简介
Apple just released their new Magic Keyboard amidst a slew of new accessories and some shiny new iMacs. This "magical" new Apple accessory has garnered some buzz for its rechargeable battery, instant pairing, and new key mechanism, but how will it fare in terms of repairability? We're eager to find out, so it's time to join the fun with the best magic trick we know. Alohomora! It's teardown time!
Looking for the rest of the 2015 Maccessory lineup? Check out the Magic Mouse 2 and Magic Trackpad 2 teardowns!
Do you want to be part of the magic? Find us on Twitter, Instagram, or Facebook for more tech news.
你所需要的
视频概述
Before the plastic bits start flying, lets take a peek at the spec sheet:
Dimensions: 0.43" × 10.89" × 4.52"
Bluetooth wireless connectivity
Internal lithium-ion battery
Lightning port (for charging and pairing)
Flipping over the new keyboard, we find a magical, new model number: A1644.
And a Lightning port! If you just felt a soft breeze, it may have been from millions of television remotes sighing in relief; no more stealing batteries for your keyboard!
To the right of the lighting port (opposite of the power button) is cutout from the aluminum, it looks like a place for a slot. Any idea what that is for?
Slot antenna!
Comparison time! Let's take a look at how the Magic Keyboard stacks up against the 3rd generation Wireless Keyboard.
The new keyboard adopts the slightly revised layout of the 2015 MacBook keyboard—including " full-size" left and right arrow keys, and function keys.
Switching to an internal battery means Apple engineers got to ditch the battery tube, giving the keyboard a lower profile. This should be good practice for typing on our new iPad Pro Smart Keyboard!
在这个步骤中使用的工具:iOpener$12.99
This looks like a good place to start. Manufacturers often hide screws under rubber feet to get that clean unbroken underbody look.
Tweezing out a rubber foot reveals a slot that holds the foot in place. Almost a screw! But not. This is just some molded plastic.
Thanks to a complete lack of fastener or seam, it's time to open some eyes with an iOpener.
在这个步骤中使用的工具:Curved Razor Blade$9.99
The gap between the plastic bottom and aluminum frame is too thin even for our opening picks—so instead we put our Apple Watch Opening tool to work, hoping for some prying purchase.
Once we get enough of a gap opened up, we sheath our knife and switch to plastic. Plastic Opening Picks, that is.
With enough of the rear panel pried up to get a handle on it, we can peel it right off the back, after some struggles.
Underneath we find our first components—the logic board and rechargeable battery. And another layer of adhesive laden plastic.
The battery is a snap to disconnect—no solder here, so Apple intends for it to be at least somewhat replaceable.
Did someone glue an iPhone battery in here?
Okay, not really. This battery has different dimensions than an iPhone battery, but it shares some similar design concepts. Unfortunately, those nifty adhesive strips are not one of them.
I have seen you also break the on/off switch, this tutorial is not specific enough, I almost broke it by flip inside plastic out. you should specify that only open the thin back up, not entirely plastic
At the top of every teardown, we post this banner “This teardown is not a repair guide. To repair your Magic Keyboard, use our ++service manual++.” in an effort to keep people from following this as a repair guide. You are more than welcome to start a guide yourself and help future fixers!
Funny reply from Sam Goldheart to this comment, since there is no "service manual" - the page is there, but no manual whatsoever in it.
yay nay -
“Nifty adhesive strips?” Really? I’ve done about two dozen iPhone battery replacements and have never been able to remove one intact or as advertised. My theory is that it depends on the age of the strips. I think there’s a chemical change to the glue, the plastic or both and the strip breaks after 25% to 50% is removed. Then you have to pry the battery out any way that you can. I think the instructional videos are made with relatively new devices when the glue hasn’t quite set and the plastic that the strips are made of are ‘fresh.’ Age and heat cycling (battery charging) changes the equation. “Nifty” is not the word I’d choose to describe them. Just my opinion.
The battery in my now aging keyboard expanded considerably. Obviously it could not be left as is. Such batteries are potentially dangerous when expanding, and it makes the keyboard virtually useless. I was able to find no replacements online, but wondered if it would work with the battery removed. Just using the lightning plug to connect. The answer is, yes. I discovered no difference in operation, other than it must be connected to use. Sure beats just throwing it out.
