跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Motorola Moto X Force,请使用我们的维修手册
  1. Motorola Moto X Force Teardown, Remove SIM card tray.: 步骤 1 中的图像 1,2 Motorola Moto X Force Teardown, Remove SIM card tray.: 步骤 1 中的图像 2,2
    • Remove it or it will be a barrier to remove motherboard.
  2. Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 1,3 Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 2,3 Motorola Moto X Force Teardown, Remove back cover.: 步骤 2 中的图像 3,3
    • Use heat gun to heat up back cover firstly.
    • Insert metal opening tool to open a gap and cut adhesives around.
    • Take care when sliding tool under the back cover, there are delicate antenna and other components that could be damaged by your glue slicing tool
  3. Motorola Moto X Force Teardown, Remove metal logo cover.: 步骤 3 中的图像 1,2 Motorola Moto X Force Teardown, Remove metal logo cover.: 步骤 3 中的图像 2,2
    • Use tweezers to cut adhesives underneath.
  4. Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 1,3 Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 2,3 Motorola Moto X Force Teardown, Remove middle frame.: 步骤 4 中的图像 3,3
    • Twist off 17 screws by T3 Torx screwdriver.
    • Take away rubber bracket securing NFC antenna and release NFC antenna connector.
  5. Motorola Moto X Force Teardown: 步骤 5 中的图像 1,3 Motorola Moto X Force Teardown: 步骤 5 中的图像 2,3 Motorola Moto X Force Teardown: 步骤 5 中的图像 3,3
    • Take away rubber bracket securing MIC flex and release microphone flex cable connector.
  6. Motorola Moto X Force Teardown, Remove side button.: 步骤 6 中的图像 1,1
    • After middle frame's separating from the rest of parts, side buttons are loose and easy to remove.
  7. Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 1,3 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 2,3 Motorola Moto X Force Teardown, Remove microphone flex cable ribbon.: 步骤 7 中的图像 3,3
    • Release MIC connector.
    • There are adhesives existed underneath.
  8. Motorola Moto X Force Teardown, Remove headphone jack.: 步骤 8 中的图像 1,2 Motorola Moto X Force Teardown, Remove headphone jack.: 步骤 8 中的图像 2,2
    • Use tweezers to pry this part up.
  9. Motorola Moto X Force Teardown, Remove vibration motor.: 步骤 9 中的图像 1,2 Motorola Moto X Force Teardown, Remove vibration motor.: 步骤 9 中的图像 2,2
    • The vibrator is only fastened by the plastic bracket.
  10. Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: 步骤 10 中的图像 1,2 Motorola Moto X Force Teardown, Remove NFC antenna along with  plastic board attached.: 步骤 10 中的图像 2,2
    • There are a little bit adhesives around, but you can peel this part easily.
  11. Motorola Moto X Force Teardown, Remove loudspeaker.: 步骤 11 中的图像 1,2 Motorola Moto X Force Teardown, Remove loudspeaker.: 步骤 11 中的图像 2,2
    • Pry this part up.
  12. Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 1,3 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 2,3 Motorola Moto X Force Teardown, Remove metal bracket securing on motherboard.: 步骤 12 中的图像 3,3
    • Peel off the tape.
    • Twist off 2 screws.
    • Take care not to apply any lateral force to the motherboard to metal bracket electrical connector when removing the motherboard bracket. If abused, the tiny spring could break off at a later date and causing short circuits within the phone. The connector is to the right of the side button connector and above the copper film screened component.
    The motherboard bracket is electrically connected to the motherboard by a very delicate spring connector. Any lateral force on the connector will snap it off the motherboard. Take care not to apply any lateral force to the connector when removing the motherboard bracket. Any damage to the connector could result in it breaking off at a later date and causing short circuits in other components within the phone. The connector is to the right of the side button connector and above the copper film covered component.
    OuterSpaceHoppa - 回复
  13. Motorola Moto X Force Teardown, Release battery connector and side button connector.: 步骤 13 中的图像 1,1
    • Release this two connectors carefully.
  14. Motorola Moto X Force Teardown, Release touch digitizer connector.: 步骤 14 中的图像 1,2 Motorola Moto X Force Teardown, Release touch digitizer connector.: 步骤 14 中的图像 2,2
    • The LCD assembly has two connectors, here is touchscreen connector.
  15. Motorola Moto X Force Teardown, ReleaseLCD display connector.: 步骤 15 中的图像 1,2 Motorola Moto X Force Teardown, ReleaseLCD display connector.: 步骤 15 中的图像 2,2
    • This one is display connector.
