跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Mele F10,请使用我们的维修手册
  1. Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 1,3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 2,3 Mele F10 - USB Remote Teardown, Mele F10 - USB Remote Teardown: 步骤 1 中的图像 3,3
    • 2.4GHz wireless frequency
    • Max. control range: 30 meters
    • IR remote range: 10 meters
    • Built-in 500mAh battery
  2. Mele F10 - USB Remote Teardown: 步骤 2 中的图像 1,2 Mele F10 - USB Remote Teardown: 步骤 2 中的图像 2,2
    • There is no screws. I have opened remote only by hands by bendig edges
  3. Mele F10 - USB Remote Teardown: 步骤 3 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 3 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 3 中的图像 3,3
    • OK! let see what parts we have inside
    • nRF24LE1 - Ultra-low Power Wireless System On-Chip Solution
    • ADXL345 - small, thin, ultralow power, 3-axis accelerometer with high resolution (13-bit) measurement at up to ±16g
    • Two XV - 3700CB Ultra miniature size gyro sensor with high stability double output
    • IR TX diode
  4. Mele F10 - USB Remote Teardown: 步骤 4 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 4 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 4 中的图像 3,3
    • More parts
    • JTAG ?
    • Mini-USB port - as far as I know can be used only to charging
    • 500mAh battery
  5. Mele F10 - USB Remote Teardown: 步骤 5 中的图像 1,3 Mele F10 - USB Remote Teardown: 步骤 5 中的图像 2,3 Mele F10 - USB Remote Teardown: 步骤 5 中的图像 3,3
    • USB Receiver
    • nRF24LU1 - Single Chip 2.4 GHz Transceiver with USB Microcontroller and OTP Memory
Adam
于10/12/11注册
128 声望
撰写一个指南
12条评论
Super! Thank you
nisko84 - 回复
I Need to buy an IR replacement, could you please help me?
it is strange to me that you says it has a TX IR Diode, when the remote can also receive IR to "clone" the Signal from another remote.
thanks
Jose Manuel Peinado Navarro - 回复
it does not learn codes from Panasonic tvs (i tested) and from denon as i read here.
http://forum.mele.cn/showthread.php?tid=...
drdedus - 回复
Confirm not work with Panasonic TV
Aurel Enache -
I dropped the remote accidentally, now only works with the mini usb plugged in. any idea where and what to look for?
Thanks
Amine Elsemine - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 26
总计 12,436