I found it interesting that the entire keyboard is held together with double-stick tape. Maybe extra sticky, but plain old, transparent double-stick tape, nonetheless. So if double-stick tape is considered okay for holding the whole thing together, why did Apple glue the battery in permanently? The only reasonable answer is, so it would need to be thrown out when the battery breaks. But if you’re careful, the battery can be slowly pried out with a spudger. (The same way I’ve had to pry out every other battery glued in with this nasty stuff.)
Without those peel-out adhesive strips, more vigorous prying and picking are required to free the battery.
The 2.98 Wh battery has less than half the capacity of the 6.55 Wh battery in the iPhone 6s. But with less to do the battery should last for months on a single charge.
That may be true, but it's important to note that all non-replaceable batteries limit device lifespans, eliminate users' options to use removable and rechargeable batteries, and greatly hinder end of life recycling.
What's the lifespan of a battery like this?
I haven't owned a rechargeable mouse or keyboard before, but I know my iPhone battery is crappy after only 2 years.
I know this is two years late, but about 2-5 years.
Liam, no way! Considering that the battery gets about 5 charge cycles a year, 2-5 years lifespan is very low (especially for a keyboard). Otherwise I’d rather buy the 3rd generation keyboard.
Surgie -
Hello, I need help with the battery of this keyboard, where I can get or buy, another apple model is compatible, I can not find it to change, I have broken swollen.
I have the exact same issue. Did you ever find a replacement battery?
There are none available anywhere that I could find, but the keyboard works just fine without the battery. It just has to be kept plugged in. Other than no longer being wireless, the keyboard works fine without a battery.
Jack M. -
I wonder - maybe the battery from computers works for the keyboards?
We disconnect a promising Lightning connector cable, and although it's not a soldered tangle, the port refuses to budge.
All that stands in our way are a couple T3 screws, and then the (tiny!) logic board is free!
So how does the Bluetooth antenna work? There seems to be an antenna connector on the logic board, which does not obviously have an antenna etched in, but none of the steps shows anything attached to that connector.
I know this is a long time after your comment, but...
Look at the second image of step 6 on the top right of the logic board, above the unused antenna socket, there is a spring contact to the case. The connector is probably for pre-assembly testing, I'm sure they wouldn't want to use all that glue to seal in a non-working logic board to then worthless $99 / £79 / €119 device; waste of glue for starters ;-).
A quick peek at the logic board reveals a dusting of silicon we can't wait to get a closer look at. Notable hardware includes:
Broadcom BCM20733 Enhanced Data Rate Bluetooth 3.0 Single-Chip Solution
ST Microelectronics STM32F103VB 72 MHz 32-bit RISC ARM Cortex-M3
NXP 1608A1 Charging IC
Texas Instruments BQ24250C Single Input I2C/Standalone Switch-Mode Li-Ion Battery Charger
Bluetooth 3.0 ? I was expecting an Apple keyboard with bluetooth LE...very disappointed.
Another layer bites the dust!
This honeycombed spacer layer is sandwiched in glue, giving the keyboard strength to stand up against even the most... enthusiastic typists.
The Lightning port is finally, after a couple screws, free.
HatsKeycaps off to this teardown! -
Spoiler alert: no butterfly keys in this net, just Apple's fancy new scissor mechanism.
However, according to Apple, they've actually reengineered the scissor mechanism to increase stability and improve key travel. By our best measurements, the new design offers a whopping 1 mm travel distance and totally flat keypresses—or something.
I can't believe that apple spend all that time making the butterfly keyboard design and promote it to be much better than the normal keyboard, but rather than continue to back it they bring out a new keyboard using the scissor mechanism...it's almost like they dont think the butterfly mechanism is any good anymore...lol
To me it sounded like the butterfly keyboard is *thin and still good*, not *the best*. So it only makes sense in a product that must be thin.
thesmok -
Butterfly mechanism of the MacBook-2015 is only 1mm travel distance; hard to use for any typing, very hard to use for long typing.
This new Magic keyboard is only 1.5mm travel distance, not as hard as the Butterfly, but hard to use as well. Less wobbly than previous Apple scissor switch generation, but you have to understand that the previous generation was a joke and very wobbly.
This and the Butterfly are ok for short texting and short typing. I do not recommend any of these for long typing sessions.
I’m a programmer and I use my MacBook for development and I have no issue whatsoever with that keyboard as far as typing.
