跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Nintendo GameCube Controller,请使用我们的维修手册
  1. Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 步骤 1 中的图像 1,2 Nintendo GameCube Controller Teardown, Separating the Separate Halves:: 步骤 1 中的图像 2,2
    • Remove the six phillips head screws from the underside of the controller.
    • After these screws are removed, you can separate the bottom from the top of the controller.
  2. Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 步骤 2 中的图像 1,2 Nintendo GameCube Controller Teardown, Removing the Control Panel and Buttons:: 步骤 2 中的图像 2,2
    • After removing the back of the controller, you can lift the circuit board out of the plastic shell.
    • With the circuit board removed, you can access the main buttons and remove them if desired.
  3. Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 步骤 3 中的图像 1,2 Nintendo GameCube Controller Teardown, Removing the Remotes Bumpers:: 步骤 3 中的图像 2,2
    • To remove the left and right bumpers from the bottom of the controller, pull up on the square base that keeps the button in place and then pull the button through the shell.
  4. Nintendo GameCube Controller Teardown, Pieces of the Controller:: 步骤 4 中的图像 1,1
    • These are the parts that should come out of the remote; not regarding the control panel.
  5. Nintendo GameCube Controller Teardown, Removing the C-Stick:: 步骤 5 中的图像 1,2 Nintendo GameCube Controller Teardown, Removing the C-Stick:: 步骤 5 中的图像 2,2
    • Once the control panel is removed from the controller the c-stick can be easily, but carefully, removed.
Pete Moreno
于06/02/15注册
154 声望
撰写一个指南
5条评论
So uh... This isn't an official GameCube controller. The official ones have Nintendo branding above the start button as well as a differently colored mainboard and tri-wing screws instead of Phillips. There are other slight differences in some components too. Do you mind someone else redoing this teardown with an official controller?
sigoshi - 回复
That would be awesome! Please do! =)
Sam Goldheart -
i will gladly do so in the next few weeks
ZeldaAwesome -
so is this with the official controllers now or has it still not been updated yet?
thanhan287 - 回复
This is pretty close to the official controller. I’ve submitted a separate guide for the official controller teardown.
Skeletwing -
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 29
过去 30 天: 86
总计 16,272
