视频概述
今天的百万美元问题:这是13英寸“Escape 版本”的放大版本,还是15英寸 Touch Bar 的缩小版本? 下面是技术规格告诉我们的:
13.3英寸 LED 背光 IPS Retina 显示屏,分辨率为2560 x 1600(227dpi),支持P3广色域。
2.9GHz Skylake 双核英特尔酷睿i5(可睿频至3.3GHz),配备集成显卡 Iris 550
8GB 2133MHz LPDDR3 板载内存(最大支持定制16GB)
256GB、512GB 或 1TB 基于 PCIe 的 SSD
4个Thunderbolt 3(USB-C)接口,支持充电、DisplayPort、Thunderbolt、USB 3.1 Gen 2
带集成 Touch ID 传感器的 Touch Bar
Force Touch 触控板
对外壳的初步检查确认了预期的FCC认证,以及一个新型号:A1706。
我们很想拿着我们的螺丝刀开始工作 ——但首先,让我们迅速拿出另一个2016年年末发布的13英寸的Retina MacBook Pro 做一些快速比较...
展现出通常为iPhones保留的五角螺丝和吸盘之舞,我们用熟练的滑动操作来打开盖子。
让我们玩“一起找不同!”在左边是配备有Touch Bar的MBP,右边是Escape版的MBP。
在配备Touch Bar的型号上,看起来在解决逻辑主板阻碍之前我们只能移除触控板和耳机插孔。
Seems to bad that they put a *smaller* battery into the Touch Bar model. It has a faster processor (2.9 to 2.0 i5), which presumably uses more power. It has a faster memory bus - that might change power usage, and it has two more thunderbolt/USB-C ports (or maybe two thunderbolt/USB-C and two USB-C-only) I don't know whether that would add a bigger power drain unless all four ports are being used.
Could Apple have simply added half an inch thickness and stuffed in more battery cells without turning it into a "thermal bomb"? (Of course they'd never do that because Apple's thin-ness obsession..)
Why does Escape Edition MBP has only one fan where as Touch bar MBP has two?
Escape edition has a TDP of 15W, while the Touch Bar edition has a TDP of 28W. Almost twice the heat, so need two fans during heavy duty tasks.
Yin Wang -
Too many lines to be a diagnostic port, look at the shielding as well, this is a high speed interface.
I'm thinking Apple realized it need a means to access the soldered SSD if the rest of the system died. So this is a jumper block to connect the onboard SSD to either the onboard CPU or externally to another system to access the data on the SSD via the connection. Its also possible it may allow one to add in a daughter board, additional SSD storage.
That would be my thought as well Dan, they have to give themselves some way out when you fry your machine.
Add in a daughter board *where*? (Unless they want to go the way of Google's sadly defunct Ara project..)
jimwitte -
Dan, diagnostic ports often have high speed interfaces (e.g. JTAG and HSSTP) in order to debug onboard controllers.
Yes, thats true it would be on the faster side, but not so fast as to need the extra shielding. Also look at its location and besides a diagnostic port would have fewer lines. I'm very sure you are looking at a 8 lane PCIe interface given the number of lines (1x8+2x4). That would leave the two 4 lane interfaces are for the Thunderbolt chips.
Dan -
Until someone gets access to the service manual or training we are just guessing here. Common sense and experience can lead us to the most probable function.
Gaining access to a dead systems SSD is a likely function, the other would be for diagnostics. I'm discounting the diagnostic function as one only needs about 20 lines to setup HSSTP for a low end setup. Remember the MacBook Pro is not that complex a device to need more than the basic setup (this connector is offering 42 pins + 4 grounds as well as a full shield)
Here’s the special SSD access tool! https://9to5mac.com/2016/11/24/apple-spe...
