跳转到主内容
你所需要的
这个拆解是不是维修指南。 要维修你的的Lexmark Z11,请使用我们的维修手册
  1. Lexmark Z11 Teardown, Lexmark Z11 Teardown: 步骤 1 中的图像 1,2 Lexmark Z11 Teardown, Lexmark Z11 Teardown: 步骤 1 中的图像 2,2
    • Be sure to remove the power cord and all other connections to and from the device.
    • Remove easily detachable parts.
  2. Lexmark Z11 Teardown: 步骤 2 中的图像 1,1
    • To remove the cover and housing use a screw driver to remove the highlighted screws.
  3. Lexmark Z11 Teardown: 步骤 3 中的图像 1,1
    • Additionally, remove those two screws at the bottom of the device.
  4. Lexmark Z11 Teardown: 步骤 4 中的图像 1,2 Lexmark Z11 Teardown: 步骤 4 中的图像 2,2
    • Press the nib marked in green inside and slightly lift the housing from the back plate shown in the first image here.
    • The housing can be removed by lifting and rotating it around the catches on the lower front side of the device highlighted in purple. Finally, it is shifted slightly to the front out of those catches.
  5. Lexmark Z11 Teardown: 步骤 5 中的图像 1,3 Lexmark Z11 Teardown: 步骤 5 中的图像 2,3 Lexmark Z11 Teardown: 步骤 5 中的图像 3,3
    • With this inner part nearly everything is easily accessible. There are two stepper motors:
    • NMB PM42L-048-FEA8
    • 4 wires
    • Mitsumi H9601
    • 5 wires, can probably be resoldered to use 4 or 6 wires
    • There is also an electronics board as well as smaller useful parts like buttons, LEDs, light barriers.
    • Motorola XC901051FTA
    • Motorola 34063 (switching voltage regulator)
  6. Lexmark Z11 Teardown: 步骤 6 中的图像 1,3 Lexmark Z11 Teardown: 步骤 6 中的图像 2,3 Lexmark Z11 Teardown: 步骤 6 中的图像 3,3
    • The motors in detail.
raumschaum
于02/27/13注册
371 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,422
