跳转到主内容
修复你的物品
维修的权力
配件 & 工具
在此拆机指南中使用的工具
简介
This is a good teardown when you will finally see what is under the black panel on the rear. It can also guide you to change the battery, if needed :)
Have a nice reading.
这个拆解是不是维修指南。 要维修你的的Motorola Moto G 1st Generation,请使用我们的维修手册
  1. After removing the back cover, use a torx T5 to remove all screws at the back Use an opening tool or plastic spuged to remove the outer frame. Use an opening tool or plastic spuged to remove the outer frame.
    • After removing the back cover, use a torx T5 to remove all screws at the back
    • Use an opening tool or plastic spuged to remove the outer frame.
  2. First we're going to remove the battery Using a plastic spudger, remove the battery connector from its socket. The battery will come off the motherboard when you put a little bit of pressure under it.
    • First we're going to remove the battery
    • Using a plastic spudger, remove the battery connector from its socket.
    • The battery will come off the motherboard when you put a little bit of pressure under it.
    • Don't bend the battery too much
  3. The naked motherboard will reveal 2 connectors (apart from the battery-socket)
    • The naked motherboard will reveal 2 connectors (apart from the battery-socket)
    • This is the front-cam
    • This is the digitizer/LCD flex
  4. 任天堂 Switch 套装
    A quick fix to get back in the game
    Shop Switch Kits
    任天堂 Switch 套装
    Shop Switch Kits
  5. To remove the camera, use a pair of tweezers to remove the tape Next, use a plastic spudger to open up the socket. Pull the camera up (out of the lens-socket) and pull so the flex will come out of it's socket
    • To remove the camera, use a pair of tweezers to remove the tape
    • Next, use a plastic spudger to open up the socket.
    • Pull the camera up (out of the lens-socket) and pull so the flex will come out of it's socket
  6. To remove the LCD/Digitizer connection from its socket, remove the blue silicone cover Next, use a plastic spudger to open the socket-lock Carefully remove the flex cable.
    • To remove the LCD/Digitizer connection from its socket, remove the blue silicone cover
    • Next, use a plastic spudger to open the socket-lock
    • Carefully remove the flex cable.
    • Although this flex seems to exist in 2 parts, it's actually removable as one. Only the wide flex has to be disconnected.
  7. Now, it's only the motherboard that's left.
    • Now, it's only the motherboard that's left.
    • Use a fine plastic tool to pull the main board out
    • There are no screws at this step
    • Never put too much stress on the motherboard, find other places to put pressure if it doesn't cooperate immediately
  8. All done
    • All done
    • The earpiece remains in the screen assembly. Take care when removing it from the screen. Push gently on it from the screen-side to lift it out.
Maxim
于2014年04月30日注册
2,266 信誉积分
创作了3篇指南
团队
iFixers Belgium iFixers Belgium 的会员
Business
1 名成员
创作了3篇指南
The procedure is very simple, but i realise that take off all the screws is a little bit difficult. As well, remove the motherboard that is attached to the plate behind the screen.
Allan Alcantara - 回复
Question. How difficult is it to replace the glass?
Abigail McElroy - 回复
I'm just about to have a go at it now!
I'll let you know
Dan Cameron -
Just replaced the broken screen on my XT1039. Be aware XT1032,XT1033, XT1039 - the screen components are all the same. I bought the screen/frame/digitizer as one unit for the XT1032. It was relatively straight-forward with a bit of care and attention in certain areas. After you've taken the 14 screws out the rest of the phone is basically glued together with sticky-strips. I followed the advice on a You-tube video and used a hair dryer to heat up the ribbon cables and to loosen the earpiece. Phone now fully functional - hooray! Thanks to all on this forum!
camiano - 回复
Can we further dismantle individual elements on motehrboard? Like I want to replace the memory.
simplyviral - 回复
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 21
过去的30天: 86
总计 85,482