与功能键版本非常类似,Touch Bar版本的触控板单元在拧下十颗T5 Torx螺丝后很容易滑出。
我们还可以高兴地讲,这些来自不同型号的触控板是相同的,并且可能是交叉兼容的。
以防你错过了,这里是我们最初确认的一些IC:
意法半导体STM32F103VB ARM Cortex-M3 微处理器
博通 BCM5976C1KUFBG 触摸控制器
美信集成 MAX11291ENX 24位, 6通道 高通滤波器
Wheres the taptic engine? There's three settings for feedback level, so it's in there somewhere.
samsung154 - 回复
现在我们来看看这胡子一样的逻辑电路板板,看看是什么芯片让这个MacBook成为Pro版的:
英特尔酷睿 i5-6267U 处理器,配备了Iris Graphics 550 图形处理器
英特尔 JHL6540 Thunderbolt 3 控制器
闪迪 SDRQKBDC4 064G 64 GB NAND 闪存 (2颗 总计128 GB)
三星 K4E6E304EB-EGCE DDR3 DRAM (4 x 2 GB 总计8 GB)
德州仪器 SN650839 66AL7XWGI, 和TI/Stellaris LM4FS1EH SMC Controller (TM4EA231 的替换型号)
村田/苹果 339S00056 Wi-Fi 模块
R4432ACPE-GD-F
Why are they using 4x2 GB RAM modules? Is this making any sense? Didn't they just use one?
That is JEDEC LPDDR3 spec and the spec intel processor supports.
The LPDDR3 chip supports 32-bits data width and to support 128-bits LPDDR3 data width intel processor supports . It needs 4 four LPDDR3 chips.
JJ Wu -
A couple of possible reasons:
- Wiring for 4 chips would be necessary to support the 1TB SSD option (4 x 256GB)
- Access is faster when solid state storage is spread over more chips (wider bus).
Not sure I follow you here. The RAM interface is independent of the SSD interface (PCIe).
Dan -
Intel Core i5-6267U processor only supports LPDDR3 upto 1866Mhz (base on Intel link). If the LPDDR3 in the MacBook Pro has maximum data rate is 2133Mhz. Is the maximum data rate 2133 or 1866 Mhz?
Apple control so much of what they use that it gives them potential to go a long way outside the box.
Given that they totally control the SSD controller, then there are things that they could do to greatly improve paging performance to fast SSD. And those things could well involve wanting the widest memory path that they can get.
which network card is in it?..........
翻转逻辑电路板,我们发现不少组件,包括:
闪迪 SDRQKBDC4 64 GB NAND闪存存储(如越狱版的见到的可移动SSD) ——总计256 GB
APL1023 343S00137 (likely the custom 很可能是定制的与Touch Bar配对的 Apple T1 芯片 )
2x 德州仪器 TI CD3215C00 68C7QKW G1
Intersil 95828 HRTZ X630MRD
(苹果?) 338S00193-A1 16348HCI
华邦电子 SpiFlash W25Q64FVZPIQ 64 Mb 串行闪存
恩智浦半导体 66V10 NFC 控制器, 包括安全芯片 008 和恩智浦半导体 PN549 (和在 iPhone 6s 上看到的一样)
Does the NFC chip mean that the MBP could theoretically be used with Apple Pay? Or is there some other reason they would have included it? (Apple, *futureproofing*? The devices are almost hermetically sealed, so there's probably no possibility of even an "Apple blessed" upgrade option) Chipworks has their docs on it, but they cost many hundreds or thousands of dollars each (do they perhaps have a student discount?)
It's only for the secure element. If my memory is right, the iPad also has a similar controller but doesn't support NFC.
I want to buy this. Where can I find it? Can you help me?
2x Texas Instruments TI CD3215C00 68C7QKW G1
背面其他芯片:
2个百利通 PI3WVR12612 HDMI 2.0, DisplayPort 1.2 视频切换器
凌云逻辑 CS42L83A 音频编码器
美国国家半导体 66A82NU 48B1-004
德州仪器 TPS51916 内存电源同步降压控制器, 和 TPS51980A 同步降压控制器
德州仪器 TMP513A PMIC
2个 仙童半导体 FDMC7570S PMIC
仙童半导体 FDMC86106LZPMIC
Does anyone have a datasheet for the audio logic? (CS42L83A) I cannot find one on the internet.
