRAM
Buzzer MZT-03C
Texas Instruments MAD2PRI Microcontroller (ARM Based)
Disassembly Completed!
与1其他贡献者
于10/27/12注册
707 声望
创作了5篇指南
徽章: 3
yaaaaas queeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeen
Gaubrisco - 2017年12月18日 回复
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 32
总计 6,312
