跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的NeXTstation,请使用我们的维修手册
  1. NeXTstation Teardown, NeXTstation Teardown: 步骤 1 中的图像 1,3 NeXTstation Teardown, NeXTstation Teardown: 步骤 1 中的图像 2,3 NeXTstation Teardown, NeXTstation Teardown: 步骤 1 中的图像 3,3
    • The NeXTStation, this is a great addition to any computer collection.
  2. NeXTstation Teardown: 步骤 2 中的图像 1,3 NeXTstation Teardown: 步骤 2 中的图像 2,3 NeXTstation Teardown: 步骤 2 中的图像 3,3
    • Turn the NeXTStation around, and remove this screw:
    • Then, lift the top cover of the computer. This will reveal the guts.
    • The ports from left to right: SCSI2, Keyboard & Mouse, DSP Port, DB-19(MegaPixel Display), DB-9(Serial), RJ-45(Ethernet), Coaxial (10b2 Ethernet), Power
    • I find notes in everything!
    " Keyboard & Mouse"
    Nope! Those are serial ports. The keyboard plugs into the monitor, and the mouse plugs into the keyboard.
    Also the DB-9 is the printer port, by which the NeXT laser printer was attached. I don't think it could be used for general serial communications. On the other hand, if I recall correctly the DSP port *was* usable for high-speed serial communications.
    jonhendry - 回复
  3. NeXTstation Teardown: 步骤 3 中的图像 1,2 NeXTstation Teardown: 步骤 3 中的图像 2,2
    • Removing the hard drive:
    • The NeXTStation uses a 50-Pin SCSI Hard Drive up to 4GB.
    • Remove all of the cables from the logic board.
    It's incredible how modern this board looks, despite its being so dated.
    tabormeister - 回复
    来自 tabormeister 的话:
    Yep, this was one fast of a workstation back in 90"
    Chris Green - 回复
  4. NeXTstation Teardown: 步骤 4 中的图像 1,3 NeXTstation Teardown: 步骤 4 中的图像 2,3 NeXTstation Teardown: 步骤 4 中的图像 3,3
    • Then remove this screw.
    • Once the screw is removed, pivot the drive up on a 45 Degree angle, then slide it out.
    Wow, it is so easy to take everything out!!! Now there are milions of screws and connectors, turning devices around and so on... I'm amazed of the simplicity!
    jakub004 - 回复
  5. NeXTstation Teardown: 步骤 5 中的图像 1,1
    • The Hard Drive & Caddy
  6. NeXTstation Teardown: 步骤 6 中的图像 1,3 NeXTstation Teardown: 步骤 6 中的图像 2,3 NeXTstation Teardown: 步骤 6 中的图像 3,3
    • Removing the floppy disk drive:
    • The NeXTStation uses a non-standard 2.88MB 3.5" floppy drive, though it uses the standard floppy connector.
    • Remove the floppy cable.
    • Then, remove this screw.
  7. NeXTstation Teardown: 步骤 7 中的图像 1,3 NeXTstation Teardown: 步骤 7 中的图像 2,3 NeXTstation Teardown: 步骤 7 中的图像 3,3
    • Then, just like the hard drive, pivot the drive up 45 degrees, and pull it out.
  8. NeXTstation Teardown: 步骤 8 中的图像 1,3 NeXTstation Teardown: 步骤 8 中的图像 2,3 NeXTstation Teardown: 步骤 8 中的图像 3,3
    • Removing the fan:
    • Remove this connector.
    • Remove these screws.
    • Remove the fan.
  9. NeXTstation Teardown: 步骤 9 中的图像 1,3 NeXTstation Teardown: 步骤 9 中的图像 2,3 NeXTstation Teardown: 步骤 9 中的图像 3,3
    • Removing the logic board:
    • Remove the power supply connector. Just lift it straight up, and it should come free.
    • Remove this screw.
  10. NeXTstation Teardown: 步骤 10 中的图像 1,3 NeXTstation Teardown: 步骤 10 中的图像 2,3 NeXTstation Teardown: 步骤 10 中的图像 3,3
    • Lift the end of the logic board(away from the ports), and slide it away from the ports.
    • Now, set the board aside.
  11. NeXTstation Teardown: 步骤 11 中的图像 1,3 NeXTstation Teardown: 步骤 11 中的图像 2,3 NeXTstation Teardown: 步骤 11 中的图像 3,3
    • Power Supply:
    • Lift the power supply up, and out.
    The power supply is the (only?) weak spot on this beauty! It is always the MOSFETs which burn out. So make sure you use heat sink compound when you re-assemble it!
    If it is broken, maybe this page can help: http://heller.no-ip.org/~heller/NeXT/pow...
    Helmut Heller - 回复
  12. NeXTstation Teardown: 步骤 12 中的图像 1,1
    • The Logic Board Overview:
    • The Board has a 25Mhz Motorola 68040 CPU, This board features a ton of chips for something made nearly 20 years ago.
    • The CPU: Motorola XC68040RC25
    • The Co-Procesor: MB610313
    • Motorola Chips
    • Intel Chips
    • AMD Chips (Intel and AMD In the same computer?)
    • Fujitsu Chips
    I think the MB610313 is a DMA controller ASIC.
    jonhendry - 回复
  13. NeXTstation Teardown: 步骤 13 中的图像 1,3 NeXTstation Teardown: 步骤 13 中的图像 2,3 NeXTstation Teardown: 步骤 13 中的图像 3,3
    • Made in the USA, you don't see this anymore.
    • The Serial #
    • Looks like my NeXTStation came from WilTel.
    • It is model # N1100
Chris Green
于10/11/09注册
36,978 声望
创作了49篇指南
团队
Master Techs Master Techs 的会员
Community
322 名成员
创作了2,535篇指南
3条评论
http://www.youtube.com/watch?v=jhfUKEu7s...
The Machine to Build the Machines:
Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Juddy - 回复
来自 Juddy 的话:
http://www.youtube.com/watch?v=jhfUKEu7s... The Machine to Build the Machines: Watch NeXT's revolutionary computer controlled (NeXT Cubes - no less) assembly line in action!
Amazing!
Chris Green - 回复
MB610313 - ICP (Integrated Channel Processor). Basically DMA on steroids for almost all of the main sub components of the system. I believe that the cube, or at least the 25Mhz 030/040 cubes, had two of these.
HotelCoralEssex - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 23
过去 30 天: 74
总计 30,838
