跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Logitech Harmony Hub,请使用我们的维修手册
  1. Logitech Harmony Hub Teardown, Unboxing: 步骤 1 中的图像 1,3 Logitech Harmony Hub Teardown, Unboxing: 步骤 1 中的图像 2,3 Logitech Harmony Hub Teardown, Unboxing: 步骤 1 中的图像 3,3
    • Powercord with a micro USB connector
    • European plug adapter
    • American plug adapter
    • Harmony Hub
    • Micro USB cable
    • IR mini blaster
  2. Logitech Harmony Hub Teardown, Finding the screws: 步骤 2 中的图像 1,3 Logitech Harmony Hub Teardown, Finding the screws: 步骤 2 中的图像 2,3 Logitech Harmony Hub Teardown, Finding the screws: 步骤 2 中的图像 3,3
    • Since we didn't find any screws we expected them to be under the soft foot pads.
    • We easily removed them with a utility knife
    • Now we can see 4 screws and 2 openings to the PCB.
    • I wondered what they could be but my guess is that they're used to test the PCB.
  3. Logitech Harmony Hub Teardown, Opening the hub: 步骤 3 中的图像 1,3 Logitech Harmony Hub Teardown, Opening the hub: 步骤 3 中的图像 2,3 Logitech Harmony Hub Teardown, Opening the hub: 步骤 3 中的图像 3,3
    • The case opens up easily when using a utility knife around the sides
    • This is a cover paper to make sure the status LED doesn't shine in the rest of the casing but just to the front
  4. Logitech Harmony Hub Teardown, Casing: 步骤 4 中的图像 1,3 Logitech Harmony Hub Teardown, Casing: 步骤 4 中的图像 2,3 Logitech Harmony Hub Teardown, Casing: 步骤 4 中的图像 3,3
    • Inside the top case we find a load to give the product a little more weight
    • As you can see the top case is made a little thinner on the places where an IR led is present
  5. Logitech Harmony Hub Teardown, PCB Top: 步骤 5 中的图像 1,3 Logitech Harmony Hub Teardown, PCB Top: 步骤 5 中的图像 2,3 Logitech Harmony Hub Teardown, PCB Top: 步骤 5 中的图像 3,3
    • PCB was manufactured by a Chinese company called FCF
    • There are 6 IR leds spread over the PCB
    • CC2544 SoC 2.4-GHz RF Transceiver and antenna
    • CSR8811 bluetooth chip and antenna
    • WiFi antenna from the AR9331 on the other side of the pcb
    • MX25L12835F 128Mbits serial Flash memory
  6. Logitech Harmony Hub Teardown, PCB Bottom: 步骤 6 中的图像 1,3 Logitech Harmony Hub Teardown, PCB Bottom: 步骤 6 中的图像 2,3 Logitech Harmony Hub Teardown, PCB Bottom: 步骤 6 中的图像 3,3
    • EM6AB160TSE-5G 512 Mbits SDRAM
    • AR9331 2.4 GHz 802.11b/g/n SoC for AP and Router Platforms
    • Micro USB (data and power) - Can be used to extend this hub with a Harmony Home Hub Extender
    • Reset/Pair button
    • 2x IR mini blaster ports (2.5mm)
November Five
于08/25/16注册
465 声望
创作了4篇指南
3条评论
Thanks for doing this!
Haluska - 回复
Thanks for sharing this! I think I see an antenna port on that board, too. Interesting …
Now I’m wondering if I should take my chances and try to fix the loose micro usb port or just live with it.
Haluska - 回复
Extremely helpful, thank you. But I also want to know the location of IR input which is used to learning IR commands from original remotes.
Tochi Chiang - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 15
过去 30 天: 55
总计 7,682