配备Touch Bar 的MacBook Pro 的另一大特色是添加了Touch ID。
帮助驱动这个巧妙功能的硬件包括一个整合了电容式传感器的按钮,可以区分不同的用户。为生物识别喝彩。
Touch ID 按钮表面覆盖有蓝宝石水晶,它应该可以防止指纹识别器刮伤。
as if capacitive buttons just break
James Deng - 回复
Samsung and Micron/MicronPC/MPC laptops had fingerprint readers and security software using them since the late 1990's. Dunno if Samsung continued to do so after MPC went out of business in 2008, cutting off that channel for selling Samsung's high end laptops in the North American market.
Hi everyone
What is the black “plastic” which be two black screws hold?
Is it make button more elasticity?
Thank you
悬挂在逻辑板的每一端,我们找到一个小型,模块化的USB-C电路板。
到了这里,我们终于可以把风扇抽出来。这个被重点介绍的风扇直径为43毫米,比我们在入门级MacBook Pro 中发现的45毫米风扇小一点(但是,你有了两个)。
I think it was a big mistake to loose the MagSafe concept for the power cord. I've tripped on my cord a few times thankfully the cord disconnected before the laptop took a spill.
Could the USB-C hardware-connector spec be made with a magnetic clasp? Or does Microsoft have a patent on doing that for something with more than 5 pins?
jimwitte -
两排扬声器栅格优雅地放置在MacBook 的边缘和键盘之间——精心制作的通风口,可以将声音从MacBook Pro直接传到...等一下。
扬声器并不在扬声器栅格下方。扬声器栅格甚至没有透过外壳。
这些扬声器可能是通过侧面通风口发出令人印象深刻的声音。
It looks to me like these speakers are simply ported— a common technique used in home theater speakers to achieve bigger sound. Also, the way this is laid out the speakers are further away from the logic board too, which might allow Apple to crank the bass further up, knowing that potentially chip-breaking low-frequency sound waves have more distance to dissipate.
All those perforations probably shave off quite a few grams of weight compared to a solid slab of aluminium.
Perhaps - then why didn't they put *more* of them in? Since weight seems to be second only to thin-ness on Apple's list-of-priorities.
jimwitte -
I spill only a drop of water at speaker grill on the left. Is it damaged my macbook?
If you cover the speaker grilles it does block the sound, your detail is incorrect.
so the grills only go clear through the case at the bottom as shown ? I dropped only a few drops of liquid on the upper grills beside the delete button and cleaned it right away, is it safe ?
Yeah, despite all the whining in the comments, all those speaker holes up there ARE cosmetic. The only ones that are actual, functional holes in the aluminum are way down next to the right arrow key. As long as your spill didn’t get onto the keyboard keys or the power button, you’re perfectly fine—it’s no different than if you got some liquid onto the palm rest or the display lid. Rest easy!
Dear iFixit. First: I love you guys! But… sorry to say your description may not be 100%. The down firing speakers are the subwoofers(!). There are little, closed compartments like little domes right above them, which contain the tweeters. Maybe you can add another picture for this detail?
遇到了粘合剂的阻力,我们组合使用了一个撬片和一根撬棒,从上表面撬出右侧扬声器。
我们用我们的小眼睛窥探什么可能是一个极小的扬声器,嵌在“真正的”扬声器上方的角落里。
我们喜欢功能键版MBP 用来固定扬声器的橡胶缓冲隔音螺丝。看起来Touch Bar 版选择使用胶水来替代。
Hmmm, two-way audio system in a Mac laptop? Interesting.
hugostonge - 回复
It is a two way sound system. If you cover the top "holes" with your hands the high frequency cuts out. However, it's hard to tell if all the holes are drilled or just enough for the tweeter. In any case it sounds great and is LOUD. I suppose the function key model though will sound better.
在这个步骤中使用的工具:Mako Driver Kit - 64 Precision Bits$39.95
我们离Touch Bar 如此接近,我们几乎可以触摸到它。
苹果似乎在通过用P2 五角梅花形螺丝固定Touch Bar 来展示它的黑科技。
我们从外壳底部中拔出连接电缆——这将逻辑主板连接到Touch Bar 显示屏,并可能连接了一些显示芯片。我们发现有:
意法半导体 32A 8628
The power/Touch ID button needs to be replaced at the same time as the logic board, or vice versa as they're paired at the factory presumably. So a power button means you have to transfer ALL the data from one SSD to the next!!
