简介
In this tutorial, I will show you how to disassemble the Nokia 3210.
这个拆解是不是维修指南。 要维修你的的Nokia 3210,请使用我们的维修手册
  1. Remove Battery cover, battery and SIM Card.
    • Remove Battery cover, battery and SIM Card.
  2. Remove the antenna with your fingers.
    • Remove the antenna with your fingers.
    • Remove these screws. These are Torx T6. You'll need this screwdriver to remove them.
    • If you remove the plate, you can see the Motherboard. Remove the Motherboard with a small flathead screwdriver or a spudger. (A spudger is recommended).
    • Here's the PCB with removed EMI shields.
    • CCONT NMP70467 Power Management IC
    • NMP0581 Power Supply IC
    • BGY252 and BGY 262 UHF Amplifier
    • Other side of the PCB.
    • Hitachi HWYN202A 900MHz Duplexer
    • Intel F160B3TA Flash
    • Atmel 24C128 EPROM
    • Samsung KM68U1000 SRAM
    • Buzzer MZT-03C
    • Texas Instruments MAD2PRI Microcontroller (ARM Based)
    • Disassembly Completed!
Bryan
于2012年10月27日注册
690 信誉积分
创作了5篇指南
yaaaaas queeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeen
Gaubrisco - 回复
浏览统计数据:
过去的24小时: 1
过去的7天: 3
过去的30天: 22
总计 4,618
