跳转到主内容
加入维修社区 - 创建账户
The scroll wheel of my mouse had a bad connection. I originally planned to replace the part, but after cleaning it, the wheel returned to normal. I recorded the disassembly process and measured the component dimensions for future repair reference.
From my online search, model RJN-00001 might be the same as the following models — RJN-00025, RJN-00013, RJN-00037, RJQ-00065 — possibly just with different colors, but I cannot be certain.
你所需要的
工具
本篇指南是分解流程而非维修指南。 如果您要维修您的Microsoft Mouse,应参考我们的维修指南。
    1. Microsoft Wireless Mouse RJN-00001 disassembly, Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 1 中的图像 1,1
      • Remove the AAA battery and back cover.
      询问修复机器人
      添加评论
    2. Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 2 中的图像 1,1
      • Insert a spudger into the seam of the top cover. Using a metal spudger may leave scratch marks, so you may choose your preferred tool.
      询问修复机器人
      添加评论
    3. Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 3 中的图像 1,3 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 3 中的图像 2,3 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 3 中的图像 3,3
      • In the image, you can see two clips on the top cover (marked with red circles). Use a spudger to release them, then lift the top cover. There is also a hidden clip at the rear that can be easily disengaged. (marked with orange circles)
      • After that, remove the three T5 screws (marked with green circles) to lift off the mid-frame.
      询问修复机器人
      添加评论
    4. Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 4 中的图像 1,2 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 4 中的图像 2,2
      • Remove the three Phillips screws, then carefully separate the motherboard from the scroll wheel to complete the disassembly.
      询问修复机器人
      添加评论
    5. Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 5 中的图像 1,3 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 5 中的图像 2,3 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 5 中的图像 3,3
      • Measure the scroll wheel dimensions; you should be able to find the corresponding model online. I cleaned it using electronic contact cleaner, and the scroll wheel returned to normal. You can give this a try.
      询问修复机器人
      添加评论
    6. Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 6 中的图像 1,2 Microsoft Wireless Mouse RJN-00001 disassembly: 步骤 6 中的图像 2,2
      • Finally, measure the button dimensions for future reference.
      • My English is not very good, so I used AI to translate this article into English. Please help correct any translation errors if there are mistakes.
      询问修复机器人
      添加评论
作者
与
TingYuLin
于08/20/25注册
143 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 20
过去 30 天: 136
总计 1,035