在这个步骤中使用的工具:iOpener$12.99
接下来需要加热。我们呼叫我们的朋友iOpener帮助我们拆除Touch Bar。
孩子们,听好了,划重点了! 今天,我们将学习如何不小心弄坏Touch Bar。我们从上部的外壳中分离OLED 面板时导致数字转换触控屏与显示屏分离。学到老,活到老。
雪上加霜的是Touch Bar 柔性电缆断在外壳下面,这让拆解变得超出预期地烦人.
Could be a great idea to put in the front of Step 19 two red exclamation marks for people to pay attention? Maybe in the corners of the pictures as well?
人的触摸需要由大脑处理。Touch Bar 需要由芯片来处理。通过拆解,我们发现Touch Bar 的大脑:
博通BCM5976TC1KUB60G 触摸控制器
移除OLED条的确很困难,但我们的努力不会白费!也许有些徒劳。好吧,我们的努力白费了(我们的希望和梦想也是)。Touch Bar太脆弱了。
我们偶然发现一个没有标记的芯片,更是增加了Touch Bar 的脆弱之迷。考虑到它的位置,它可能是显示驱动器之类的东西。
在移出所有组件后,我们发现了一个三麦克风阵列。最左边的一个是用来听什么的?是风扇?还是键盘?谁知道呢!
The third microphone is probably there to remove fan noise + keyboarding clicking noise.
Nah - I'd guess it's either Apple and/or the NSA listening in on sex chats.. (Oh, sorry, that was my inner Steve Bannon..)
jimwitte -
Does photo 2 here serve as confirmation that the leftmost part of the touch bar is inactive, meaning that a soft escape key cannot be properly located far enough left to be directly above the backquote/tilde key?
But it's actually touchable. If you touch the leftmost part of the touch bar, esc-key will be pressed (and highlighted).
终于,我们取出(被强力粘附)五节电池。
你最好希望你的“Pro”生命很短;因为更换电池就像是个谎言。
电池主板上的芯片为 TI BQ20Z451(可能是在MacBook Pro 中经常看到的 BQ20Z45-R1 的变种)
标称容量49.2 Wh ,相比功能键版本的54.5 Wh,这个电池似乎有点小—特别是考虑到它要驱动更多的功能。
我们依次称取这些电池的重量:配备功能键的MacBook Pro 电池重235克,而这个电池仅重197克。
Hello this rMBP 13,3" with touch bar , the battery how many mHa ?
Portable External Battery perspective I'm interested in
How could the touch bar edition feature a smaller battery but yet about the same batter hour of usage at 10 hours?
Those cells look tiny. I hope next year's model has a capacity of at least 70 watt hours with two cells in each one.
What about the keyboard? Can it be replaced?
Do you really have to take 18(!) steps in order to remove the battery of a touch bar model? Seems a little exaggerated to me.
This isn't a guide—it's just an overview of the hardware.
由衷感谢以下译者:
61%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
76条评论
what a mess inside. especially given the spaces around the batteries, and the off position of speakers, looks like the chassis was optimised for the non-touchbar version (much cleaner layout, removable SSD, no gaps), and touchbar addition was a later decision. Maybe initially they envisaged only the 15" would have touchbar.
a similar case of "odd unused chassis space" happened with the first gen 13" retina macbook pro, which had empty space under the trackpad. Was probably a late decision to use small form SSD over 2.5" SSD. this empty space was used up on subsequent updates.
to me the touchbar version has way too many compromises. the biggest issues are: smaller battery, while using a processor with a higher TDP. and non upgradable SSD (arguably the only component that might require future upgrade, unless you want to pay extraordinary money right now).
How do you do a power rest if the machine hangs? Before you held down the power button for a few seconds. Would that work with a touch ID button?
It still is a physical button. Just like the iPhones (except iPhone 7).
mamufek -
I would assume that you still do - the Touch ID sensor is still a physical button, so there's no reason it doesn't work like a normal button as before. However, to stop it shutting down the machine with a single click, I'd imagine macOS has some code in it saying "if the power button is pushed while the computer is on, it's probably for Touch ID things, so don't shut down".
in fact you have to press it long to act like a power button says the apple support page :P
First generation computers tend to lend themselves to some issues. However, given the price bump and the Apple brand I was expecting more, much more. The concept seems nice, the hardware implementation not so much. Laptops are to be mobile, so sacrificing battery life for weight is not a design decision that appeals to me. With Skylake I was expecting the REAL battery life to surpass 12 hours...
