简介
Explanatory Guide of how to teardown a Nintendo GameCube.
这个拆解是不是维修指南。 要维修你的的Nintendo GameCube,请使用我们的服务手册
Flip unit over and locate the four screws shown in the second photograph. Remove four corner screws located on the underbelly of the unit using the Nintendo Gamecube bit tool.
  • Flip unit over and locate the four screws shown in the second photograph.
  • Remove four corner screws located on the underbelly of the unit using the Nintendo Gamecube bit tool.
添加评论
Pull bottom half of unit away from top outer casing. Pull bottom half of unit away from top outer casing. Pull bottom half of unit away from top outer casing.
  • Pull bottom half of unit away from top outer casing.
添加评论
Depress clips and remove back panel as shown.
  • Depress clips and remove back panel as shown.
添加评论
Carefully unclip controller ports in the front of the unit.
  • Carefully unclip controller ports in the front of the unit.
  • Ribbon Cable (in yellow) is still attached to the unit. Do not try to disconnect this cable.
添加评论
Unscrew the two screws holding the fan assembly onto the unit using a Philips #2 screwdriver as shown. Carefully remove the red and black wiring assembly from the fan unit by gently pulling the fan connector away from the fan as shown.
  • Unscrew the two screws holding the fan assembly onto the unit using a Philips #2 screwdriver as shown.
  • Carefully remove the red and black wiring assembly from the fan unit by gently pulling the fan connector away from the fan as shown.
添加评论
Remove four screws using a Philips #1 screwdriver as shown. Carefully remove metal plates as shown in second photograph
  • Remove four screws using a Philips #1 screwdriver as shown.
  • Carefully remove metal plates as shown in second photograph
添加评论
Mac RAM 套件
加速你的Mac。充分利用它的内存。
Mac RAM 套件
从Mac中清理出更多内存。
Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver. Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver. Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver.
  • Starting with the three screws located under the fan assembly, unscrew a total of twelve screws on the outer edge of the unit using a Phillips #2 screwdriver.
添加评论
Carefully lift drive assembly off of the base. Carefully lift drive assembly off of the base. Carefully lift drive assembly off of the base.
  • Carefully lift drive assembly off of the base.
添加评论
Flip drive assembly over and remove 8 screws as shown. Remove metal plate, careful to not disturb the brown wire (shown in yellow)
  • Flip drive assembly over and remove 8 screws as shown.
  • Remove metal plate, careful to not disturb the brown wire (shown in yellow)
There's actually only 6 screws to remove-- two of the circled objects are placement pegs.
Kevin K - 回复
Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown. Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown.
  • Gently slide out black clip holding the brown ribbon in place. Then slide out brown ribbon as shown.
添加评论
Carefully remove blue wire Remove four screws with a #1 Phillips Screwdriver Remove four screws with a #1 Phillips Screwdriver
  • Carefully remove blue wire
  • Remove four screws with a #1 Phillips Screwdriver
添加评论
Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes) Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes) Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes)
  • Flip out circuit board as shown, being careful not to sever the red wire or the white ribbon cable (shown in yellow boxes)
添加评论
Using a flat-head screwdriver or other long flat object, carefully release the four plastic clips holding the drive assembly together. The last clip can be rather hard to find.  Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue). The last clip can be rather hard to find.  Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue).
  • Using a flat-head screwdriver or other long flat object, carefully release the four plastic clips holding the drive assembly together.
  • The last clip can be rather hard to find. Use a screwdriver as shown in the third image to get behind the plastic to release the last clip (in blue).
添加评论
Lift metal plate off of drive assembly, again being careful not to sever the two wires still attached to the two halves of the drive assembly. Next, flip and rotate the drive assembly so that it resembles the one in the third picture. Next, flip and rotate the drive assembly so that it resembles the one in the third picture.
  • Lift metal plate off of drive assembly, again being careful not to sever the two wires still attached to the two halves of the drive assembly.
  • Next, flip and rotate the drive assembly so that it resembles the one in the third picture.
添加评论
Using the screwdriver, release two more clips around the back half of the drive assembly. The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half. The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half.
  • Using the screwdriver, release two more clips around the back half of the drive assembly.
  • The last clip doesn't need to be released, the top half of the drive assembly will slide away from the lower half.
添加评论
Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering). Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering).
  • Finish removing the top half of the drive assembly, be careful as this piece is where the two wires that should not be removed are attached to (unless you want to do some soldering).
添加评论
Remove three final screws near the bars of the lens assembly.  Once this is done the lens assembly can be removed. Remove three final screws near the bars of the lens assembly.  Once this is done the lens assembly can be removed.
  • Remove three final screws near the bars of the lens assembly. Once this is done the lens assembly can be removed.
添加评论
Shown in the first picture is the lens assembly.  In the second, the drive assembly without the lens assembly. Congratulations, you're done!
  • Shown in the first picture is the lens assembly. In the second, the drive assembly without the lens assembly.
  • Congratulations, you're done!
添加评论
agronbac
于2009年10月28日注册
603 信誉积分
创作了2篇指南
团队
Cal Poly, Team 6-2, Maness Fall 2009 Cal Poly, Team 6-2, Maness Fall 2009 的会员
CPSU-MANESS-F09S6G2
4 名成员
创作了9篇指南
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 27
过去的30天: 104
总计 21,204