In fact I think it’s much better. Just enough travel and far less noise. My colleagues appreciate it when I don’t pull out my old mechanical IBM keyboard from the 90s, the loudness of that one is distracting and annoying.
That said, I still think Apple has a lot of progress to make with its keyboards.
It’s 2017 and they still haven’t figure out a way to make a keyboard that resist the smallest drop of coffee.
Come on Apple, I can’t imagine your grand vision is for you to make profits by selling more keyboards.
rapha -
I tried to swap to keycaps and was impossible to attach them back. Is there a special tools needed?
Same here.. Space bar off .. Won't back
On
haphog -
Same here, no chance to put it back. Ificit please give a solution for that!
I had an issue with my delete key and didn’t want to spend $180 replacing the whole keyboard like Apple support advised me to.
I used an exacto blade to remove the keycap, though it might not be advisable.
Removing Keys:
1. Carefully insert a spudger from the bottom side of the keycap (i.e. south side of the chicklet). You shouldn’t insert more than 1-2mm.
2. Carefully pry upwards until the key pops off the scissor mechanism.
3. Carefully remove the key cap from the assembly.
Reattaching Keys:
1. (For long keys only) Align the protruding hooks of the metal bracket into their respective slots right and left of the scissor mechanism.
2. Very carefully lower the north side of the keycap so the 2 tiny slots on the keycap’s north underside mate with the 2 north pegs on the scissor mechanism.
3. Once the north side is slotted properly, swing down the south side of the keycap, align the chicklet so it’s concentric with the frame around it, then press down until the keycap clicks into place.
Hey there, do you think it would be possible to replace a key - the top arrow key for example - with a key from the previous wireless keyboard, say just with super glue? Or do all the little interlocking bits have to be pretty exact.
mudbox -
To add to this comment: If after ‘reattaching’ the key it doesn’t pop up. The ‘hooks’ on the back of the key might be bent from trying to reattach.
I had this exact issue with my ‘Control’ key and only after using an otoscope found that they were bent. After using a very thin screwdriver bit (ifixit #1) the hooks were pried back into shape and the key was able to slide back into the slots on the mechanism.
Mark -
The Magic Keyboard Repairability Score: 3 out of 10 (10 is easiest to repair)
The Lightning port and battery can be replaced independently of the logic board—if you can get the device open.
While fragile, the keycaps are removable and replaceable.
Excessive use of strong adhesive makes it very difficult to remove the rear panel, hindering access to every internal component.
Without a service manual, it is difficult to open the keyboard without damaging internal components.
Buen info. para alargar la vida a nuestros dispositivos queridos i de calidad. Apple. 👍🧐
Kim Escoda - 回复
The keyboard can be pried apart without too much trouble, as long as you’re patient, and take your time. Keep away from the on/off switch, though. Just work around it, and you should be okay. I’d give the repairability a rating of one though. Can’t replace the battery at all, and successfully repairing anything else inside is about as easy as pulling hen’s teeth.
34条评论
I have removed my spacebar and can't put it back properly. It just stays pushed down as if it was pressed. Can't find any help online with that. People, please help!
same over here. It does work but stays down. Did you find a solution?
lvdw -
I had the same issue, and I went to Apple Store today, they said they have no way to fix. They can take my keyboard back and give me $10 discount on the replacement. Which I refused.
And I found this video, it saved me. Please follow the way how he slide in and bush back into the keyboard from the 12 second of this youtube video.
Ian Chen -
The YouTube video helped me immensely (thanks Ian), for other people with a similar issue where replacing the key doesn’t work…
My ‘Control’ key was stuck flat. It seems the issue was the key itself where the ‘slot’s on the top underside of the key where the mechanism slots into were bent from trying to put it back (I used an otoscope to find this out!). I used the thinnest iFixit screwdriver bit (#1) to lever the ‘slot’ on the key back into shape so the mechanism could fit into it rather than be forced to the side.
Then inserting the key as per the video worked first time. Thanks!
Mark -
I spilled milk on my magic keyboard :S and now the f1,2,3 'til f10 and the right shift key don't work. and I made the stupidity to take off the f1 and f2 to see if I was capable to clean and make it work... not... now I have two keys that I can´t attach again and I think I broke a little part of the mechanism... big $@$*. today I went to the official apple store here in aveiro and they told that can´t help me, that don't have any mechanism parts to attach again the keys and that I have to buy a new keyboard if I want all the keys working, what?? anyone know any website that sells just the new scissor mechanism for the magic keyboard? many thanks.