MacBook Pro with SSD RAID 0 inside?
Not here, sorry ;-{
Dan -
So can you move the touch ID sensor to another mac? Does it still work? Or are we going to have an Error 53 for Mac and a connect to iTunes screens.
Of course you can't. It's like the TouchID on iPhones and iPads. It's paired with the T1.
probably everything works execpt touchID, hopefully apple learned their lesson
Lack of repair-ability is understandable and unavoidable in today's world of disposable gadgets. If my $500 laptop craps out, so be it. However, $2000 worth of computer is not disposable. I would never buy another macbook.
It's not unrepairable. It's just unrepairable by unequipped amateurs, which is where iFixit sell their bits and pieces.
And those same things that make it more difficult to repair, also make it less likely to go wrong in the first place.
Again, not in iFixit's commercial interest to encourage.
alex -
I guess I see things a bit differently than Alex here. True IFIXIT is a business as such they do need to make money, but its more than that. The vision is to not create waste by repurpose or repair. The more Apple goes down this path of non-repairable it kills their own mission of being ecology minded. People don't want to throw away a $2 - 3 K system just to get a bit more memory or storage. They want some expandability! Likewise, being forced to replace major assemblies to deal with a small part failure is also wasteful!
Dan -
Random question - what do you end up doing with the things you tear down after? Do they all go back together again (and end up in full working condition)?
As you can see they've already ruined a lot of things, so this is not going back together.
Tom Chai -
From the IFIXIT team: "Not to worry—we definitely don't let our teardown devices go to waste. Oftentimes we will use them to create a full set of repair guides. We create some in-house and also send devices through our edu program to teach technical writing. You can learn more about that here. After that, we make sure they find a good home, or dispose of them responsibly."
Dan -
Wait, no split fin fans in the touchbar 13" either? I thought their website showed the touchbar 13" as having them...?
'On the 15-inch MacBook Pro, an innovative split blade design allows for more blades and delivers increased airflow.'
If you compare in Step 4 the two versions of the MacBook, you can see the version without the touch has the vent openings for the second fan too.
TheLOD2010 - 回复
"The speakers are not located under the speaker grilles. The speaker grille doesn't even go clear through the case."
Yet the tweeter can clearly be seen in the red box in this image:
https://www.dropbox.com/s/j13u5ev3ypekr8...
Okay then iFixit....
Noted and the text was corrected clarifying the openings are for the twitter speaker.
Dan -
Does step 17, photo 2 serve as confirmation that the leftmost part of the touch bar is inactive, meaning that a soft escape key cannot be properly located far enough left to be directly above the backquote/tilde key?
The area is the interface to the ribbon connector that goes to the logic board. I do agree the placement is troubling. I suspect the designer wanted to be symmetrical with the other side as the Touch ID/Power Switch is the same amount of space so the Touch Bar is cropped in on that side. I'm surprised as well they didn't think this through. I would have brought the Touch display all the way to the left edge and used the underside for the connection point. There is no reason it couldn't be a bit asymmetrical.
Dan -
> There is no reason [the Touch Bar] couldn't be a bit asymmetrical.
Except that Jobs liked symmetry..
jimwitte -
what a shame! apple think all their users are stupid. they probably are 99% right. Who cares if you cant upgrade the ssd? The next step will be solder the battery too? What else they can invent to suck the idiots money? I fell terrible windows pc are so much worst... for now who cares about upgrade at least the ssd will be in the hunt for the old models. And sandisk? common, this is only to change to samsung ssd next year and announce a twice fast ssd?
"What else they can invent to suck the idiots money?" How does a book for 300 bucks sound?
Thomas J -
A stand for your Pro Display XDR for $1000!
Other crazy prices:
VESA Mount Adapter - $199.00
Apple Mac Pro Wheels Kit - $699.00
Apple Mac Pro Feet Kit - $299.00
it's crazy apple designed a separate 13 inch function key model instead of just shrinking down the touch bar model, sure it might save money on the long run, but design and testing and manufacturing two completely different 13 inch would mean ........................................................................................people from macbook air department would still keep their jobs.
