跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Mele F10,请使用我们的维修手册
  1. Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 1,3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 2,3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 3,3
    • 2.4GHz wireless frequency
    • Max. control range: 30 meters
    • IR remote range: 10 meters
    • Built-in 500mAh battery
  2. Mele F10 - USB Remote Teardown: 步骤 2 中的图像 1,2 Mele F10 - USB Remote Teardown: 步骤 2 中的图像 2,2
    • There is no screws. I have opened remote only by hands by bendig edges
  3. Mele F10 - USB Remote Teardown: 步骤 3 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 3 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 3 中的图像 3,3
    • OK! let see what parts we have inside
    • nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
    • ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
    • IR TX diode
  4. Mele F10 - USB Remote Teardown: 步骤 4 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 4 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 4 中的图像 3,3
    • More parts
    • JTAG ?
    • Mini-USB port - as far as I know can be used only to charging
    • 500mAh battery
  5. Mele F10 - USB Remote Teardown: 步骤 5 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 5 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 5 中的图像 3,3
    • USB Receiver
    • nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Adam
于10/12/11注册
128 声望
撰写一个指南
12条评论
Super! Thank you
nisko84 - 回复
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
Jose Manuel Peinado Navarro - 回复
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
http://forum.mele.cn/showthread.php?tid=...
drdedus - 回复
Confirm not work with Panasonic TV
Aurel Enache -
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Amine Elsemine - 回复
Just had exact same issue that brought me here looking for disasembly how to. Only worked plugged in. Opened it up and glad to say its now fixed. My positive battery wire had broken off. Resoldered and tested. So far so good
legerrej -
Hello,
I lost my usb dongle. Is there a way to pair it to a new one or do i have to buy a new remote ?
saraivix - 回复
I have the same problem! But mine just broke a very tiny crystal oscillator and I have no hope to find the right specs so I can buy another one.
Guilherme Saltini -
Can we replace battery? Thank you for your answer.
khunjiphuket - 回复
Yes you can, order a 500mAh 3.7V rechargeable battery to replace. Just make sure to buy the right size (measure it after open)
Guilherme Saltini -
Thanks!! I was wondering how to get the darn thing open to try to replace a dead battery.
SJC in NY - 回复
I need a replacement usb dongle. Where do I get it from
Paul Steven Tovey - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 27
总计 12,436