Hi, I also have the Portuguese Keyboard, can I ask if you did find any way to fix your keyboard there in Aveiro?
I don't know if you fix it or not, I have another problem, with my acute accent and crasis key, doesn't work any more. Now, I don't know if you even your keyboard any more, but if don't, I can buy it from you...? Or anything... I don't know...
Anybody looking to repair a keyboard w sticky keys or weird key responses due to spillage watch this video: https://www.youtube.com/watch?v=rabx240p... Just rinse under warm to hot water spray, swoosh water around for a while, shake water out, dry outside and get as much water out as possible shaking and patting upside down. then stick in oven at low temperature like hundred something degrees Farenheit to 200 degrees F or whatever other creative way to dry for over 1 day.
norakat -
I have removed caps lock and can't put it back. It just stays pushed down and no return. How can I put it up?
@artur I just had this exact same issue, but managed to resolve it. If a key stays down after you clip it back in, it means you didn't clip it in properly, and the top of the scissor mechanism isn't clipped into the key, so it doesn't get pushed up. Remove the key again, and look at the little clips on the underside of it. You'll see the ones at top of the key need you to slide the key upwards towards the top of the keyboard to clip it in, wheras the ones at the bottom just requrie you to push down on the key to clip them in. So, position the key towards the bottom of it's "gap", then push down on the top part of the key, and then push the top part of the key up towards the top of the keyboard to get the top clips clipped in. Then just push down on the bottom of the key to clip it in.
I had the same issue: When I put keys back on keyboard, the key stayed pressed in. So I followed James Cocker’s advice. It did not work in the first place, because the little plastic hooks on the downside of the keys were bent. So I carefully bent them back (with iFixit Angled Tweezers) (such that the small scissor clips are able to fit into the key’s small plastic hooks) and it worked again. Phew…
Fachexot -
@jcwacky I could not understand your suggestions here. Like many others I've been unable to reattach the Spacebar key to the Magic Keyboard. Unlike other previous keyboards, this spacebar uses a design that makes it very difficult to reattach.
The main problem is as described, you reattach and it stays stuck down. From what I can tell, there is an orientation where small clips connect to the butterfly mechanism. Those go toward the bottom I think.
However, no number of other attempts make the key attach properly. I can not see any way to fix this. There are no youtube videos showing how to reattach the spacebar on the magic keyboard. Closest thing I found was someone saying it was nearly impossible and their key works worse now.
I'm super bummed I tried to clean this.
I spent a bunch more time on this and was able to restore the key. It was not as good as before, but it did get back into place and it is now usable again.
One major issue with this is that the metal pins used to hold the metal bracket ends can bend or warp fairly easily. I think that a bent pin may have been what caused the stickiness on my space key in the first place.
Here's my guide: How to reattach a Spacebar Key to the Magic Keyboard
are these tools available in India?
Someone has any luck in finding keys to the keyboard to solve this "stays pushed down as if it was pressed" problem (@artur; @lvdw)? It's not a clip properly @JamesCocker, if I change places with another key, the other key is working normal, in my case its really a "broken key" problem...
Thank you all!
To solve the key stuck problem, do as James Cocker suggested! Let me try to explain again. You need to slide the keycap UP first so the top part latches to the little clips at the top, then press down on the bottom part. This will let the keys spring back. If you just press down on the top and bottom parts to push in the key, it will stay down and won’t work.
I have a question myself, I spilled sticky fluid on my keyboard. 3 keys now don't work and 1 is outputting 2 letters. How do I clean it? I was going to try to take the battery out and run it under tap water and wait a week for it to dry in rice but it looks like a hassle to take the battery out…no hope here?
greetings from Spain, the problem of my keyboard A1644 is the SHIFT RIGHT key, it works intermittently, I have to give it several times to start working, once it works well during use, I removed the key and cleaned well all the possible part, I think the plastic key must be deformed because when I try to press directly on the inner rubber or I tighten the two side contacts works perfectly, under the rubber I can not clean it is stuck can this rubber be removed? I think that some liquid could get inside this rubber and that's why when I do the test without the key I put more pressure and it works.
I’ve removed the up and down arrow and I cannot put them back.
