跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Motorola Moto E7,应参考我们的维修指南
  1. Motorola Moto E7 Teardown, Motorola Moto E7 Teardown: 步骤 1 中的图像 1,1
    • First, heat up the back of the phone using a heat gun, iOpener, or this heating mat I have. If you are using a heating mat like I am, I recommend putting a suction cup on the front so you can take it off the rubber surface. If you are using a heat gun or a heating mat, set it to 80°C (176°F) for 90 seconds.
  2. Motorola Moto E7 Teardown: 步骤 2 中的图像 1,1
    • Quick, use a suction cup to rip off the adhesive! Put an iFixit opening pick to keep it open! Make sure to push the fingerprint sensor through while taking the adhesive off or you will rip the ribbon cable securing it.
  3. Motorola Moto E7 Teardown: 步骤 3 中的图像 1,1
    • Unscrew the 21 Phillips #000 screws securing the top and bottom. There are screws under the S’s.There is also one under the fingerprint reader. I was only able to take a picture of the top.
  4. Motorola Moto E7 Teardown: 步骤 4 中的图像 1,1
    • Disconnect the ribbon cables near the battery. Remove the 2 Phillips screws near the camera and near the top right corner.
    • Remove the main board at the top and bottom. REMOVE THE SIM TRAY BEFOREHAND.
  5. Motorola Moto E7 Teardown: 步骤 6 中的图像 1,1
    • Heat up the front of the phone to pry up the battery, this will be difficult so be patient as to not blow up the phone.
  6. Motorola Moto E7 Teardown: 步骤 7 中的图像 1,1
    • Peel off the cable securing the screen to the phone. Then heat the phone and use a suction cup to pull the screen away, make sure to pull the cable through the hole!
    • If the screen is broken, you can pry the screen off from the top and use opening picks to open it.
Dante Jessmon
于12/06/22注册
418 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 41
总计 1,699
