跳转到主内容
本拆机指南正在进行中 – 定期刷新以看到更新!
你所需要的
  1. M6013 Capacitor Meter Teardown, Removing Battery: 步骤 1 中的图像 1,2 M6013 Capacitor Meter Teardown, Removing Battery: 步骤 1 中的图像 2,2
    • Remove the circled screw
    • Remove battery case and batteries
  2. M6013 Capacitor Meter Teardown, Removing Case: 步骤 2 中的图像 1,3 M6013 Capacitor Meter Teardown, Removing Case: 步骤 2 中的图像 2,3 M6013 Capacitor Meter Teardown, Removing Case: 步骤 2 中的图像 3,3
    • Remove circled screws
    • Pull case apart
    • Watch out for buttons, they will fall out easily.
  3. M6013 Capacitor Meter Teardown, Remove Circuit Board: 步骤 3 中的图像 1,3 M6013 Capacitor Meter Teardown, Remove Circuit Board: 步骤 3 中的图像 2,3 M6013 Capacitor Meter Teardown, Remove Circuit Board: 步骤 3 中的图像 3,3
    • Be careful when removing the circuit board, the battery cable is still connected.
    • Unsolder the square locations either on the circuit board or the case to fully remove the circuit board
    Good morning, community, I need help to identify the value of resistors R10, R6, R7, R1 of my m6013 that broke down by mistake.
    Ing_cor - 回复
  4. M6013 Capacitor Meter Teardown, Microprocessor: 步骤 4 中的图像 1,2 M6013 Capacitor Meter Teardown, Microprocessor: 步骤 4 中的图像 2,2
    • Location of microprocessor
  5. M6013 Capacitor Meter Teardown, Remove Display: 步骤 5 中的图像 1,2 M6013 Capacitor Meter Teardown, Remove Display: 步骤 5 中的图像 2,2
    • Remove the cable connector
    • Remove Display
Ted Hsueh
于09/20/12注册
170 声望
创作了3篇指南
团队
Cal Poly, Team 16-56, Forte Fall 2012 Cal Poly, Team 16-56, Forte Fall 2012 的会员
CPSU-FORTE-F12S16G56
5 名成员
创作了13篇指南
2条评论
Add some specs on start and foto of the unit ....
Mateusz - 回复
Hello everyone, can someone help me identify the regulator that is in the printed circuit of this capacimeter identified with "U1" and the diode "D1" I appreciate any information.
CHUCHOX - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 14
总计 612
