跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Motorola V3i,请使用我们的维修手册
  1. Motorola V3i Teardown, Motorola V3i Teardown: 步骤 1 中的图像 1,1
    • A Motorola V3i!
    • Let's see what's inside...
  2. Motorola V3i Teardown: 步骤 2 中的图像 1,2 Motorola V3i Teardown: 步骤 2 中的图像 2,2
    • Let's turn it and take out the battery.
    • Remove these two screws.
  3. Motorola V3i Teardown: 步骤 3 中的图像 1,1
    • Now you can easily flip the cover.
  4. Motorola V3i Teardown: 步骤 4 中的图像 1,3 Motorola V3i Teardown: 步骤 4 中的图像 2,3 Motorola V3i Teardown: 步骤 4 中的图像 3,3
    • You need to detach these two plastic lashes from the surounding.
    • Now you can remove this transparent plastic case.
    • Now you can take out the speaker.
    • The metal thing on the end of the picture is the antenna.
  5. Motorola V3i Teardown: 步骤 5 中的图像 1,2 Motorola V3i Teardown: 步骤 5 中的图像 2,2
    • So, that's the board.
    • Vibra motor.
    • Mini USB.
    • Connector for the antenna.
    • After I took these EMI shields away it looks like this...
  6. Motorola V3i Teardown: 步骤 6 中的图像 1,2 Motorola V3i Teardown: 步骤 6 中的图像 2,2
    • Bluetooth chip by Broadcom.
    • 32Mbit PSRAM by STMicroelectronics.
    • Baseband Processor (Main Processor) by Freescale (90nm structure).
    • RF Transmitter by RF Micro Devices.
    • Battery controller by Freescale.
    • Quad-Band Transmit Module by RF Micro Devices.
  7. Motorola V3i Teardown: 步骤 7 中的图像 1,2 Motorola V3i Teardown: 步骤 7 中的图像 2,2
    • Remove these 4 rubbers.
    • Then remove the four torx screws.
    • You can easily lose these rubbers. (That's why I have only 3 of them...)
  8. Motorola V3i Teardown: 步骤 8 中的图像 1,2 Motorola V3i Teardown: 步骤 8 中的图像 2,2
    • Filp the device and you can remove the top housing.
    • Remove the three buttons on the side of the device.
    • Remove the connector to the mainboard...
    • and to the camera.
  9. Motorola V3i Teardown: 步骤 9 中的图像 1,1
    • Remove the camera by lifting it up.
    • That's a 1,3Mpix camera!
  10. Motorola V3i Teardown: 步骤 10 中的图像 1,3 Motorola V3i Teardown: 步骤 10 中的图像 2,3 Motorola V3i Teardown: 步骤 10 中的图像 3,3
    • Lift up the speaker.
    • Then, that's a tricky part,remove all the buttons around the screen housing. Caution: They are really thin and they easily break!
    • After you did this tricky part you can lift the top of the phone away.
  11. Motorola V3i Teardown: 步骤 11 中的图像 1,2 Motorola V3i Teardown: 步骤 11 中的图像 2,2
    • Now lift up the front glass from the top of the device. It's held with adhesives.
    • After you did this it should look like this.
  12. Motorola V3i Teardown: 步骤 12 中的图像 1,2 Motorola V3i Teardown: 步骤 12 中的图像 2,2
    • Around the screen there are some lashes. Detach them to release the screen of the metal housing.
    • Then you can lift the metal housing up.
  13. Motorola V3i Teardown: 步骤 13 中的图像 1,2 Motorola V3i Teardown: 步骤 13 中的图像 2,2
    • The metal housing is very fragile!
    • an ATI Imageon chip! It's a mulitmedia co-processor, it is used for record video and mobile gaming. It support up to a 2Mpix camera.
  14. Motorola V3i Teardown: 步骤 14 中的图像 1,2 Motorola V3i Teardown: 步骤 14 中的图像 2,2
    • Again there's a small lash on the botton of the front screen housing.
    • After that you can remove the front screen with the PCB.
  15. Motorola V3i Teardown: 步骤 15 中的图像 1,1
    • The front screen.
    • Yes, my front screen has some dead pixels. (They are pink?!)
  16. Motorola V3i Teardown: 步骤 16 中的图像 1,1
    • Thank you for reading my Teardown:)
Peddy
于12/28/09注册
159 声望
创作了2篇指南
一条评论
Have an old V3i and the screen has just stopped working - have a feeling it’s become disconnected, is it work tearing it down like this to try fix the problem? Want it still to work after though
Iala - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 18
总计 24,627
