跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Microsoft Wireless Mobile Mouse 1850,请使用我们的维修手册
  1. Microsoft Wireless Mobile Mouse 1850 Teardown, Top case: 步骤 1 中的图像 1,1
    • I unclipped the 9 clips holding the top case to the body.
  2. Microsoft Wireless Mobile Mouse 1850 Teardown: 步骤 2 中的图像 1,1
    • I unscrewed the 3 Torx T6 Screws holding the body onto the bottom case
  3. Microsoft Wireless Mobile Mouse 1850 Teardown: 步骤 3 中的图像 1,1
    • I undid the two Philips #00 screws on the motherboard
  4. Microsoft Wireless Mobile Mouse 1850 Teardown, Fully Disassembled: 步骤 4 中的图像 1,1
    • That’s it!
Jed Calvert
于02/03/20注册
293 声望
创作了2篇指南
3条评论
Good work easy to understand instructions
jhoneycutt323 - 回复
My mouse had a battery leak inside of it. I removed the dud battery and tried to clean it a little but it would not work. After following these instructions I was able to fully disassemble the mouse and clean it out with soapy water, rinse in clean water, dry off with compressed air, and then clean in isopropyl alcohol and dry off with compressed air.
The mouse now works perfectly and doesn't need to go to the landfill.
Thank you very much!
Sam
Sam Stockwell - 回复
Well done on saving it instead of dumping it!
Glad I could help.
Jed Calvert -
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 20
过去 30 天: 85
总计 3,929
