跳转到主内容
简介
I will teach you how to dissemble this Router
这个拆解是不是维修指南。 要维修你的的Linksys WRT54G,请使用我们的维修手册
  1. Linksys WRT54G Teardown, Get your Linksys: 步骤 1 中的图像 1,2 Linksys WRT54G Teardown, Get your Linksys: 步骤 1 中的图像 2,2
    • The Linksys WRT54G series is a series of Wi-Fi gateways manufactured by Linksys, a subsidiary of Cisco Systems.
  2. Linksys WRT54G Teardown, Antenna Removal: 步骤 2 中的图像 1,2 Linksys WRT54G Teardown, Antenna Removal: 步骤 2 中的图像 2,2
    • Let's begin with the teardown! First, unscrew the antennas from the back of the router and set them aside.
  3. Linksys WRT54G Teardown, Front Panel Removal: 步骤 3 中的图像 1,3 Linksys WRT54G Teardown, Front Panel Removal: 步骤 3 中的图像 2,3 Linksys WRT54G Teardown, Front Panel Removal: 步骤 3 中的图像 3,3
    • Lets get into the internals! First, flip the unit over and insert a small flat-head screwdriver in between the warranty sticker and the front panel and gently pry it open.
    • Beware! It may take some effort to pry the panel off. Also, be careful not to damage the motherboard, like I did.
    • This will certainly void your warranty from 2002, in case you wanted to know.
  4. Linksys WRT54G Teardown, Remove Top Panel: 步骤 4 中的图像 1,3 Linksys WRT54G Teardown, Remove Top Panel: 步骤 4 中的图像 2,3 Linksys WRT54G Teardown, Remove Top Panel: 步骤 4 中的图像 3,3
    • Now, slide the top plastic panel off and put it aside you now have a clear view of the motherboard.
    • Intel TE28F320 Flash Memory
    • Broadcom BCM4712KPB (I think it’s a modem chip)
    • Admtek ADM6996L Ethernet Controller
    • Activity LEDs
    • Issi 42S16400-6T Random Access Memory (unsure how much)
    • An assortment of other chips I couldn't find.
  5. Linksys WRT54G Teardown, Remove Motherboard: 步骤 5 中的图像 1,3 Linksys WRT54G Teardown, Remove Motherboard: 步骤 5 中的图像 2,3 Linksys WRT54G Teardown, Remove Motherboard: 步骤 5 中的图像 3,3
    • Time to remove the motherboard! Unscrew the single Phillips screw, slide the motherboard and then lift it out.
    • Single Phillips screw
    • Plastic slips holding the motherboard in place.
  6. Linksys WRT54G Teardown, Done!: 步骤 6 中的图像 1,1
    • You're done! Thanks for sticking with me for my first teardown!
    • If you want to reassemble this, just do this guide in reverse order! (assuming you didn't break it like I did)
Reed Crosby
于2016年12月07日注册
4,189 信誉积分
撰写一个指南
团队
Kid fixers Kid fixers 的会员
Community
126 名成员
创作了112篇指南
一条评论
添加评论
浏览统计数据:
过去的24小时: 4
过去的7天: 18
过去的30天: 81
总计 6,038
