跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Logitech M Series Mouse,请使用我们的维修手册
  1. Logitech M235 Teardown, Logitech M235 Teardown: 步骤 1 中的图像 1,1
    • Remove the battery and battery cover
  2. Logitech M235 Teardown: 步骤 2 中的图像 1,2 Logitech M235 Teardown: 步骤 2 中的图像 2,2
    • Remove the the two screws holding the cover.
    • I had two of these mouses and one of them had a screw hidden under the CE sticker so make sure you check it out before opening the mouse apart
  3. Logitech M235 Teardown: 步骤 3 中的图像 1,1
    • Use a prying tool to split the mouse case apart.
  4. Logitech M235 Teardown: 步骤 4 中的图像 1,1
    • The case should be easy to open and not require much force.
  5. Logitech M235 Teardown: 步骤 5 中的图像 1,1
    • The PCB is only held by a few clips and can be easily removed.
  6. Logitech M235 Teardown: 步骤 6 中的图像 1,1
    • The top mouse cover can be removed by undoing three white clips holding it on the grey plastic part.
  7. Logitech M235 Teardown: 步骤 7 中的图像 1,1
    • Done!
Daniel
于11/27/16注册
225 声望
撰写一个指南
团队
4Bits Repairs 4Bits Repairs 的会员
Business
1 名成员
创作了2篇指南
8条评论
Great work. Hope to see some more of your work
Mustafa karu - 回复
thank you..this helped me a looot
Sharnav Kundu - 回复
My M325 has NO SCREWS!!! Now what???
christcansaveyou - 回复
There are several variants. Mine has only one screw, hidden by the battery compartment label, near the + terminal
Robert Reite - 回复
The most common problem with this mouse is dust and dirt getting in the optical encoder for the wheel.
Robert Reite - 回复
添加评论
浏览统计数据:
过去 24 小时: 8
过去 7 天: 16
过去 30 天: 97
总计 21,165
