跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Motorola C350,请使用我们的维修手册
  1. Motorola C350 Teardown, Rear case freeing: 步骤 1 中的图像 1,2 Motorola C350 Teardown, Rear case freeing: 步骤 1 中的图像 2,2
    • Use your finger to press the button and free the device rear case.
    • You may have to force it a bit more to free its bottom if you open it for the first time.
  2. Motorola C350 Teardown, Removing battery: 步骤 2 中的图像 1,1
    • slide the black button to free the battery so you can grab it with your other hand.
  3. Motorola C350 Teardown, Separating the front case: 步骤 3 中的图像 1,2 Motorola C350 Teardown, Separating the front case: 步骤 3 中的图像 2,2
    • You will see one plastic clip on each side of the device. Use your thumbs to push them apart and being able to separate the front case from the device other components.
  4. Motorola C350 Teardown, Keyboard: 步骤 4 中的图像 1,1
    • Use your thumb to gently peel the keyboard off the front case.
    • Be careful, the plastic on which the keyboard is stuck is pretty fragile.
  5. Motorola C350 Teardown, Logic Board: 步骤 5 中的图像 1,2 Motorola C350 Teardown, Logic Board: 步骤 5 中的图像 2,2
    • Remove the 4 T6 Torx screws
  6. Motorola C350 Teardown: 步骤 6 中的图像 1,2 Motorola C350 Teardown: 步骤 6 中的图像 2,2
    • Use a metal spudger to pell off the four metal clips and separate the motherboard and keyboard from the main plastic part.
  7. Motorola C350 Teardown: 步骤 7 中的图像 1,1
    • The last thing you need to doto access the Logic Board is to separate the Keyboard/Screen block just taking apart with your fingers.
  8. Motorola C350 Teardown, Ear Speaker: 步骤 8 中的图像 1,2 Motorola C350 Teardown, Ear Speaker: 步骤 8 中的图像 2,2
    • Remove the four T6 Torx Screws
  9. Motorola C350 Teardown: 步骤 9 中的图像 1,1
    • Use a metal spudger togently free the screen/ear speaker metal case.
  10. Motorola C350 Teardown: 步骤 10 中的图像 1,1
    • Slowly peel the ear speaker off the case.
    • Be really careful about the small plastic pin which can be easily lost.
  11. Motorola C350 Teardown, Display: 步骤 11 中的图像 1,1
    • Remove the two small metal clips keeping the cables safe.
  12. Motorola C350 Teardown: 步骤 12 中的图像 1,1
    • Use a plastic spudger to pell off the two cables on the back side of the screen.
    • There are two very small connectors. Take care of them and replace them if they incidentally fall.
  13. Motorola C350 Teardown: 步骤 13 中的图像 1,1
    • Use a plastic spudger to release the disconnected screen.
  14. Motorola C350 Teardown, Microphone: 步骤 14 中的图像 1,1
    • Use a plastic spudger to unclip the mic.
  15. Motorola C350 Teardown, Upper Speaker: 步骤 15 中的图像 1,1
    • The upper speaker is kept in place by a metal plate.
    • Use a metal spudger to free the 3 clips on the back side
  16. Motorola C350 Teardown: 步骤 16 中的图像 1,1
    • Insert your metal spudger to remove the metal plate and free the upper speaker.
  17. Motorola C350 Teardown, Parts overview: 步骤 17 中的图像 1,1
    • Here you can see all the parts composing the Motorola C350.
Vincent Monteil
于07/06/13注册
6,975 声望
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 1,730
