跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Nerf N-Strike Maverick,请使用我们的维修手册
  1. Nerf N-Strike Maverick Teardown, Nerf N-Strike Maverick Teardown: 步骤 1 中的图像 1,1
    • The Redeemer. Looks badass with its rotating barrel, but it's going to get a whole lot more badasserer quite soon...
    • Reminds me of a gun from the Fifth Element.
  2. Nerf N-Strike Maverick Teardown: 步骤 2 中的图像 1,1
    • First thing's first: let's remove some screws. All screws are conveniently Phillips, and all can be removed with a #0 or #00 size screwdriver.
    • Remove all ten Phillips screws.
  3. Nerf N-Strike Maverick Teardown: 步骤 3 中的图像 1,3 Nerf N-Strike Maverick Teardown: 步骤 3 中的图像 2,3 Nerf N-Strike Maverick Teardown: 步骤 3 中的图像 3,3
    • Another Phillips screw hides beneath the cocking mechanism thing. Remove that one as well.
    • The cocking mechanism's quite simple. A metal lever pulls back on the air plunger and compresses the large spring. Another small spring returns the slider back into its original position once it's done doing the dirty business..
  4. Nerf N-Strike Maverick Teardown: 步骤 4 中的图像 1,2 Nerf N-Strike Maverick Teardown: 步骤 4 中的图像 2,2
    • And just like that, the gun comes apart.
    • Visible in the top left corner is the large spring and air plunger.
    • I later opened the gun again and put a folded piece of paper in this area. It gave the gun a bit more "punch" when sending darts on their merry way.
  5. Nerf N-Strike Maverick Teardown: 步骤 5 中的图像 1,1
    • Gun tip. I foresee it being black in the future.
  6. Nerf N-Strike Maverick Teardown: 步骤 6 中的图像 1,2 Nerf N-Strike Maverick Teardown: 步骤 6 中的图像 2,2
    • First comes out the air plunger. It lifts right up.
    • The barrel comes out next.
  7. Nerf N-Strike Maverick Teardown: 步骤 7 中的图像 1,2 Nerf N-Strike Maverick Teardown: 步骤 7 中的图像 2,2
    • The trigger is held in place by a sole Phillips screw. It also has a small spring for that authentic handgun "springy" feeling...
  8. Nerf N-Strike Maverick Teardown: 步骤 8 中的图像 1,3 Nerf N-Strike Maverick Teardown: 步骤 8 中的图像 2,3 Nerf N-Strike Maverick Teardown: 步骤 8 中的图像 3,3
    • The trigger's spring also attaches via a Phillips screw. A couple of twists with the screwdriver and it comes right out.
    • The fancy rotator for the barrel is next. I assume that were the gun to break, this would be the part that fails. It's the most complex part of the gun.
  9. Nerf N-Strike Maverick Teardown: 步骤 9 中的图像 1,1
    • Looking down the gun's business end.
    • I didn't bother to take the barrel apart. I didn't feel that adventurous.
  10. Nerf N-Strike Maverick Teardown: 步骤 10 中的图像 1,1
    • Here it is -- the whole gun taken apart.
    • It's so easy to assemble, a child could do it. Maybe Nerf's motto is "From our kids to your kids"?
    • I sincerely hope Nerf products are manufactured in countries that have strict child labor laws. I in no way, shape, or form condone child labor.
  11. Nerf N-Strike Maverick Teardown: 步骤 11 中的图像 1,2 Nerf N-Strike Maverick Teardown: 步骤 11 中的图像 2,2
    • The finished product.
    • I took the gun to work and shot these pictures under a better lighting/camera setup... A much better lighting/camera setup.
4条评论
%#*@! Some kid stuck a marble down the barrel and I can't get it out. I have taken it apart to the same extent you did but can't get the barrel front or back removed. Any thoughts?
William - 回复
Set the barrel up so it’ll shoot where it’s not obstructed and shoot the kid until he buys you a new gun.
koannweinstein -
@sicra the gun has air restrictors that won’t shoot anything out unless a dart is pushing against it…
so the marble won’t come out by it’s own.
@William take the barrel apart it’s just 3 screws, and then you can remove it.
Phuwanut Pataratawinun - 回复
use a smallish dia. piece of tubing ( i used outer insulation of coax tv cable) and superrglue ( gel) to said marble let it getgooos and set, like an hour and gentlly pull it out
Valden Tharbosen - 回复
添加评论
浏览统计数据:
过去 24 小时: 6
过去 7 天: 15
过去 30 天: 66
总计 85,722