  16. Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 1,3 Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 2,3 Motorola Moto X Force Teardown, Release motherboard assembly.: 步骤 16 中的图像 3,3
    • Release signal cable connector.
    • Pry the motherboard assembly up.
  17. Motorola Moto X Force Teardown, Remove rear camera.: 步骤 17 中的图像 1,2 Motorola Moto X Force Teardown, Remove rear camera.: 步骤 17 中的图像 2,2
    • Moto X Force packs a 21-megapixel primary camera on the rear.
  18. Motorola Moto X Force Teardown, Release signal cable connector and remove it.: 步骤 18 中的图像 1,2 Motorola Moto X Force Teardown, Release signal cable connector and remove it.: 步骤 18 中的图像 2,2
    • Use tweezers to release the connector.
  19. Motorola Moto X Force Teardown, Remove proximity sensor flex.: 步骤 19 中的图像 1,2 Motorola Moto X Force Teardown, Remove proximity sensor flex.: 步骤 19 中的图像 2,2
    • With this sensor flex, you can wave your hand on the top of the screen to wake up the screen.
  20. Motorola Moto X Force Teardown, Pry up and remove battery.: 步骤 20 中的图像 1,2 Motorola Moto X Force Teardown, Pry up and remove battery.: 步骤 20 中的图像 2,2
    • Non-removable Li-Ion 3760 mAh battery.
  21. Motorola Moto X Force Teardown, Remove front-facing camera.: 步骤 21 中的图像 1,2 Motorola Moto X Force Teardown, Remove front-facing camera.: 步骤 21 中的图像 2,2
    • A 5-megapixel front shooter for selfies.
  22. Motorola Moto X Force Teardown, Remove earpiece.: 步骤 22 中的图像 1,2 Motorola Moto X Force Teardown, Remove earpiece.: 步骤 22 中的图像 2,2
    • Be careful to pry this part up, because it tends to fall apart easily.
  23. Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 1,3 Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 2,3 Motorola Moto X Force Teardown, Remove side button flex.: 步骤 23 中的图像 3,3
  24. Motorola Moto X Force Teardown: 步骤 24 中的图像 1,2 Motorola Moto X Force Teardown: 步骤 24 中的图像 2,2
    • Here is LCD screen with LCD supporting frame. They are attached tightly, so we haven't separate them.
  25. Motorola Moto X Force Teardown: 步骤 25 中的图像 1,1
    • Done.
Witrigs
于11/24/15注册
69,454 声望
创作了378篇指南
9条评论
amoled
Danila Elchin - 回复
Good afternoon,
Tell me what you can say on the problem faced by many users of the device.
When you connect the original or third-party charger with fast charging Functions or without fast charging function, and sometimes when using cordless phone charging on the charge indication is presented but charging rate is 1-3% per hour. This problem occurs on the Droid Turbo 2 and X force.
I would like to hear your opinion on this issue.
Vikulov Aleksander - 回复
Several units are plagued by a vertical green line that appears on LCD (just search for Moto X Force or Droid Turbo 2 Green Line). Bad flex or bad LCD ?
NCQ - 回复
There should be problem of lcd screen flex.
Witrigs -
I have a UK Moto X Force. I have noticed that the green line appears when You push harder between the screen and right loudspeaker hole. it disapears when I remove my finger. I hope this green line wont become permanent :/
Dxt D -
Does this tutorial works with Moto X Play?
werther - 回复
can i use droit turbo 2 logic board on moto x force? i whant to change logic board becous my is crashed
sandro bitarishvili - 回复
:) Several very odd responses to this teardown, so I'll be the first to say.....
Thanks very very much Eric and other contributers, for taking the time to leave this guide. It's perfect and helped me get the thing apart without killing it - aint they a pain when they keep turning back on? I just want to mention thsi one extra bit.....
Be careful when prizing the back off the phone, it stuck so well on the one I've just done (even though I've fixed dozens of phones and am very familiar with the 'heating up' process to soften the glue, well in fidlling about with it, I was horrified to see I'd pressed the buttons in just the right way to get it to boot into its RECOVERY menu, and one more button press would have erased the customers contents!! *gulps*.
This happened despite the fact that the phones battery has been so flat it could never turn on beyond showing the Flat Battery logo - still had enough power to get into Recovery LoL.
Many thanks again Eric :-)
assortedrubbish - 回复
Hi, i bouth a Motorola x force, and i have a problem with the dual sim, the sim 2 does not work as a sim, but work when i use with a memory card.- Thank you!!
Juan Diego - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 18,789