Here’s my Free Office Supplies Only method:
Soy sauce on the control key, took a sticky note and edged it down along the top edge of the key until it was under enough to pull up and gently dislodge the key. Snapped a wooden stirring stick in half and pulled the loose filaments out, then dampened it to use it as a fiber brush.
To re-insert, I slid the sticky note back under the top of the scissor switch in the key socket to keep it elevated, and reattached the metal hinge to the key and slid it up into the plastic hooks. I pressed down firmly from the bottom of the key to get those two little plastic bits on the bottom of the key piece into the spaces on the key socket, and then pressed down on the top until the top of the plastic switch snapped into the two little holes facing each other on the underside of the key, then removed the sticky note.
It stayed pressed down until I slid the sticky note back under the key from the top, and pulled up gently a few times. Key became springy again, with no stickiness.
The key needs to be slid in and then pressed down. The upper part of the key is a slide mechanism and the bottom part a click mechanism. Because of the upper part te key will “stand up“, thus creating the travel!
Wow this is sad. Many people are asking questions but nobody is providing solutions. I am not too optimistic but I will ask anyway - I spilled some beer on my keyboard and now all sorts of weird key combos are triggered when I hit certain letter keys. I thought maybe rinsing parts in water or alcohol would help. Wondering if anyone found a solution to this problem?
Anybody who spilled something on the keyboard resulting in sticky keys or weird keyboard responses you can fix without opening it up or removing any keys. Watch this video: https://www.youtube.com/watch?v=rabx240p... - Just rinse under warm to hot water spray several minutes, swoosh water around for a while, repeat, shake water out, dry the outside and get as much water out as possible by shaking and patting upside down. then stick in oven at low temperature like hundred something degrees Farenheit to 200 degrees F or whatever other creative way to dry for over 1 day.
This is some pretty bad advice, while the keyboard may work initially, you will likely end u p with a lot of corrosion on the motherboard and a dead battery at some point in the near future. If you arent willing to open it to properly clean it then at the very least use pure isopropyl alcohol instead of water. In a pinch you can use dill pickle juice instead of the isopropyl but make sure you strain the juice if it was the variant with garlic added.
Thanks for this description : instead of repairing, I’ve completely destroyed my keyboard now.
Your steps mis one important action : before removing the inner layer, you need to unscrew the on/off button.
If not done, it will break when removing the layer, rendering the keyboard unusable. Thanks a lot.
Hello from Argentina, my magic keyboard begans to work bad since 2 days, you press 1 and appears 15, you press q and appears qt, you press a and appears ag, you press z and appears zb. Do you have any suggestion to solve it? thanks a lot!
i ve tried all of these and i think i managed to crack the metal grips inside the metal case. now my 3 buttons dont return back… anyone?
Battery available here: https://www.laptop-battery-shop.com/appl...
Tim Searle - 回复
Este es el tutorial más empalagoso que he leido en mi vida
I think I have a small colony of ants living in my keyboard. They don’t seem to be hurting anything or affecting the operation. It’s just annoying to have them emerge while I’m working. I’m afraid if I open it as demoed here, I’m likely to cause a problem where there isn’t really one…just an annoyance. Anybody got any ideas about how I could make the environment within the keyboard uncomfortable enough to drive them out without hurting the keyboard?
Thanks.
ALERT! This tutorial is NOT complete, switch ON/OFF is the most complicated stuff to manage here and it's not available in this tutorial.
ALERT! It's easy break two little plastic parts of the switch.
In my case key numbers 1,2,3,4, not work. Now keyboard didn't connect via Bluetooth. Waste of time, money and everything.
I recommend you do not open it.
freakfnlow - 回复
Attention: I think one step was missed out. The step involving removing of the power switch, and there's a ribbon there. So if you follow through and did not remove the power switch screw and ribbon and proceeded to rip the plastic plate off you may tear the ribbon off from the power switch!!! Which I did! T_T
I have a Magic Keyboard that pairs fine, but doesn’t register any key presses. I have tried it with MacBook Pro, windows desktop, and iPad. Any tips?
Alex Gower - 回复
does the battery have an ID attached to it like the iPhone? so that any third party batteries ( IF there are any ) cannot properly connect?
Jisoo Park - 回复
Still no lit keys... and no replaceable battery? No thanks. I will keep what I already have, and when they break I'll still buy the old model.
crus - 回复
Replaceable battery? What is this, 1999?
glundmark - 回复
