跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Nintendo 64,请使用我们的维修手册
  1. Nintendo 64 Teardown, Nintendo 64 Overview: 步骤 1 中的图像 1,1
    • The Nintendo 64 was Nintendo's third home console. Released in 1996 for the US and Japan, the N64 boasted 64-bit graphics for the most realistic gaming experience ever made to date. The N64 was co-developed by Nintendo and Silicon Graphics.
    • NEC VR4300 64-bit CPU, running at 93.75 Mhz
    • Silicon Graphics Reality Coprocessor (RCP) GPU
    • 576i (720×576) Composite output
    • Support for up to 4 players
  2. Nintendo 64 Teardown: 步骤 2 中的图像 1,3 Nintendo 64 Teardown: 步骤 2 中的图像 2,3 Nintendo 64 Teardown: 步骤 2 中的图像 3,3
    • Let's take a look at the I/O, shall we?
    • 4 N64 controller ports
    • Nintendo 64 Game Pak slot
    • Composite video cable port
    • N64 power supply port (12V/3.3V DC switching)
  3. Nintendo 64 Teardown: 步骤 3 中的图像 1,3 Nintendo 64 Teardown: 步骤 3 中的图像 2,3 Nintendo 64 Teardown: 步骤 3 中的图像 3,3
    • Let's begin by removing the top cover.
    • Remove the 6 Gamebit 4.5mm screws found at the 4 corners and near the top-middle and bottom-middle.
    • Using a metal spudger, take out the Jumper Pak from its slot and set it aside.
  4. Nintendo 64 Teardown: 步骤 4 中的图像 1,3 Nintendo 64 Teardown: 步骤 4 中的图像 2,3 Nintendo 64 Teardown: 步骤 4 中的图像 3,3
    • Flip the console upright, and the top cover just comes right off.
    • Remove the 10 crossbar screws using a Philips #2 screwdriver.
    • Take out the 2 screws holding in one piece of the expansion slot shield, also with a Philips #2
    • The 2 black screws and the one at the bottom left of the expansion slot shield are easily removed with a Philips #2.
    • Finally, remove the 2 long screws from the 2 ends of the slot with a Philips #0.
  5. Nintendo 64 Teardown: 步骤 5 中的图像 1,3 Nintendo 64 Teardown: 步骤 5 中的图像 2,3 Nintendo 64 Teardown: 步骤 5 中的图像 3,3
    • Remove the 3 pieces of the expansion slot shield.
    • Make sure to remove these pieces BEFORE removing the heatsink crossbar.
  6. Nintendo 64 Teardown: 步骤 6 中的图像 1,3 Nintendo 64 Teardown: 步骤 6 中的图像 2,3 Nintendo 64 Teardown: 步骤 6 中的图像 3,3
    • The heatsink crossbar comes right off, which gives us access to the motherboard shield.
    • The 5 screws on the two sides of the shield are swiftly removed with a Philips #2
    • The 2 screws on each side of the Game Pak slot are quite long, and are removed with a Philips #2.
    • With that, the shield slips right off, letting us gaze at the Nintendo 64's source of power.
  7. Nintendo 64 Teardown: 步骤 7 中的图像 1,2 Nintendo 64 Teardown: 步骤 7 中的图像 2,2
    • On the motherboard are 3 very pronounced steel blocks, which indicates that the important stuff is under there. But before removing these, it's best to take the motherboard out of the bottom case.
    • In order to remove the motherboard, unscrew the 4 Philips #2 screws from the two back I/O ports, allowing extraction of the motherboard.
  8. Nintendo 64 Teardown: 步骤 8 中的图像 1,2 Nintendo 64 Teardown: 步骤 8 中的图像 2,2
    • Using a Jimmy, pry off each chip's heatsink, revealing the console's processing units.
    • Nintendo CPU-NUS-A
    • Nintendo RCP-NUS
    • Nintendo RDRAM18-NUS-B (2x2MB modules)
  9. Nintendo 64 Teardown: 步骤 9 中的图像 1,1
    • And thus concludes a successful teardown of one of the greatest consoles of all time.
Christian Marmolejos
于11/21/16注册
351 声望
撰写一个指南
4条评论
Thank you, this tear down was real helpful. I was able to open up an N64 and clean the corrosion between some pins that kept it from turning on. :D
Nocturnal 007 - 回复
I’m really glad to hear that! The N64 has always had a special place in my heart since it was the first home console I ever had.
Christian Marmolejos -
dang one in the same Christian same first console my second was the PlayStation 1(actually just called PlayStation) and the PlayStation 2 my third the Nintendo GameCube then handheld consoles the game boy, game boy advanced, and Nintendo 2dsi , and the Nintendo 3-DS, and then fourth the non-handheld online consoles the Wii and the Xbox 360.
nathanrust123 - 回复
This in my opinion was one of the best consoles. The Zelda games for the 64 were amazing. Love the idea I can fix mine.
Joshua Graham - 回复
添加评论
浏览统计数据:
过去 24 小时: 18
过去 7 天: 179
过去 30 天: 651
总计 43,827
