跳转到主内容
你所需要的
本篇指南是分解流程而非维修指南。 如果您要维修您的Moodo Smart Aroma Diffuser,应参考我们的维修指南
  1. Moodo Smart Aroma Diffuser  Teardown, Device: 步骤 1 中的图像 1,2 Moodo Smart Aroma Diffuser  Teardown, Device: 步骤 1 中的图像 2,2
    • The device can be opened by removing the 4 Philips screws visible from the bottom
  2. Moodo Smart Aroma Diffuser  Teardown, Fan assembly: 步骤 2 中的图像 1,1
    • The fan and air guidance assembly is attached to the main PCB with 2 screws.
    • Each fan has one connector for power and one for the pod sensor - these need to be disconnected from the PCB before removing the fan assembly. If you want to replace a fan, you will need to unhook the sensor cables from the sides.
    • Fans used are: 1604KL-01W-B39-B00 NMB Technologies DC Fans DC Axial Fan, 40x10mm, 5VDC, 4.2CFM
  3. Moodo Smart Aroma Diffuser  Teardown, PCB: 步骤 3 中的图像 1,2 Moodo Smart Aroma Diffuser  Teardown, PCB: 步骤 3 中的图像 2,2
    • The main PCB connects to the control PCB with a ribbon cable.
    • It can be removed with 2 screws.
    • The 2 cell battery pack is located under the main PCB.
Markus
于01/01/20注册
132 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 20
总计 853