This is the mate to the 13" Function key model Here is the 15" Touch Bar Teardown. What are you saying here, you want the new MacBook to have the Touch Bar?
Dan -
Am I reading the data sheet for the ram correctly? The Samsung ram was released in 2012, and is rated at ~1066MHz??? Is this somehow run in tandem to yield 2133MHz?
Briefly looking through some of the early Geekbench scores, it seems the new rMBP doesn’t have much of an edge, if any over the predecessor. Upon looking closer, it seems the memory tests are slower on the newer model. This doesn’t add up per Apple’s claim! Is this yet another crippling disappointment?
Why da fcuk do you need to open it?!
IT JUST WORKS!
Ok, the Sandisk SSD can break down, that can happen. But everything else is working forever.
You do realize that the SanDisk SSD is now soldered onto the logic board, it may be the first to die, but if it dies the entire board is useless and thus you will need a logic board replacement. Lets hope you keep backups because without a removable SSD there's no chance of getting your data recovered.
It appears you do not grasp the concept of why repair guides are created:
~1 Some people (like me) just LOVE knowing how things work - that's how we become engineers, and are able to repair things and design other things, make informed decisions (which we can confidently pass on to others with less inclination or interest to know this stuff.)
~2 Because repairing your own device teaches you independence and VALUABLE skills which are transferable and profitable, and also enjoyable to learn and practice.
It's also fine to be a consumer who DOESN'T, but it's illogical for you to criticise or chastise those who DO take them apart, kapish?
GOLD contacts, not copper; the copper is the underlying substrate that is the PCB trace.
With respect, iFixit, leave the puns to us English folks, your attempts are extremely contrived and... well... they don't work and detract from the articles you feel the urge to force them into. PLEASE, just don't try to be funny - we come here to see things stripped down, not for comedy - others do it way better.
With respect, iFixit, add additional puns. We love your extremely contrived attempts at humor. They simply work, never detracting from the articles. They are as welcome as caviar on toast. Please, be funny! We come here for two things, stripping and comedy. No one else does it better.
Thanks {:-)
Hello,
Does anyone know if these new Macbook pros have 3x3 Wi-Fi antennas like the 2013 models ?
Thank you !
This model appears to have 3 transmit antennas (see image of the back without cover, near right fan). I think this is a 3x3 wifi model. The non-touch bar model is 2x2.
Curious what the shielded port is for. I am skeptical that it is for reading the SSD, since the SSD usually needs communication with the SMC, CPU and requires 3.42v and 3.3v S0 voltages to power it (among other circuits/signals). Unless the reader tool which plugs in independently powers the SSD ICs, I think it will be unlikely.
I think there is a high chance it is just a shielded diagnostic port, to better protect it from liquid damage. On older models (Macbook Air is a good example) if the diagnostic port gets liquid damaged, Apple can no longer use the port to read important voltages. It can also prevent the Macbook from working correctly, which is why a lot of diagnostic ports get removed by 3rd party repair centres.
In time, we will see I guess...
I've had many laptops over the years and at the end of use I always removed the data disk in order to protect my privacy. Now I have security/privacy concerns about the soldered SSD. If the logic board (or the SSD itself) goes wrong, how can you ensure that the data is removed?
Nah, it's pretty simple. Turn on FileVault encryption (you already have it on don't you?), and then when you remove your userID and recovery key you make the SSD unreadable.
Alternatively, you could remove the logic board and destroy the SSD by smashing the data chips. I'd be a bit of a waste, but it's secure!
