跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. Metrans MWT01 Qi Wireless Charger Teardown, The Metrans MWT01. Qi wireless charger.: 步骤 1 中的图像 1,2 Metrans MWT01 Qi Wireless Charger Teardown, The Metrans MWT01. Qi wireless charger.: 步骤 1 中的图像 2,2
    • Has an additional USB port for charging.
    • Input: 9V 1500mA
    • Output: 5V 1000mA
    • Frequency: 100-150kHz
    • USB output: 5V 1000mA
    • Size 145mm X 81mm X 10mm
  2. Metrans MWT01 Qi Wireless Charger Teardown: 步骤 2 中的图像 1,2 Metrans MWT01 Qi Wireless Charger Teardown: 步骤 2 中的图像 2,2
    • Top and bottom shells are separated by 10 plastic clips.
    • To open, insert plastic opening tool or plastic knife and push inward and towards the top shell.
    • Start from near the USB port and work your way around. The corners are pretty hard and the clips are pretty sturdy.
    • Viola! Its open!
    • Holes there are for ventilation for the coil
  3. Metrans MWT01 Qi Wireless Charger Teardown: 步骤 3 中的图像 1,3 Metrans MWT01 Qi Wireless Charger Teardown: 步骤 3 中的图像 2,3 Metrans MWT01 Qi Wireless Charger Teardown: 步骤 3 中的图像 3,3
    • More pictures.
    • Coil is covered by a foam pad held down by a little glue.
Sean
于08/30/10注册
181 声望
撰写一个指南
一条评论
can't wait to see the next steps :-)
Fixie - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 4,437
