简介
In this guide, we will be taking apart a Macintosh Centris 610, which is basically the same as a Quadra 610.
First, let's take a look at the specs of this computer:
- Centris 610
- 80 MB hard drive
- 32 MB RAM
- 512 KB VRAM
你所需要的
Unscrew the screw holding the power supply in place with the #1 Phillips screwdriver.
Remove the two screws with the Phillips #1 screwdriver.
Remove the standoff.
Push the CD-ROM drive out of the computer (I don't have a CD-ROM drive installed in mine, so I can't give you any pictures. Sorry!).
Step 1: Press up on one of the front tabs while lifting the support post. Step 2: Repeat this step on the other side until the internal chassis slides easily toward the back of the computer.
Unscrew the two marked Torx screws with your T10 Torx screwdriver and remove the speaker.
