跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Motorola C139,请使用我们的维修手册
  1. Motorola C139 Phone Teardown, Battery: 步骤 1 中的图像 1,3 Motorola C139 Phone Teardown, Battery: 步骤 1 中的图像 2,3 Motorola C139 Phone Teardown, Battery: 步骤 1 中的图像 3,3
    • Begin by flipping your phone over so that the back cover is facing up.
    • Apply force to the back cover and simultaneously slide the cover down.
    • Note: Applying pressure on the ridges will make it easier to remove the cover.
  2. Motorola C139 Phone Teardown: 步骤 2 中的图像 1,3 Motorola C139 Phone Teardown: 步骤 2 中的图像 2,3 Motorola C139 Phone Teardown: 步骤 2 中的图像 3,3
    • Press the button labeled "PUSH" located at the bottom back of the phone. This will release the battery.
    • Lift and remove the battery.
  3. Motorola C139 Phone Teardown, SIM Card: 步骤 3 中的图像 1,3 Motorola C139 Phone Teardown, SIM Card: 步骤 3 中的图像 2,3 Motorola C139 Phone Teardown, SIM Card: 步骤 3 中的图像 3,3
    • Do not bend or scratch the SIM card. In addition, keep it away from static electricity, dust, and water.
    • Gently slide the SIM card out and lift to remove it from the phone.
  4. Motorola C139 Phone Teardown, Rear Casing: 步骤 4 中的图像 1,3 Motorola C139 Phone Teardown, Rear Casing: 步骤 4 中的图像 2,3 Motorola C139 Phone Teardown, Rear Casing: 步骤 4 中的图像 3,3
    • Use a Torx T-5 screwdriver to remove the screws on the back of the phone.
    • The screws are 6.86 mm long and 1.61 mm in diameter.
  5. Motorola C139 Phone Teardown: 步骤 5 中的图像 1,3 Motorola C139 Phone Teardown: 步骤 5 中的图像 2,3 Motorola C139 Phone Teardown: 步骤 5 中的图像 3,3
    • Slide a pry tool underneath the adhesive rubber stip and peel it back away from the phone.
    • Repeat for the other side.
  6. Motorola C139 Phone Teardown: 步骤 6 中的图像 1,3 Motorola C139 Phone Teardown: 步骤 6 中的图像 2,3 Motorola C139 Phone Teardown: 步骤 6 中的图像 3,3
    • Insert the pry tool in the slit on the side of the phone and slide it down until you hear an audible click and the phone bottom loosens from the top.
    • Use the pry tool to release the two hooks on each side and the two hooks at the top holding the case together.
    • Release a total of six hooks from the sides and top to free the phone into two halves.
  7. Motorola C139 Phone Teardown: 步骤 7 中的图像 1,3 Motorola C139 Phone Teardown: 步骤 7 中的图像 2,3 Motorola C139 Phone Teardown: 步骤 7 中的图像 3,3
    • Using a Torx T-5 screwdriver remove the screws at the top of the phone.
    • The screws are 6.86 mm long and 1.61mm in diameter.
  8. Motorola C139 Phone Teardown: 步骤 8 中的图像 1,3 Motorola C139 Phone Teardown: 步骤 8 中的图像 2,3 Motorola C139 Phone Teardown: 步骤 8 中的图像 3,3
    • Use plastic opening tools to free the circuit board from the case.
    • There are two hooks (one on each side) holding the circuit board into the case.
    • Then grip the circuit board and lift to remove the circuit board from the case.
  9. Motorola C139 Phone Teardown, Keypad & Faceplate: 步骤 9 中的图像 1,2 Motorola C139 Phone Teardown, Keypad & Faceplate: 步骤 9 中的图像 2,2
    • On the top half of the phone push downwards on the number keys to free the keypad from the top of the phone.
  10. Motorola C139 Phone Teardown, Antenna: 步骤 10 中的图像 1,3 Motorola C139 Phone Teardown, Antenna: 步骤 10 中的图像 2,3 Motorola C139 Phone Teardown, Antenna: 步骤 10 中的图像 3,3
    • Unhook the antenna by releasing the two hooks, one on each side of the phone.
    • Detach the antenna from the back of the circuit board
    • This small black rubber cover may detach.
  11. Motorola C139 Phone Teardown, Vibration Mechanism: 步骤 11 中的图像 1,2 Motorola C139 Phone Teardown, Vibration Mechanism: 步骤 11 中的图像 2,2
    • Using your hands or the pry tool, gently lift the vibration mechanism out of the rear casing.
  12. Motorola C139 Phone Teardown, Speaker: 步骤 12 中的图像 1,3 Motorola C139 Phone Teardown, Speaker: 步骤 12 中的图像 2,3 Motorola C139 Phone Teardown, Speaker: 步骤 12 中的图像 3,3
    • Unhook the 10 clips holding the metal screen cover in place and pull up to detach it from the logic board.
    • There are four clips at the top, two along each side, and two clips at the bottom of the metal cover.
  13. Motorola C139 Phone Teardown: 步骤 13 中的图像 1,2 Motorola C139 Phone Teardown: 步骤 13 中的图像 2,2
    • Lift to remove the speaker from its contact point on the logic board.
  14. Motorola C139 Phone Teardown, Motorola C139 Phone Teardown: 步骤 14 中的图像 1,1
    • List of Parts: Battery, SIM Card, Vibration mechanism, back cover, Front Case, Back Case, 2x rubber sides, 4x Screws, Antenna, Speaker, Keypad, Metal screen cover.
Kyle Olbrich
于03/09/12注册
30 声望
创作了4篇指南
团队
Clemson, Team 2-2, Benson Spring 2012 Clemson, Team 2-2, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G2
3 名成员
创作了15篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 4
总计 3,953
