简介
Mac Pro Early 2009 8 Core.
你所需要的
Der rechte Lüfter des Prozessorgehäuses. Beachte, dass er von zwei Klammern oben und unten zusammengehalten wird.
由衷感谢以下译者:
100%
这些译者帮助我们修补全世界! 您也想加入吗?
开始翻译 ›
23条评论
It is socket-b(LGA 1366)
I think it is easy to upgrade your CPU
It should be easy to upgrade a single-cpu Pro, they use standard lidded Xeons. I am planning on upgrading to W3690s in a couple of 4,1 machines that have had their firmware flashed to 5,1.
tobiasboyd - 回复
Please let me know how you handle that upgrade!! Or add a tutorial id vey much like to see that and maybe follow suit but im not very savy with these upgrades
Will -
Is it possible to easily remove and service right processor fan (the back one)? It makes too much noise, so needs some oil apparently. I didn't find any way to remove it.
Is it possible to replace the fans with quieter fans?
I have acquired a MacPro 4,1 from my friend who no longer needed it and couldn't get it working anyway. The weirdest thing is none of the internal drives show up, not even when booting off an external OS drive, and the ethernet ports as well. Everything else seems to work, installed a fresh copy of El Capitan on an external and all works but these two items. Makes me believe that there may be a disconnected or bad cable to the backplane but I am having a hard time finding the info online and any pictures on what to look for. Any ideas or suggestions?
Hello barrebbi, I just had the same problem happen to me the macpro was working well and all of the sudden the drives disappear and the internet connection was gonne too . I try to unplug everything and do a pram clean and nothing, the next thing I will do is run the ahd diagnose utility for this computer. what I am missing is the internal drivers the 4 internal sata’s but the optical drives are working fine, also I lost the wifi, ethernet and the optical audio port. the external audio is fine. I was browsing online nothing really taxing for the computer. if I cannot fix it I will install a pci usb 3 port to run external drives and a usb3 to ethernet port to get the network and internet back and a usb bluetooth dongle. If anyone can help or guide us to find a solution I will great appreciated. Berrebbi if you find anything please advice I will do so too. Thanks in advance.
Sorry, I have not been able to get an answer yet. And for some reason, this model won’t upgrade bootcamp to Windows 10 (or 8) either, black screen. I’ve updated older models but not this one.
Still no answer for me
Missing connection of HDD bays and, more importantly, the connections between the HDD bays and the logic board.
Still haven’t figured it out yet
Is the Bluetooth connector on the motherboard a standard USB single port [Vcc, D-, D+, GND] connector ?
Nope, there’s a picture in step 10- I think it’s a PCI-E connector of some type. Definitely not USB though.
Anyone ever figured out how to “teardown” the fan-cage assembly from the PCI lane area (the one hovering that has the PCI lock bar mechanism). The assembly is easy to remove, but !&&* if I can figure out how to free the fan from it.
I got as far as being able to release the female plug so that it could slide through the plastic, and the fan appears seated on rubber type posts, just can’t separate the two cage elements to get to it. (at least not without worrying amounts of force).
I need to know how you removed the bottom case with the fans. I cant find any documentation on it. Thanks
Hello,
I disassembled my mac pro 2009 for cleaning, and putted it back together. Everything works fine, except for the power button LED. It not longer lights up. I tried reconnecting everything and resetting SMC and PRAM with no success.
Is the logicboard of those type same ? Can I change the quad-core logicboard with 8-core logicboard or vice versa ? Thanks.
You can swap the trays with another model of the same generation, yes. 2010/2012 are interchangeable , but you have to swap 2009 with 2009 parts, otherwise the fans will run at full speed due to differing low-level firmware between the 2009 and 2010 models.
