跳转到主内容
你所需要的
视频概述
这个拆解是不是维修指南。 要维修你的的Logitech M510,请使用我们的维修手册
  1. Logitech M510 Teardown, Logitech M510 Teardown: 步骤 1 中的图像 1,1
    • Let's get started!
  2. Logitech M510 Teardown: 步骤 2 中的图像 1,1
    • Flip your mouse over
  3. Logitech M510 Teardown: 步骤 3 中的图像 1,1
    • Remove the batteries by pulling on the tab.
    • If you do not plan on putting it back together, ensure you dispose of the batteries properly.
  4. Logitech M510 Teardown: 步骤 4 中的图像 1,1
    • Take the battery pull tab that is circled in red and tape it to the area that is circled in blue
    • This allows you to access the screws that are hidden by the battery pull tab
  5. Logitech M510 Teardown: 步骤 5 中的图像 1,1
    • Unscrew the two screws that are circled in yellow.
  6. Logitech M510 Teardown: 步骤 6 中的图像 1,1
    • Remove the tape
  7. Logitech M510 Teardown: 步骤 7 中的图像 1,1
    • Now you can easily separate the bottom and the top of the device.(Just give it a little tug)
  8. Logitech M510 Teardown: 步骤 8 中的图像 1,1
    • Okay now that we've got it separated we can have a sneak peek inside
    • The scroll wheel.
    • The battery area
    • Mouse buttons
  9. Logitech M510 Teardown: 步骤 9 中的图像 1,1
    • Now unscrew the screw that is circled in yellow
  10. Logitech M510 Teardown: 步骤 10 中的图像 1,1
    • Now disconnect the cable there is circled in blue by unplugging it from the logic board.
  11. Logitech M510 Teardown: 步骤 11 中的图像 1,1
    • We have taken apart the bottom half, So let's take apart the top half.
    • This is the on-off switch.
  12. Logitech M510 Teardown: 步骤 12 中的图像 1,1
    • Let's get started disassembling the top half
    • Remove the two screws circled in yellow.
  13. Logitech M510 Teardown: 步骤 13 中的图像 1,1
    • Okay now that we've got that done, lets continue
  14. Logitech M510 Teardown: 步骤 14 中的图像 1,1
    • Remove the screw circled in yellow
  15. Logitech M510 Teardown: 步骤 15 中的图像 1,1
    • Now you can pop out the scroll buttons.
  16. Logitech M510 Teardown: 步骤 16 中的图像 1,1
    • Now pop out the piece circled in yellow
  17. Logitech M510 Teardown: 步骤 17 中的图像 1,1
    • And there we go we have disassembled the entire mouse.
Xavier
于04/20/21注册
352 声望
撰写一个指南
团队
X71FS X71FS 的会员
Community
1 名成员
创作了3篇指南
5条评论
I’ve actually seen a model of this same mouse where optics sensor is MODULAR with a ribbon cable. So much better for repairability!
Giorgi - 回复
I don’t have this mouse, but an LX8 Cordless Laser Mouse. It looked quite similar so gave it a go, and presto! It opened up easily, I could get to all the internal bits quite easily and removed years of cat hair, tobacco grains and human oils which had formed felt mats around the moving parts and gummed it up completely! Now factory fresh and restored to full function - couldn’t be happier! Thanks Xavier!
Adrian Mann - 回复
It says the video is private.
Michael Norton - 回复
The video is private. But the instructions are good without the video.
Note that the front-side of the mouse has tabs that hold the pieces together, so mate the front of the mouse (the button-side) before mating the end closes to the batteries (and the screws)
Adam Goldberg - 回复
Thanks! It would be great if you showed how to take the wheel out - it has to be pried out of its seat in the front of the mouse. FYI for cleaning it only takes steps 1 thru 8 plus taking out the wheel.
PB - 回复
添加评论
浏览统计数据:
过去 24 小时: 14
过去 7 天: 85
过去 30 天: 326
总计 9,366
