跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Linksys router WRT54G2 V1,请使用我们的维修手册
  1. Linksys WRT54G2 V1 Teardown, Getting Ready!: 步骤 1 中的图像 1,2 Linksys WRT54G2 V1 Teardown, Getting Ready!: 步骤 1 中的图像 2,2
    • looks like my desk is a mess! Time to clean up!
    • This may take a while.
  2. Linksys WRT54G2 V1 Teardown: 步骤 2 中的图像 1,2 Linksys WRT54G2 V1 Teardown: 步骤 2 中的图像 2,2
    • Much Better.
    • The lighting looks good with minifigure holding a spudger.
    • Do not attempt to make a minifigure hold a spudger. he could fall over and get hurt.
  3. Linksys WRT54G2 V1 Teardown, Actually being productive.: 步骤 3 中的图像 1,3 Linksys WRT54G2 V1 Teardown, Actually being productive.: 步骤 3 中的图像 2,3 Linksys WRT54G2 V1 Teardown, Actually being productive.: 步骤 3 中的图像 3,3
    • this is the linksys WRT54G2 V1.
    • The Internet in jack.
    • The 4 Ethernet out jacks
    • One reset button.
    • One 12 Volt DC .5 amp inlet.
    • 1 WPS button.
  4. Linksys WRT54G2 V1 Teardown, Taking it apart!: 步骤 4 中的图像 1,3 Linksys WRT54G2 V1 Teardown, Taking it apart!: 步骤 4 中的图像 2,3 Linksys WRT54G2 V1 Teardown, Taking it apart!: 步骤 4 中的图像 3,3
    • This is the back of the router. and 4 of its screws must be removed
    • WHAT IS THIS? A new screw!
    • Nothing but the best equipment to tackle this! @kelsea recommended I should use my tools more.
  5. Linksys WRT54G2 V1 Teardown, Resistance: 步骤 5 中的图像 1,3 Linksys WRT54G2 V1 Teardown, Resistance: 步骤 5 中的图像 2,3 Linksys WRT54G2 V1 Teardown, Resistance: 步骤 5 中的图像 3,3
    • I feel a disturbance in this repair...
    • AHA! its darth voider! WE MUST DESTROY HIM!
    • iFixit emerges once again! VICTORY!
  6. Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 步骤 6 中的图像 1,3 Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 步骤 6 中的图像 2,3 Linksys WRT54G2 V1 Teardown, Back to your regularly scheduled programming: 步骤 6 中的图像 3,3
    在这个步骤中使用的工具:
    iFixit Opening Tool
    $1.99
    购买
    • How do we open this? Rip it open? No... As tempting as that is there must be a more elegant way...
    • iFixit tools are elegant right? Use a iFixit Opening Tool to do the trick. mostly in the back corners.
    • The cover seems to pop back with nothing holding it. I used a screw from the router to hold it.
  7. Linksys WRT54G2 V1 Teardown: 步骤 7 中的图像 1,1
    • only popping the back corners does not appear to be enough.
    • The front area seems stronger, and it feels like it may snap my opening tool. onto the big guns!
  8. Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 步骤 8 中的图像 1,3 Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 步骤 8 中的图像 2,3 Linksys WRT54G2 V1 Teardown, THE SPUDGENATOR 9000!: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    Metal Spudger
    $2.99
    购买
    • Engraved with the word IFIXIT to show authenticity.
    • Made with REAL metal
    • Look at that obviously not edited in shine!
    • Luckily I own one of these beauties. you can buy one too! BUY THE SPUDGENATOR 9000 HERE!
  9. Linksys WRT54G2 V1 Teardown: 步骤 9 中的图像 1,3 Linksys WRT54G2 V1 Teardown: 步骤 9 中的图像 2,3 Linksys WRT54G2 V1 Teardown: 步骤 9 中的图像 3,3
    • insert the SPUDGENATOR 9000 and slide it through the split until you here pops.
    • POP!
    • POP!
    • POP!
    • Eventually it will open.
  10. Linksys WRT54G2 V1 Teardown: 步骤 10 中的图像 1,3 Linksys WRT54G2 V1 Teardown: 步骤 10 中的图像 2,3 Linksys WRT54G2 V1 Teardown: 步骤 10 中的图像 3,3
    • Here is the back of the WPS button.
    • These tabs are held in too much for my fingers to get! Time for the SPUNGENATOR 9000! use it to pry those tough tabs.
    • Aaaaand its out! (after breaking a tab)
  11. Linksys WRT54G2 V1 Teardown: 步骤 12 中的图像 1,3 Linksys WRT54G2 V1 Teardown: 步骤 12 中的图像 2,3 Linksys WRT54G2 V1 Teardown: 步骤 12 中的图像 3,3
    • Removal of the logic board motherboard includes no screws.
    • I'm not removing the motherboard because that would involve cutting the wires, and I want to use this later! (not in the mood for soldering today. =p)
  12. Linksys WRT54G2 V1 Teardown, THE END!: 步骤 13 中的图像 1,2 Linksys WRT54G2 V1 Teardown, THE END!: 步骤 13 中的图像 2,2
    • All the parts.
    • Thumbs up not included.
  13. Linksys WRT54G2 V1 Teardown, SETUP: 步骤 14 中的图像 1,3 Linksys WRT54G2 V1 Teardown, SETUP: 步骤 14 中的图像 2,3 Linksys WRT54G2 V1 Teardown, SETUP: 步骤 14 中的图像 3,3
Aiden
于09/19/15注册
17,486 声望
创作了21篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 20
总计 2,085