Sir ifixit engineers if the touch bar is fragile I think it will be broken when taken by non experts or local repair technicians.what to do unless we replace it we do not need to touch it.for replacing keyboard is it necessary to remove touch bar I am asking this because it is so fragile.i know you're experts.pls help ifixit engineers as soon within less time I am waiting for you
Sir pls help I look your website everytime for disassembly
Sir ifixit where is the harddisk and dvd drive.plshelp as soon as possible
Why apple is making it's laptops unrepairable
Ives has too much input at Apple. He has developed an anorexic approach to design. He has slimmed down the look of MacOS from a 3D look to a flat bland desktop. Functional and repair sacrifices were made to make the equipment "The thinnest we ever made it" The touch bar is a nice idea but it can only be fixed by replacing the entire top of the computer. I have replaced just the keyboard for a MBP for just $40. It's held in with over 30 very small screws and was a lot of work. Still fixable though. Apple just replaces the whole top. We couldn't be foiled with special screws. Just solder and glue everything in place now. The touch bar is, in effect, part of the upper frame. USB C is great as a multiport but the loss of Magsafe is just wrong. We are back to our laptops flying off the tables again. Oh wait - More broken Macs that have to be replaced! Soldered in drives for the sake of thinness, look how this compulsion worked for Karen Carpenter.
Why is there 5 batteries and not 3? One big would have bigger capacity than 2 smaller.
Where is the wifi Chipset for the 802.11 and Bluetooth? why didnt you guys list it for the 15 inch model and you listed it for the 13 inch?
Hey there Moe Khan! In step 8 there is the Murata/Apple Wi-Fi chip. This is likely a combination of both Wi-Fi and Bluetooth. Unfortunately this is a proprietary chip, so there is no publicly available data sheet (at least as far as I know). This means we can't confirm that this is FOR SURE a Bluetooth chip. We are just "pretty sure". I hope this helps you! (I also responded to your post on the 15" MBP with Touch Bar).
Hello I am contacting you from the Experimac East Orlando store. I was wondering if the Display was easily removable or if i would have to do something with the Touch Bar to remove the screen. Looking forward to more Tear Downs, thanks again iFixit Team!
Hello. I just broken my screen. What are the chances that it can be fixed?
Nothing there about keyboard disassembly.
Mine has several keys that are now mushy and not clicky and I'd like to see a way of getting it apart without breaking the butterfly assembly.
Anyone?
Are there tamper proof screws or other booby traps that would let Apple know the computer has been opened up to void a warranty?
ingerdave1 - 回复
Recently got my screen broken and went black as just the “broken” area displays strands of colors. Went to Apple Store and said that they would reply within the day but never got any feedback from them. Can the Retina Display be repaired without the need of buying another laptop? If it can, how much can it be to repair it? I would appreciate any answers. Thank you.
Please make a tutorial of how to apply new, quality thermal paste to the Macbook pro’s processor. Quinn of Snazzy Labs showed us, that using higher quality paste results in about 10% performance gains.
In regards to the MacBook Pro internal cables/parts, can some one tell me what “Mylar BMU eDP TCON” is?
Can the battery be removed/replaced without the full teardown?
cedricsims - 回复
Hello, is anyone can help me to locate graphic card chit on this logic board? i have the board but not sure about specs. Thanks.
Hi, is it possible replace logic board on another if is dead? I mean in home, without service and logic board from ebay?
HOLA TENGO UN MAC BOOKPRO CON TOUCH BAR 2017 CON EL ERROR
cpu machine check architecture error dump (cpu intel(r) core(tm) i5
SE ME REINICIA A VECES NO QUIERO ARRANCAR SE PRESENTO EL ERROR CUANDO ACTUALIZE A CATALINA.
QUE PODRIA HACER AL RESPECTO.
GRACIAS
Grazie mille per questa guida. Dovevo sostituire la tastiera di questo pc, ma alla fine abbiamo optato di sostituire tutto quanto il pezzo intero. In alcuni punti mi ero proprio perso perché era la prima volta mettevo le mani su questo modello, ma grazie a questo teardown sono riuscito a levarmi dei dubbi su alcuni punti. Molto difficile ma anche parecchio soddisfacente come riparazione.
"Today's million-dollar question: Is this a scaled-up version of the 13-inch "Escape Edition," or a scaled-down version of the 15-inch Touch Bar unit? Here's what the tech specs tell us:"
So we'll need the teardown of the 15" to be sure.
alex - 回复
Where I can find information about remplace the SSD from 256gb to 1Tb in the model A1706? Its impossible shopping the hdd!
corpusgc@gmail.com
Corpus García Ruiz.- - 回复
