拆解
这个拆解是不是维修指南。 要维修你的的Nikko La Nera Junior,请使用我们的维修手册。
The Car, the Remote Control and a Phillips screwdriver.
Let's start!
Remove this screw.
The rear wing
Unscrew this black screws
Remove the wing
The Exhausts
Remove these screws
Remove the exhausts
The Rear Cover
The "tubolar" body
Flip the car
Remove these screws.
Remove the body
The seat
Remove these screws (one of these is back of the seat)
Remove the seat.
The antenna
Remove this screw
Raise the circuit board
Remove the antenna
The "engine"
Remove the gears cover
Remove the engine block
Remove the gear and his hinge
Remove this piece of plastic
The Engine!
Remove the wheels from the car
The Steering Mechanism
Remove the cover
Lift the wheels
Remove the steering bar...
...the two screws...
...and the cover.
Remove the first "gear"...
...and the second.
Remove the steering motor
Remove the plastic cover
Be careful!
Remove this piece
Remove the second piece...
...and the spring.
Congratulations! The car is torn down!
Let's tear down the remote!
Remove the screw in the PCB
Remove the screw in the piece of plastic at the end of the antenna
Remove the plastic piece around the beginning of the antenna
Carefully de-route the antenna from the PCB
Detach the two parts of eat key.
Congratulations! You've ended the teardown!
与3其他贡献者
于06/12/11注册
306 声望
创作了2篇指南
徽章: 8
+ 5更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 1,789
